Old Sep 22, 2011, 09:25 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Alert
Stumax SM80-45, SM89-45 and SM100-45 rotor issue
Hi guys, I'm still in lovely China but still somewhat in touch with the rest of the world. I've just received a few emails detailing rotor blowups, one with an SM80-45 running very high power, and SM89-45 runing very high power and one with an SM89-45 running normal power. The SM80-45 rotor blades have rubbed inside the shroud and failed. Without being able to see the remains of the SM89-45's first hand I can't be sure what's happened but it's enough to make me worried that it's going to happen again. One of the SM89-45 failures could have been due to the fan mounts being out of alignment, causing distortion of the shroud, even with the mounting grommets, the wide spacing of the mounts will aggravate any misalignment, but it could also have been due to excessive blade stretch.
I have had two batches of rotor blades moulded for me, the second batch seems to be the one causing the problems. What I've noticed is the blades become a little bit more flexible over time. This is normal for Nylon, as it is pre-dried before it's moulded, and moisture content affects stiffness, but also it's brittleness - less moisture means it's more brittle. In the old days we used to boil Nylon props in a pot of water before use but modern Nylon formulations are supposed to normalise a lot quicker in the atmosphere. This could be allowing them to stretch a bit more and possibly strike the shroud. I do set a generous tip clearance to allow for stretching at big power levels, but if the material is getting more flexible then it may not be enough. BTW, I can't use high stiffness materials such as carbon reinforced Nylon as FOD with these narrow blades would be a serious issue. I am currently experimenting with a special higher modulus long glass fibre reinforced Nylon designed for high impact strength but it's not ready for release yet, if it turns out to be OK then I'll offer a free rotor upgrade.
Without my records here to check, I can't be sure who's fans may be at risk, but as it's the second batch of blades I would say that any SM89-45, SM100-45 or SM80-45 fans purchased from about May onwards would be from this batch. Both failures have been early in the fan's life, so I'd say if you've been flying for some time without issue then it's going to be fine.
What's the fix? If you're confident enough you can fold some 80 grit sandpaper over itself enough times to take up the tip clearance in the rotor and increase the clearance by about 0.5mm. If you're not confident enough to do that, please send your rotor to me and I'll fix it for you and return it at my expense. I'm very sorry about any inconvenience caused, and I may be over reacting, but without any more evidence at this stage I can't let people risk their models or worse while I wait to see what else may happen.
Stu.
stumax is offline Find More Posts by stumax
Old Sep 23, 2011, 02:27 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
mighty BIG of you ...that is some great customer service ,and a safe thing to do .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Sep 23, 2011, 05:21 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I've noticed a bit of rubbing on my 89-45, but it's limited to only a 10-15 degree section of the shroud. I assumed that's more an un-centered motor. Hasn't seemed to affect it at all - at only 2.5-3kw, is this considered a 'safe' level?
I'm happy to turn it down myself, but would prefer not to increase the tip gap beyond what's absolutely necessary...
Odysis is offline Find More Posts by Odysis
Old Sep 23, 2011, 05:42 AM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
I had this happen on my 100mm fan on 11S and turning down the tips 0.5mm was easy to do and has made no difference in the performance. Great support from Stu!!
strictlyscale is offline Find More Posts by strictlyscale
Old Sep 23, 2011, 06:39 AM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
This explains why I need to order a StuMax setup for my next big bird. Excellent Customer Service.
kydawg1 is offline Find More Posts by kydawg1
Old Sep 23, 2011, 10:45 AM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Thanks for the heads up, Stu!
JimDrew is online now Find More Posts by JimDrew
Old Sep 23, 2011, 11:22 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
absolutely, 100% +1. how many other manufacturers would do this? most would wait to take action, or be forced into action after a gripe thread on a forum such as this. Stu seems like a class act and I'll deffinitely be looking at his stuff very soon.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 23, 2011, 12:34 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Stu you have been all about customer support from day one
This shows the kind of company you run
Love your products
Some of the very best!
Thanks bud
Ron
Ron101 is offline Find More Posts by Ron101
Old Sep 23, 2011, 12:52 PM
Steve Haynes is offline
Find More Posts by Steve Haynes
There was a crease in the plan
Steve Haynes's Avatar
Joined Jun 2010
Respect
Steve Haynes is offline Find More Posts by Steve Haynes
Old Sep 23, 2011, 03:32 PM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
Stu do you think is what happen to mine...( disappear in Post Neverland when I shipped the fan to Stu)
bidule is offline Find More Posts by bidule
Old Sep 23, 2011, 03:37 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
+1 We love you Stu!
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 23, 2011, 09:04 PM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
JC, you know I offered to replace it immediately, but I did want to see the bits to try and figure out what happened. I thought Mike was going to give you a new one at Ejets, that was our last communication. I'll get in touch with Mike and see what he says. I actually replicated your setup and was getting over 4.5kW, which is more than I set tip clearance for (bcause that's a crazy amount of power to put in a 90mm fan), so I think yours was probably a combination of too much power and not enough tip clearance, the blade material issue could also have been a contributing factor. When I get home I'll get in touch with the post office and try to find where the parcel has gone, can you email me a tracking number please? Also, let me know what motor you'd like to replace the old one with as I think that one was too hot.
One thing I'm considering is to make an all carbon rotor and offer an upgade to existing customers for small price, probably $60-70 as there will be quite a bit of work in making them. As we've seen from the original blades, if the material is moisture stabilised the way it should be (the parts are supposed to be steamed prior to packaging) then they are fine, I actually tested the 89-45 up to 5kW and the 100-45 to 7.5kW without issue, so an all carbon rotor is a luxury, not a necessity, the only real benefit from it (apart from its appearance having extreme woody value) is the power can probably increase to totally crazy levels, if you are totally crazy, of course
Thanks for your support guys, this is a tough situation to resolve, there are a lot of rotors out there for me to replace/fix, that's gonna have quite an impact on production but it's go to be done.
Stu.
Old Sep 23, 2011, 09:27 PM
Joined Jan 2009
hopefully it doesn't have an impact on your business. we'de hate to lose you over a major recall. we don't have enough choice as it is in high end fans. to lose Stumax because of financial troubles would be a major blow. let's hope that this situation is small and that you are indeed blowing it a bit out of proprtion........if that's what you can call it. I'm sure you know what I mean though.
Rich
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
Great support Stu!
Stu you have bent over backwards for me in the past with great service with the special inlet duct and the crashed fan. Heck you even gave me better service then the last time I sent my EVF back to BVM. To beat out BVM in service is freaking great!! Keep up the great work Stu!
gunradd is offline Find More Posts by gunradd
Old Sep 23, 2011, 09:28 PM
Joined Jan 2009
by the way, we really need an outlet in Canada. can we get something going? paying import duty from the States is lousy.
Discussion The new Stumax 80mm fan - SM80-45 stumax Electric Ducted Fan Jet Talk 160 Jan 15, 2016 08:58 AM
Sold Stumax SM 89-45 fan goforit Aircraft - Electric - Jets (FS/W) 1 Sep 21, 2011 07:36 PM
For Sale K&A F100 - Stumax SM90-45 - NEU1515-3D sbritton Aircraft - Electric - Jets (FS/W) 22 Jun 20, 2011 10:35 PM
Discussion Anyone put a SM89-45 in a Habu 32? Mavpoint Electric Ducted Fan Jet Talk 0 May 15, 2011 12:14 PM
Video SM100-45 EDF unit test run stumax Electric Plane Talk 12 Jan 17, 2011 06:59 PM
