Old Dec 30, 2011, 03:00 PM
United States, VA, Berryville
Joined May 2010
I am using the Geans Ace 1300 and put the pack behind landing gear and in front of the first wing support. If i wanted to move the CG any foward I will shorten up linkage in the alileron. Rite now it seem good.
kellyzo6 is offline Find More Posts by kellyzo6
Old Dec 30, 2011, 03:05 PM
Joined May 2010
I havent added any trim but I broke my last prop and LHS don't have any more. I'll let you know after I get a few more flights on her. Good luck and Happy New Year
Old Dec 30, 2011, 04:39 PM
Joe's Dad and pit crew
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Milled Slick with Radio view. Windy day.
3DHS 38 EPP MILLED SLICK WITH RADIO VIEW pilot Joe Smith (2 min 17 sec)
jsmith285 is online now Find More Posts by jsmith285
Old Dec 30, 2011, 05:04 PM
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Wow...feel like I could learn something from watching your stickwork!
BryanEW710 is offline Find More Posts by BryanEW710
Old Dec 31, 2011, 09:38 AM
Joined Feb 2011
I got through another 3 battery`s (and another prop lol) today, and my cg seems better now.. It`s falling just alittle on inverted now, so it`s much better to fly. Still kinda twitchy in hover, but its getting there.
But i feel it couples _alot_ in KE circles.. but i might be expecting to much of it
Gotta get used to it first i guess
Ola. is online now Find More Posts by Ola.
Old Dec 31, 2011, 01:50 PM
United States, NY, Wyoming
Joined Apr 2011
I have a question if someone could take a minute to help please. I'm at the point in the build where you attach the rudder. Mine is a lot thinner than the thickness of the fuse. If I shift it the the edge like the build shows I will have a big gap on one side. Am I missing something simple?
starwarsfan is offline Find More Posts by starwarsfan
Old Dec 31, 2011, 04:16 PM
racerman27410's Avatar
United States, NC, Greensboro
Joined Dec 2006
center the rudder stab on the fuse..... mount it using foam safe CA
then make a fillet with welders on both sides
racerman27410 is offline Find More Posts by racerman27410
Old Dec 31, 2011, 05:12 PM
Joined Apr 2011
Old Jan 03, 2012, 11:46 AM
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I did this just like the instructions, micro checked it and it dog walked all over. Rudder trimmed several degrees to get it to track straight. Something was off but you couldn't spot where. Finally cut it off and just lined it up to the left side all the way down, new plane! Still wonder why the rudder isn't the same thickness as the fuse, but mine flys straight now.
Just double, triple, check.
robj is offline Find More Posts by robj
Latest blog entry: Well...
Old Jan 06, 2012, 07:29 PM
Sky Pilot
four stroke pwr's Avatar
United States, FL, Orlando
Joined Feb 2004
"center the rudder stab on the fuse..... mount it using foam safe CA"
No, do not use foam safe CA, use regular CA. Foam safe CA will be weak. Read the instructions from the beginning. They state use regular CA.
four stroke pwr is offline Find More Posts by four stroke pwr
Old Jan 07, 2012, 12:46 PM
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
(Warning I can not fly like jsmith) huckin around
3dhs jan 7th (5 min 16 sec)
3Dplank is offline Find More Posts by 3Dplank
Old Jan 10, 2012, 08:10 PM
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
Regarding thr rudder installation, I chose to mount mine to the top half of the fuse before I glued the top fuse on. This made it easier to get centered and handle while gluing.
I really like how this plane flies. It harriers well, hovers nicely, floats in high alpha knife edge and makes for a great 3D trainer. The only thing I have a problem with is it rolls out of tight outside loops. Im using a 2215 900kv motor from HK spinning a 10x4.7 prop which is equivalent in specs and weight as the hacker 20-20L (70g). With a 1300mah pack weighing 110g it will fly upright and inverted hands off at half throttle with the pack about 1/2" behind the landing gear legs. I have some 97g 1000mah nano-tech packs coming that should balance well up right up against the gear legs. I shaved over 18g using Futaba S3114 servos instead of HS-65MGs and am using an AXI prop saver instead of a collet which shaves another 7g (and has already saved the prop from a few unscheduled inverted landings), this makes my dry weight 12.67oz. Even though the plane's AUW is over 16.5 oz I'm still getting aggressive 3D flights of 7 minutes and only using .7A (about 50% capacity of the 1300s).
crawlspace is offline Find More Posts by crawlspace
Old Jan 11, 2012, 06:57 AM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Milled Slick indoors
3DHS 38 EPP Slick Milled Indoors pilot Joe Smith (4 min 48 sec)
Old Jan 13, 2012, 05:18 PM
United States, CA, Fresno
Joined Jul 2011
Pull-Pull Rudder
Hey JSmith, was curious to find out how well you felt rudder held on this model. Just got my epp slick in the mail today and was thinking of doing the Pull-pull rudder mod that AJ shows on his HPP Vid volume 1. What do you think.
gcollective is offline Find More Posts by gcollective
Old Jan 13, 2012, 06:09 PM
BryanEW710's Avatar
Joined Sep 2010
Your ability to do rolling harriers from almost any attitude amazes me. Bravo, man, bravo
New Product 3D Hobby Shop 34" EDGE EPP joesmith285 3D Foamies 1186 Dec 30, 2012 06:32 PM
Sold 3D Hobby Shop 51" AJ Slick - RTF 6L6Amp Aircraft - Electric - Airplanes (FS/W) 0 Aug 15, 2011 05:54 PM
Wanted 3D Hobby Shop 89" Slick PinkYakRC Aircraft - Electric - Airplanes (FS/W) 4 Jun 29, 2011 10:09 PM
For Sale 3D Hobby Shop 70" Slick davidsons Aircraft - Electric - Airplanes (FS/W) 5 Jun 09, 2011 10:39 AM
