Old Feb 17, 2012, 08:05 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
See pic here
fltekdiver is offline Find More Posts by fltekdiver
Old Feb 17, 2012, 08:14 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
Originally Posted by fltekdiver View Post
yes, I picked the hindge side, since the other was bellved
Im trying to mount the hacket motor, but the shaft is sticking out the rear of the motor, instead of the front , how do I mount the prop etc onto the shaft like this?
You don't as far as I know. There should be a way to slide the shaft forward...Set screws and clips maybe?
StormJunkie is offline Find More Posts by StormJunkie
Old Feb 17, 2012, 08:15 PM
Joined Jan 2010
10/4, got it, I just used a socket, put it over the shaft, and hit it gentley with a hammer, and the shaft slide right through to the other side, thanks !
Old Feb 17, 2012, 11:55 PM
crawlspace is offline
Find More Posts by crawlspace
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
Originally Posted by StormJunkie View Post
Ok, so you did not center the rudder but actually put it to the hinge side? Thought about that but really didn't want the offset rudder. If they would just cut this thing out of the thicker foam, it would bake life so much easier
Crawl, do you fly a perfectly neutral CG? No KE coupling, etc? And if so, where is your batter placed in respect to the carbon wing spar? Thanks, appreciate the help!
The rudder is hinged centered, but the bottom part gets pulled over when the welder dries so it looks offset on mine. We're only talking a 1/16" even if it isn't, hardly something you'll notice on a foam plane.
The center of the pack is 3/8" behind the spar on mine with the gear on. I have the CG back a little, it harriers and hovers much better this way. moving the battery 1/8" actually makes a difference with mine and that is where it really shows. If it's a bit forward the plane requires more speed to fly, especially in KE and is hard to lock in the hover so you'll know right away if it needs to be moved back a little. I started with the pack against the gear legs and have been progressively moving it back a little because most of the repairs have been in front of the battery, now it's about 3/8" aft of that. In KE it couples a little bit to the gear but that's probably a trim issue.
crawlspace is offline Find More Posts by crawlspace
Old Feb 18, 2012, 07:52 AM
Whoooo!
Summerville, SC
Joined Jan 2009
Thanks!
I'll put a little extra velcro on there so I can move it around a little. Would love to be able to get it to harrier and hover in a neutral position if I can, but sounds like you haven't had much success with that.
Also just measure my rudder and I've got a hair over a .1" on each side, so sliding it over to the hinge would leave just over .2" on the one side. May try sliding it over if I build another one at some point, but really like to keep everything centered. Agree that coupling is usually a trim issue, but it's possible that the slide over on the hinge is causing it too.
Old Feb 18, 2012, 10:33 AM
Joined Jan 2010
Carbon fiber flat pcs on the bottom, getting their !
On the ALIE control arms I'm going to the hobby store now to buy 3" pcs of thread rods, and doing it that way instead
Old Feb 18, 2012, 10:48 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Flat carbon on the keel seems like a good idea. Gotta be careful not to weigh the bird down too much, though.
BryanEW710 is offline Find More Posts by BryanEW710
Old Feb 18, 2012, 10:51 AM
Joined Jan 2010
Yeh, with all that little power the Hacker A20 has, I may not even get off the ground
Old Feb 18, 2012, 10:59 AM
Whoooo!
Summerville, SC
Joined Jan 2009
Yeah, think this bird has plenty of room for a little more weight with the A20 or the motorfly 2215-1150
Threaded rods are not a bad idea...I think I might try a short piece of CF rod though and see if I can run it the same system as the rudder & elev. Have the CF here so won't hurt to try. Also have a few pieces of music wire where I didn't get both bends on the exact same plane so will let you know how that goes.
I also used a larger piece of hollow CF for the rudder and elev and am going to skip the little supports...
Old Feb 18, 2012, 11:21 AM
Joined Jan 2010
Reason I may go with threaded rod, is so you can adjust the servo travel just like you would on the bigger planes
Problem is, weight
Your now adding 2 pcs of 3" thread rod, and clevis
So Im going to see what they weigh on the scale now vs, the carbon fiber with the Z bend music wire
Old Feb 18, 2012, 11:39 AM
Whoooo!
Summerville, SC
Joined Jan 2009
I really don't think weight will bea prkb with this plane. unless of course you add a lead weight
Old Feb 18, 2012, 12:05 PM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
What is the weight coming in at ready-to-fly minus the battery?
Curious how mine compares. Built it 100% stock....
STLAV8R is offline Find More Posts by STLAV8R
Old Feb 18, 2012, 12:22 PM
Whoooo!
Summerville, SC
Joined Jan 2009
Would like to know myself...although I have no way of weighing mine.
Old Feb 18, 2012, 01:30 PM
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
Thanks!
If it were the rudder causing it then it would couple the opposite way in KE on the other side and it doesn't. I initially suspected down thrust angle since there is no self alignment when you glue the motor mount on but changing it didn't seem to make much difference. A little more experimentation is in order of I want to eliminate it completely but I don't have a problem flying it the way it is.
Old Feb 18, 2012, 08:07 PM
Joined Jan 2010
Not sure on the weight, I just tried to weigh it, and I have a UPS scale, so in ouncs its not that accurate
I also went with Gen Ace 1000mah, vs the 1,300mah, so it should come in around the stock set up
New Product 3D Hobby Shop 34" EDGE EPP joesmith285 3D Foamies 1200 Jul 26, 2014 07:22 AM
Sold 3D Hobby Shop 51" AJ Slick - RTF 6L6Amp Aircraft - Electric - Airplanes (FS/W) 0 Aug 15, 2011 05:54 PM
Wanted 3D Hobby Shop 89" Slick PinkYakRC Aircraft - Electric - Airplanes (FS/W) 4 Jun 29, 2011 10:09 PM
For Sale 3D Hobby Shop 70" Slick davidsons Aircraft - Electric - Airplanes (FS/W) 5 Jun 09, 2011 10:39 AM
