Old Mar 18, 2012, 06:18 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
Originally Posted by pete_g View Post
Can anyone that has landing gear installed and zero problems care to elaborate on their setup?
These people exist? Without a mix in the radio? I'd like to hear from them too!
Also some tips on thrust angle adjustments from people in the know on that kind of stuff would be nice.
StormJunkie is offline Find More Posts by StormJunkie
Old Mar 18, 2012, 07:52 PM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
Just some random thoughts and I could be all wet. For you guys that have it climb when inverted, are you using Gens Ace 1300s? I'm using that lipo and was having the similar issue. The 1300 is a pretty tall pack and I was wondering if it was causing a lot of air resistance. I was thinking maybe it was trimmed out for upright flight but the resistance was causing it to pitch up when inverted. My whole CG changed when I added lights but at the same time I added a bit of EPP that was sloped in front of the battery to help the air flow around the pack. I'm balanced at the same spot I was before and now I have no issues and the nose drops just a touch when inverted.
Now I don't know if the piece of foam helped at all or just the change in position of the pack after the lights were added made the difference but something changed. I just thought I'd throw it out there to see what anyone else thought or if you tried different packs and got different results.
gremlin is offline Find More Posts by gremlin
Old Mar 18, 2012, 08:32 PM
Whoooo!
Summerville, SC
Joined Jan 2009
What about KE?
Old Mar 18, 2012, 08:49 PM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
It will need a touch of KE mixing but nothing dramtic. I keep flying KE and saying "I have to mix a bit of this and a touch of that" but then start having so much fun with this plane that by the time I land I forget what I had to change. Some day I'm going to have to have someone take notes for me so I can remember what to mix.
Old Mar 18, 2012, 09:17 PM
four stroke pwr is offline
Find More Posts by four stroke pwr
Sky Pilot
four stroke pwr's Avatar
United States, FL, Orlando
Joined Feb 2004
I agree.. I don't like mixing to correct KE issues. I like to do it all manually to "fly" with my own feel . If you fly this bird enough, it becomes instinctive... you know how much to add (and with those surfaces, it doesn't take much throw!).
four stroke pwr is offline Find More Posts by four stroke pwr
Old Mar 19, 2012, 07:49 AM
kellyzo6 is offline
Find More Posts by kellyzo6
kellyzo6's Avatar
United States, VA, Berryville
Joined May 2010
I have the Gens Ace 1300 and fly slightly nose heavy so it won't climb while inverted. Also while in KE it will fly towards the canopy.
kellyzo6 is offline Find More Posts by kellyzo6
Old Mar 19, 2012, 08:38 AM
Whoooo!
Summerville, SC
Joined Jan 2009
This means something is NOT right with the CG or thrust angle...With so many having the issue, I have a feeling this is a thrust angle issue.
Old Mar 19, 2012, 09:13 AM
kellyzo6 is offline
kellyzo6's Avatar
Joined May 2010
That could be possible with mine, I have ripped out the firewall on more than one occasion
Old Mar 19, 2012, 09:21 AM
Whoooo!
Summerville, SC
Joined Jan 2009
This is a problem with new builds too Kelly, so your firewall rebuilds may be just fine.
And it seems the issue is consistent...Either it fly's level and will KE with very minor coupling, but will balloon inverted, OR it will fly level inverted & level, but will couple hard to canopy in KE.
Where are all the thrust angle experts?
Old Mar 19, 2012, 09:37 AM
kellyzo6 is offline
kellyzo6's Avatar
Joined May 2010
Part of me understands that it is a foamy and won't be as precise as a balsa. I have lots to learn.
Old Mar 30, 2012, 03:58 PM
Ola. is offline
Find More Posts by Ola.
Joined Feb 2011
The one thing i dont like about my 38", is how bad it stalls out inverted... Upright i can do whatever i want.. Inverted slow speed, i have to be geeeeentle on the down elevator.. It flicks immediately.. Inverted harriera are a paain to do.
And ive tried cg from 2,5" - 5"...
Sendt from my Galaxy SII..
Ola. is offline Find More Posts by Ola.
Old Mar 30, 2012, 10:47 PM
Whoooo!
Summerville, SC
Joined Jan 2009
Still believe this is a thrust angle issue...Just wish I knew enough about thrust angle to provide some insight.
Old Apr 04, 2012, 07:37 PM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
I have a Thunder Power 1350 on mine. Climbs when inverted even with the battery way back... Where are you guys mounting your batteries on the planes that aren't climbing inverted? And how far back is the CG?
STLAV8R is offline Find More Posts by STLAV8R
Old Apr 05, 2012, 05:06 AM
Whoooo!
Summerville, SC
Joined Jan 2009
In order to prevent climbing, inverted or not...You would want to move the battery forward. problem is that you have to start compensating with some trim.
I need to send my motor back to Ken for some repairs I think, but when I get it back...I'm going to start playing with some washers under the mount and see if adjusting the thrust angle helps at all. I have no clue what I'm doing, but maybe I'll get lucky...
Old Apr 05, 2012, 10:38 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Yall should try running a lighter setup. Foamys light to be as light as possible. I fly with a smallish torque I got from 3DHS(tent sale), and a 1000 3s. My battery is probably back a little to far but it flies pretty neutral.
robj is offline Find More Posts by robj
New Product 3D Hobby Shop 34" EDGE EPP joesmith285 3D Foamies 1200 Jul 26, 2014 07:22 AM
Sold 3D Hobby Shop 51" AJ Slick - RTF 6L6Amp Aircraft - Electric - Airplanes (FS/W) 0 Aug 15, 2011 05:54 PM
Wanted 3D Hobby Shop 89" Slick PinkYakRC Aircraft - Electric - Airplanes (FS/W) 4 Jun 29, 2011 10:09 PM
For Sale 3D Hobby Shop 70" Slick davidsons Aircraft - Electric - Airplanes (FS/W) 5 Jun 09, 2011 10:39 AM
