Old Jan 14, 2012, 04:06 PM
crawlspace is offline
Find More Posts by crawlspace
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
Originally Posted by Ola. View Post
I got through another 3 battery`s (and another prop lol) today, and my cg seems better now.. It`s falling just alittle on inverted now, so it`s much better to fly. Still kinda twitchy in hover, but its getting there.
But i feel it couples _alot_ in KE circles.. but i might be expecting to much of it
Gotta get used to it first i guess
After flying it a few dozen times and adjusting the battery around I have found proper CG to be the key. If the model is twitchy in hover, move the battery back about 1/4" at a time until level flight at 50% throttle is achieved both upright and inverted. This model doesn't fly very well if it's nose heavy.
The coupling in KE is most likely a byproduct of a bad thrust angle in the motor. This wasn't covered in the instructions and can vary depending on how the foam block in the nose is glued in. Your model most likely has a small amount of down thrust that is causing coupling to the gear (if it flies like mine did at first). Fly your model straight up full power hands off and see where it goes. If it goes straight up then your thrust angles are correct, if not then they need to be adjusted. This is assuming you have trimmed it for level/straight flight as mentioned above.
crawlspace is offline Find More Posts by crawlspace
Old Feb 01, 2012, 06:56 PM
four stroke pwr is offline
Find More Posts by four stroke pwr
Sky Pilot
four stroke pwr's Avatar
United States, FL, Orlando
Joined Feb 2004
Love this plane!
four stroke pwr is offline Find More Posts by four stroke pwr
Old Feb 01, 2012, 07:37 PM
3Dplank is online now
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Got 4 batteries through mine today rolling all day long
3Dplank is online now Find More Posts by 3Dplank
Old Feb 01, 2012, 08:40 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Is this the newest EPP from 3DHS out?
I been outta EPP planes for the past year now, and wanted to buy another one , instead of using the SIM
I'll be flying out doors all the time, no In-door gym's around here
Anyone have a good starting point for outdoor flying, motor etc?
I looked up the hacker, but man, $99.00 for the Motor/ESC ?
So I'm assuming you have about $350.00 into it RTF ?
fltekdiver is offline Find More Posts by fltekdiver
Old Feb 01, 2012, 08:56 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
Sub-friggin-scribed and a soon to be owner!!!
I think if they made a Slick out of bricks it would somehow still be awesome...lol
StormJunkie is offline Find More Posts by StormJunkie
Old Feb 01, 2012, 08:57 PM
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
I run hobbyking stuff in my epps
Old Feb 01, 2012, 08:58 PM
Joined Jan 2010
10/4, thats what I used to run in Mine, what set up you using for your Slick?
Old Feb 01, 2012, 09:06 PM
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
D2830-11 1000kv Brushless Motor, 40 amp plush esc, and 4 hk939mg servos. Been good so far
Joined Jan 2010
Just put my order in with 2 tubes of Welders, Can't wait to start building it
Old Feb 01, 2012, 09:07 PM
Joined Jan 2010
Perfect, thanks !
Old Feb 03, 2012, 07:48 PM
Whoooo!
Summerville, SC
Joined Jan 2009
What's the major differences between the two recommended Hacker motors? Thx!
Old Feb 03, 2012, 07:53 PM
Joined Jan 2010
What can I expect for the build time? I've flown 3DHS 72" Slicks, 59" , & 51" Slicks, and can build a 51" in about 4 hours
What can I expect on the foamie ?
Old Feb 03, 2012, 08:05 PM
Whoooo!
Summerville, SC
Joined Jan 2009
I've never build an EPP before. I just started looking over the manual and am watching the 33" build videos now. I'd say it'll take me about 8hrs over a couple days. But no worries, it'll be a great throw in the trunk fly anywhere plane when it's done!
Old Feb 04, 2012, 02:01 PM
pete_g is offline
Find More Posts by pete_g
Joined Aug 2009
glue and building
Just got my EPP and starting the build. I'm starting to run out of Welders. Only got 1 tube thinking it would be good. Missed the part about 1.5 tubes in the manual.
Would LePage Stik'n Seal work? I can't locate Welder's locally here in Canada. I've heard it's almost the same. All hinges and main wing carbon and elevator are done with welders. I would have enough to put the bottom fuselage and maybe top. Anyone else use LePage?
pete_g is offline Find More Posts by pete_g
Old Feb 04, 2012, 02:05 PM
Joined Jan 2010
Do they have a Lowes dept store in Canada< its like a Home Depot ? Cause they sell it
New Product 3D Hobby Shop 34" EDGE EPP joesmith285 3D Foamies 1200 Jul 26, 2014 07:22 AM
Sold 3D Hobby Shop 51" AJ Slick - RTF 6L6Amp Aircraft - Electric - Airplanes (FS/W) 0 Aug 15, 2011 05:54 PM
Wanted 3D Hobby Shop 89" Slick PinkYakRC Aircraft - Electric - Airplanes (FS/W) 4 Jun 29, 2011 10:09 PM
For Sale 3D Hobby Shop 70" Slick davidsons Aircraft - Electric - Airplanes (FS/W) 5 Jun 09, 2011 10:39 AM
