Old Sep 23, 2011, 12:45 AM
drstation is offline
Find More Posts by drstation
Egypt, Alexandria
Joined Sep 2011
Dividing "Separating" wing ??
I'm building a 2 meters wing span glider
can someone tell me how to separate each wing into 2 parts to be attatched and separated for easy transport of the plane ?
drstation is offline Find More Posts by drstation
Old Sep 23, 2011, 02:50 AM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
We need to know the wing structure before we can offer any advice. Is it open structure balsa, sheeted balsa, foam or composite covered foam?
RobC(UK) is offline Find More Posts by RobC(UK)
Old Sep 23, 2011, 03:31 AM
Egypt, Alexandria
Joined Sep 2011
Foam wings
the entire plane will be made from foam with carbon rods for strenth and some ply wood in the fuselage wing junction
Old Sep 23, 2011, 03:32 AM
Egypt, Alexandria
Joined Sep 2011
Foam wings
Old Sep 23, 2011, 09:27 AM
RobC(UK) is offline
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
Aha, could be difficult. How thick is the airfoil at its thickest part?
Old Sep 23, 2011, 11:58 AM
thewildweasel is offline
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
I've used carbon tubes of two different diameters for this before, with the narrower diameter being a tight fit in the other. Bit of tape to hold the panels together and an anti-rotation pin does the job nicely.
Here's a good example of what I mean. http://www.rcgroups.com/forums/showt...ruction+thread
thewildweasel is offline Find More Posts by thewildweasel
Old Sep 23, 2011, 12:17 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
It would be better to make a single center piece and have removable tips..
..a
Old Sep 23, 2011, 04:51 PM
Egypt, Alexandria
Joined Sep 2011
Root chord 1.6 cm
tapering till tip chord 1 cm
Old Sep 23, 2011, 04:55 PM
Egypt, Alexandria
Joined Sep 2011
i thought about that but the problem is with many separation and assembly i think the carbon rod is gonna be detached from the foam
or will it be safe?
Old Sep 23, 2011, 05:18 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Many many gliders that have split wing sections merely use packing or electrical tape to hold the wing together as one piece. But I don't know if that will work with foam, tape sticks well to smooth glass.
Xpress.. is online now Find More Posts by Xpress..
