This thread is privately moderated by Eastcoast78, who may elect to delete unwanted replies.
Old Sep 22, 2011, 10:53 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
KFm4 42'' Scratchbuilt FPV WIng
Well i decided to get into FPV seeing its coming on Fall here now, the air is getting cool and before you know it,t he days are well be shorter.
First up i wanted something that would be easy to fly! Carry anywhere between 4200mah or maybe even up too 5000mah, and have a AUW anywhere between 1000g-1500mah.
I considered Buying a Ritewing or something like it, But i like building and testing.
So i decided to build one from Owens cornering Pink Foam.
I got 2 4'x8' sheets for $14 from my local Home depot!
For the FPV i have the 5.8g 200mw FPV Wireless AV Tx & Rx Set
http://www.hobbyking.com/hobbyking/s...dProduct=15295
I well not be using goggles at first. I have plan to get a LCD monitor and install it in one of those Big Black Rubber maid Action packers.
Could easily make/install it like a Speaker and surround with Black foam, like the inside of a TX case!!
ANd save up for a decent pair of goggles
For the camera i well be wiring a 2.5mm 4 pole jack plug it directly feeding the video through my GoPro!
Thanks for RC Flight Test for this great video.
How To Use a GoPro for FPV (7 min 12 sec)
In trying to find a decent Powerplant that was semi efficient!! I needed something that could swing a 8 or 9 '' Prop.
So i decided to give this one a shot!
http://www.hobbyking.com/hobbyking/s...dProduct=14342
If ordering this BL get this. be sure to pick this up as well this BL does not come with any mounting hardware!
http://www.hobbyking.com/hobbyking/s...dProduct=14501
I also got 2 of these servos to test.
http://www.hobbyking.com/hobbyking/s...idProduct=8497
I have a HK 40-50A esc now...Which should hold up. Having the ESC on the wing well Provide Lots of ventilation...
Specs:
Model: NTM Prop Drive 35-36A 1400
Kv: 1400rpm/v
Turns: 7
Max current: 55A
Max Power: 550W
Shaft: 4mm
Weight: 117g
ESC: 60A
Cell count: 3s~4s Lipoly
Front Mounting Hole Distance: 25mm or 19mm
Connection: 3.5mm Bullet-connector
Suggested Prop: 8x4 ~ 11x5.5
Prop Tests:
8x4 - 14.8v - 621W - 42A
8x4 - 11.1v - 277W - 25A
9x6 - 11.1v - 432W - 39A
10x5 - 11.1v -510W - 46A
11x5.5 - 11.1v - 543w - 49A
FPV is all new to me and i well not have OSD for now. Ill just keep it in view
But thats on the list as well
Heres a few pictures of the build so far!!
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Sep 22, 2011, 11:35 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Here are some more Pictures
Old Oct 14, 2011, 04:53 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
5.8Ghz 200mW FPV Testing (4 min 3 sec)
Old Oct 29, 2011, 01:51 AM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
FPV Wing Maiden (6 min 19 sec)
Old Feb 22, 2012, 06:47 PM
rcthrasher is offline
Find More Posts by rcthrasher
Joined Feb 2011
Hey this is just the plane i have looking for to build to carry my gopro. Do You still have the plane? Could you post the dimensions?
rcthrasher is offline Find More Posts by rcthrasher
Discussion Divinity, 42" KFm4 Slowfying wing. ApachePilot Foamies (Scratchbuilt) 2207 Mar 30, 2016 07:15 AM
Discussion KFm4-Epp-Swift-Like (KESL) 32" Wing rdjay Foamies (Scratchbuilt) 1087 Oct 11, 2015 04:03 PM
Build Log Scratchbuild kFm4 wing called The Pakpak RCSquale Flying Wings 20 May 06, 2011 10:28 AM
Discussion SpaFFFnutz 48" KFm4 Flying Wing - Electric FFF/Coroplast Hybrid jackerbes SPAD - Simple Plastic Airplane Designs 10 Nov 25, 2009 02:41 PM
Help! FPV placement RFI etc (scratchbuilt FPV model) boopidoo FPV Talk 4 Oct 14, 2009 04:28 PM
