This thread is privately moderated by timecop, who may elect to delete unwanted replies.
Old Sep 23, 2011, 01:27 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Data
DJI Wookong-M mini-technical-review
I got my package a couple days ago but didn't have time to screw around with it until today. There has been a bit of misinformation and "covering up" made by DJI and their dealers, so I figured I'll post some non-bs info.
First things, nice packaging.
Without the PMU (Proprietary Power Management Unit) the entire setup draws a hefty 650-700mA. This definitely explains why some people have been having heating BEC issues. Cheap 7805's inside a typical HK esc dropping 12-16V down to 5V would generate a ton of heat at 700mA. Lessons learned: use the PMU
The GPS does have a battery backup, and appears to be using ublox neo GPS module with label removed, according to the comments in this post. Compass is, oddly, HMC5883. The entire GPS setup is driven by an Atmel SAM3 Cortex-M3 processor. HMC5883 is NOT on a separate power supply, but I guess since there are no other sensors (besides GPS) on the same voltage rail, that's not so bad, and the 4.7uF (or larger) cap that the chip requires is quite far from the IC itself - that's a bit puzzling, as most problems associated with this compass have been due to the cap being too far or routed through too many vias, affecting measurement.
The "proprietary DJI bus" is actually CAN-bus. There's probably telemetry and other useful info on it, but I didn't bother looking too much into it. Pinout is something like VCC/GND/CANH/CANL.
The status led is blinding. Do NOT look into it while it flashes, you will die. I still have red spots in my eyes.
The IMU is extremely well made and I would imagine counts for the majority of the cost of the unit. While I would have expected to find Analog Devices ADIS series of pre-made temperature-compensated 6DOF IMUs, this is a custom-made job with gyro/accel sensors assembled into a kind of a PCB cube with some sort of custom ASIC driving them - perhaps an Actel FPGA from the packaging, but I didn't look too much into it. The IMU also communicates over CAN bus. Looks like things can get pretty busy on it.
Every chip on the unit has the markings professionally lasered-off and replaced with DJI logo and part number, like IMU001, MCU001, etc. That doesn't really help the fact that the components are readily identifyable - the GPS as mentioned uses Atmel SAM3, a 96MHz Cortex M3 processor, and so does the Main Controller. There's also a bunch of SO-8 CANBus transceivers, which I originally thought were LM317's. The pictures haven't been updated, but almost everywhere you see LM317 in the pic its CANBus. There's also a sprinkling of some coils and random chips/passives, but nothing spectacular - general components that aren't sensors on this unit are standard. PCBs are professionally made and silk quality is good. Main Controller is a 2 layer, and GPS is 4-layer board, while IMU main PCB is kind of strange, its two 2-layer, .5mm thin boards back to back for some odd reason, maybe due to noise issue or similar.
UPDATE: I've xrayed and checked out the IMU. Some shocking discoveries inside Gyroscopes are ADXRS620, one per axis. No surprise there. Accelerometer, likely something analog, perhaps even LIS344AH or so. It's got an opamp next to it to reduce its output impedance. Barometer was the biggest shock, it's MPXZ6115X or so, one of the standard Freescale baros that every MK clone uses Every sensor is mounted backwards facing into an IMU cube, which is actually a very good design - entire thing is securely fastened to what looks like a molded metal cube, with 1.6mm PCBs on each cube edge containing a particular sensor and support circuits, and each sensor is separated by the metal mass. Barometer gets its pressure through 3 holes on the back of the PCB, which is then vented through a small hole in the IMU housing - no propwash issues here. No pics will be posted due to NDA and high security and all the other stuff, but you can trust me on this.
There's been a lot of discussion about "200Hz" in the DJI thread. Let's put it to rest, guys. PWM output from the M1..M6 is at 400Hz period. PWM output from F1, F2 (gimbal) is 100Hz. When configured as an Octo, F1/F2 become 400Hz as well. What does the 200Hz mean then? If I had to uneducatedly guess, it's probably the loop time of their main software loop. While not really spectacular, that's 5ms, and is probably more than enough for a stable platform. I was told anything below 25ms is acceptable for multirotor stability as things like motor response and etc are the biggest factor here. Hardware PWM blocks are used for output, so there's no jitter or any other noise. With proper high-response ESCs, this should be lots of fun for everybody.
Once I stop trolling threads and actually figure out how to put this thing on a multirotor, I'll have some flying vids, but don't hold your breath.
Some pics attached for those who's been dying for them.
My guesstimate on the Main Controller BOM is ~$20, GPS, ~$20, and $150 for IMU. Here you have it! The rest of the cost is in "proprietary INS/GPS algorithms" ^_^
timecop is offline Find More Posts by timecop
Last edited by timecop; Sep 25, 2011 at 05:38 AM. Reason: some more gps clarifications
Reply With Quote  (Disabled)
Old Sep 23, 2011, 01:47 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
tc... great work. But it's not a review yet until the final judgement "is it or is it not worth it" is made.
fajar is offline Find More Posts by fajar
Old Sep 23, 2011, 02:00 AM
timecop is offline
Joined Dec 2010
Ya I realize that, but with my main hobby it's kind of hard to find time for this stuff
I think the hardware is capable, and I'll have a look at the actual performance when time permits.
Old Sep 23, 2011, 02:02 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
evil! lol
Quad_Addict is offline Find More Posts by Quad_Addict
Old Sep 23, 2011, 02:07 AM
fajar is offline
fajar's Avatar
Joined Jan 2011
hahaha... you're the time cop, you'll find the time
Old Sep 23, 2011, 02:09 AM
Joined Dec 2006
yea Ham "steal" some time
Old Sep 23, 2011, 02:11 AM
tomrock is offline
Find More Posts by tomrock
tomrock's Avatar
Germany, NRW, Cologne
Joined Feb 2011
thanks for the work you have done to look inside that,timecop !
hmm, use your Brain, or pay for it -lol !!!
my own final judgement is as clear as it could be :
xxxxxxxxcensoredxxxxxxxx
greetings from out of the forest...muhahaha...
tomrock is offline Find More Posts by tomrock
Old Sep 23, 2011, 02:13 AM
fajar is offline
fajar's Avatar
Joined Jan 2011
done both before posting that, have you?
Old Sep 23, 2011, 02:18 AM
tomrock is offline
tomrock's Avatar
Joined Feb 2011
i dont point at you, sorry if its come to you like a personal answer ...
"use your Brain" is for all ,who asking that question "worth or not" for them self
Old Sep 23, 2011, 02:20 AM
fajar is offline
fajar's Avatar
Joined Jan 2011
no worries mate...
Old Sep 23, 2011, 02:36 AM
ddmt is offline
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
from the pins and those 3 holes, the gps modules looks like the u-blox neo series
ddmt is offline Find More Posts by ddmt
Old Sep 23, 2011, 02:39 AM
timecop is offline
Joined Dec 2010
ddmt, quite possible. I didn't bother checking the serial testpoints to see if data was nmea or something else, if it was ubx serial protocol it would be very easy to tell. My interest was mainly that GPS *does* have a battery backup. I wonder why people are having such a hard time with GPS lock?
Old Sep 23, 2011, 02:54 AM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
I find it odd the backup battery is in close proximity to the triaxial magnetometer. I'd have placed it on the top left corner above the GPS antenna.
Photoship One is offline Find More Posts by Photoship One
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
Yeah, I'm quite confuse about the gps lock as well. Where is the gps antenna BTW? Do you have any tool to check the frequency interference? The guy who uses the carbon uavframe said he got the gps lock in seconds. Could it be the interference from the IMU & ESC?
Old Sep 23, 2011, 02:59 AM
timecop is offline
Joined Dec 2010
GPS antenna is on the back, its a regular square ceramic antenna. Back side of the GPS is all copper plane, with the antenna in the center. I added the gps front side pic. I do have a spectrum analyzer and some EMI/RFI measurement antennas, I can poke around them later when i have some time. I'm curious as well.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Cool Karbonic-XXL 50CM DJI WooKong-M frame superdave42 Multirotor Talk 12 Mar 09, 2012 10:01 AM
Discussion DonsRC KA20-22L technical "review" CuStOm Power Systems 13 Jan 18, 2008 09:57 AM
