Old Sep 15, 2003, 03:01 PM
crashbuilder is offline
Find More Posts by crashbuilder
Barbados
Joined Sep 2003
Ace foam wings
Hi there, Im in the process of building a 50 slope plane .... should be completed next week or so. Ive designed it my self and really enjoyed the process, but Im starting to wonder if it will fly ........ hence the name. The question is are ace foam wings suitable for slope planes? Ive used a constant cord center section and tapered outer sections. My model will weigh about 22 - 24 oz and have a wing loading around 10oz ....... Any comments would be greatly appreciated.
crashbuilder is offline Find More Posts by crashbuilder
Old Sep 15, 2003, 03:57 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Anything will fly on the slope, given enough wind. I'm unfortunately not familiar with what Ace foam wings are, but I suppose that almost anything that's properly balanced with a 10oz./sq.ft. wingloading will fly in a decent breeze at a good slope.
Of course, I could be wrong! Good luck!
Steve
surfimp is offline Find More Posts by surfimp
Old Jan 25, 2005, 06:31 PM
steelhead is offline
Find More Posts by steelhead
TROUT OR THERMALS
steelhead's Avatar
Eureka, Ca
Joined Sep 2002
So? How did the test go?
The ACE FOAM WINGS are really thick for non powered flight, but should work.
Dean
steelhead is offline Find More Posts by steelhead
Old Jan 25, 2005, 07:05 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
There was a little slope plane published in RCM magazine a few years ago that was built around a pair of ace foam wings.
The airfoil is not really ideal for slope, but it didn't seem to bother the guy who designed the sloper that used them. He said the plane flew very well.
Brian Courtice is offline Find More Posts by Brian Courtice
Old Feb 05, 2005, 02:25 PM
TROUT OR THERMALS
steelhead's Avatar
Eureka, Ca
Joined Sep 2002
Any idea what palne that was?
Dean
Old Feb 05, 2005, 03:21 PM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
I took an old Ace 'Mach None' kit (back when it was new ) and blocked in the nose and made it a sloper. It used the tapered foam wings Ace used to make. Flew pretty well but took a lot of wind considering the weight. Don't recall the wing loading, but it wasn't outrageously high.
Nauga,
Semper Gumby
nauga is offline Find More Posts by nauga
Old Feb 05, 2005, 09:35 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
One of my friends and me used to put that constant chord section added to the tapered ones of a ACE Mach None, and thay flew pretty good at the slope. But thinking back, there should have been more mods; bigger tail, or stretched tail moment, and some dihedral would have been good.
If the wing was vacuum bagged after the TE was added, it'd probably kick some arse.
The foil is fairly thick, but the camber is low. Should do very well inverted.
Have fun,
Target
target is offline Find More Posts by target
Old Feb 05, 2005, 10:58 PM
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
Y'know, now that you mention it, I think I stuck in a constant chord center section too. I still have a couple of boxes of the wings laying around somewhere, if they survived the move.
Nauga,
living in the past.
Old Feb 05, 2005, 11:32 PM
Radioguy is offline
Find More Posts by Radioguy
Winnipeg Intl, Canada
Joined Mar 2002
About 20 years ago I had an Aero Commander which used a constant chord center section with two tapered sections with ailerons. It was made for 2 .049's and lightweight RC but I never flew it under power.
On the slope it was a lot of fun in moderate conditions and was quite robust too.
Here are some pix of the real thing and you can see how it lends itself to the PSS style of sloper. I always thought the best version of this would the turbine AC690 rather than the piston ones shown here.
Lee
Radioguy is offline Find More Posts by Radioguy
Old Feb 06, 2005, 12:22 AM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
Yeah, that Commander is kewl! Didn't ericm do a Commander last year? I know his current projects are the Piper Cheyenne and the A-26 Invader. I'm mostly a warbird guy, but after seeing some of the stuff he's done recently, I may have to start looking a little closer at some of those civilian planes.
BTW, in that first picture, it looks like the guy is flying on one prop.
Russ.
slopeiron is offline Find More Posts by slopeiron
Old Feb 06, 2005, 03:59 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Nauga,
Semper Gumby
I built a coupla Mach None slopers and thought they were great with the stock wings. They were my first "hi performance" planes...then i made a pilgrimage to Pt. Fermin and left with my tail between my legs and my head spinning.
stu
1000MPH is offline Find More Posts by 1000MPH
NIB Ace foam wings mickydee Aircraft - Electric - Airplanes (FS/W) 2 Oct 29, 2002 03:47 PM
Ace Foam Wings - NIB SchiessCo Aircraft - Electric - Airplanes (FS/W) 7 Oct 07, 2002 11:23 AM
Ace Foam Wings Yukonho Foamies (Kits) 5 Feb 27, 2002 10:23 PM
Ace foam wings?? raythomas High Performance 5 Feb 15, 2002 06:58 PM
ACE Foam Wings NIB btompkins Aircraft - Electric - Airplanes (FS/W) 0 Jan 25, 2002 05:35 AM
