I'm guessing that the transmitter is actually a Spektrum DX3e, which is a surface radio compatible with DSM and DSM2 but not DSMX. It's also compatible with marine protocol, which may add a further complication. The AR600 is a DSMX receiver but should be backward compatible with the DSM2 transmitter.
The DX3e does not have model memories so all of the receivers are binding to the same ID number. For its part during binding, the transmitter learns what kind of protocol the receiver uses (DSM or DSM2). Not sure what happens when it encounters a DSMX receiver. I would have thought it just went into DSM2 mode (the default) but maybe there's more to it than that. I know for sure that there is no problem binding more than one receiver to a DSM2 transmitter (or model memory). But that may not apply to the surface transmitters if the receivers are of different types. And I haven't heard of anyone trying it with DSMX receivers. I assume you can bind two Orange receivers (DSM2) without problems. No definitive answer but some interesting questions. |
Latest blog entry: Polaris Aileron Pushrods
Binding is just the RX learning the TX code, if you are following the bind procedure properly they should all bind.
If its still fails I would try what was post about binding them at once. If that also fails I think its time for you to invest in the DX6i or higher tx. |
Latest blog entry: Get Help by posting your SPM File
Receiver does the BINDING learning, they all can learn the same model memory. I know this from experience. The only reason my early post was not 100% accurate was because I simply assumed his DX5e was DSM2 only and never put 2 & 2 together when he posted having AR600 which is DSMX. BUT with that aside if all your system is DSM2 you can infact bind multiple receivers to one radio and infact one model memory but of course this defeats the purpose of model match and is not recommended. |
As long as all the receivers are DSM2, you can bind as many as you want. What we are discussing here is what happens when the transmitter discovers that it's not dealing with a DSM2 but a DSMX receiver (AR600). It immediately forgets about the DSM2s and hence won't work with them. EDIT: Never mind. Freechip covered it. I should read the other responses before commenting.
| Thread Tools | |
| Question Binding after RX Firmware Update | Highfly! | Hitec/Multiplex USA | 1 | Sep 03, 2011 01:54 AM |
| Discussion What Causes Loss of Binding ? | E-Challenged | Hitec/Multiplex USA | 1 | Jun 22, 2011 03:10 PM |
| Sold Sale/trade NIP MX Microlite 6 channel Spektrum DSM2 rx made after ar6110e w bind plug | blueindian | Aircraft - Electric - Helis (FS/W) | 1 | Nov 25, 2010 07:52 AM |
| Discussion How do you tell the diff. b/w Failure to bind(Rx can't Connect) and Loss of bind? | Fly2High | Radios | 19 | May 19, 2010 06:24 AM |
| Help! DX7 loosing bind with Rx's after 2 months of non use..... | stuart warne | Radios | 29 | Feb 01, 2009 09:52 AM |
