Old Dec 27, 2011, 10:17 AM
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by 3171scott View Post
What do you like beter over the Edge? Because realy they are miles apart in design? Its bigger and heaver with more power. Should be way beter outdoors in windy conditions, but that is to be expected. I have oth the Extra and Edge a.d love them both. They do fly different but love them.
Only asking because im realy thinking of geting on.
thanks for the info.
For me it just flys more like a larger balsa plane. It harriers like my 51 except a lot slower. You feel the lighter weight for sure.
robj is offline Find More Posts by robj
Latest blog entry: Well...
Old Dec 29, 2011, 01:04 AM
NeverEnough's Avatar
USA, AZ, Phoenix
Joined Nov 2009
The Slick flies more precise and doesn't have as much coupling in KE. Don't get me wrong, I still like the Edge. It's a 3D beast.
NeverEnough is offline Find More Posts by NeverEnough
Old Dec 29, 2011, 04:06 AM
Joined Feb 2011
Just got my 38" kit with hacker motor/esc
I spent alot of hours in the fumes of welders glue yesterday, but i got it done in one day
Really a nice epp i must say!
Charging 5 1050mah' s right now, and then its maiden next
Ola. is offline Find More Posts by Ola.
Old Dec 29, 2011, 06:39 AM
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Your gonna enjoy it
3Dplank is offline Find More Posts by 3Dplank
Old Dec 29, 2011, 08:43 AM
United States, VA, Berryville
Joined May 2010
Its my 3rd day bulding, having to wait for the Weilders to dry. I think being cold in my house makes Weilders set up time longer.
kellyzo6 is offline Find More Posts by kellyzo6
Old Dec 29, 2011, 09:22 AM
Joined Feb 2011
I almost got through 2 batteries before i hit a tree doing high speed KE circles lol
Thats when i realised i only had 1 prop for it So i ordered 8 more now hehe..
I need to move my battery though.. It was way to heavy up front with my 3s 1050mah rhino 40C..
Old Dec 29, 2011, 09:41 AM
Joined Feb 2011
I did mine in a 17` C temp`d room, and welders was pretty quick to dry..
The big amount under the wing servo`s took alittle more time though.. 3-4 hours or so..
Old Dec 29, 2011, 12:19 PM
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
thanks for the imput! Just picked up a Depron Velox so might wait till spring to get the epp slick, as of now i own all but the slick in the 3dhs foammy line... LOL...
3171scott is offline Find More Posts by 3171scott
Old Dec 30, 2011, 07:42 AM
Joined Feb 2011
Am i the only one finding this 38" to be alittle picky on cg?
I`ve probably gotta move some of the braces on the main wing, so my battery fits under them, to get the battery further back..
Setup is A20-20 , X-20 , 4x 65mg`s, and a 3c 40c 1050mah Rihno , everything built as manual say, and is total of 460 grams RTF. (fat pig, i must say)
Old Dec 30, 2011, 08:16 AM
Joined May 2010
I am having the same problem as well. Try moving esc and reciver back far as you can. What would you guys thing on shorting up the linkage thus moving the servos futher back on the wing?
Old Dec 30, 2011, 09:38 AM
Joined May 2010
Just took her out for maiden & WOW! This thing is so fun, tale touches and touque rolls.....LOL Ill get some viedo later.
Old Dec 30, 2011, 09:54 AM
Joined Feb 2011
Where is youre cg at then?
Sendt from my Galaxy SII..
Old Dec 30, 2011, 12:12 PM
Joined May 2010
I got the CG 4 1/2" behind the leading edge, the nose drops a little while inverted which is what I like. Love this plane!
Old Dec 30, 2011, 02:02 PM
United States, NY, Wyoming
Joined Apr 2011
Kelly, funny you mentioned going with shorter linkage.I'm in the process of building mine. If I make the linkage aprox. 2 3/4 after the bends I'm much further forward on the wing than the picture shows on the build guide. I did shorten mine up a bit to make it look more like the build guide picture. I'll let you know if it causes any issues. I'm Coming down the home stretch on the build so I will be ready for a test flight soon.( weather dependent )
starwarsfan is offline Find More Posts by starwarsfan
Old Dec 30, 2011, 02:56 PM
Joined Feb 2011
Man thats soo strange.
At 4.5", my climb crazy inverted... I had to move the battery behind the carbon braces, vertically mounted close to the braces, to get my 4.5"...
How heavy are you`re battery, and where does it sit?
Are you running no trimmed elevator like this?
Is it flying straight upright, or do you have to stay on the elevator to keep it level?
I gotta get this sorted out.
New Product 3D Hobby Shop 34" EDGE EPP joesmith285 3D Foamies 1186 Dec 30, 2012 06:32 PM
Sold 3D Hobby Shop 51" AJ Slick - RTF 6L6Amp Aircraft - Electric - Airplanes (FS/W) 0 Aug 15, 2011 05:54 PM
Wanted 3D Hobby Shop 89" Slick PinkYakRC Aircraft - Electric - Airplanes (FS/W) 4 Jun 29, 2011 10:09 PM
For Sale 3D Hobby Shop 70" Slick davidsons Aircraft - Electric - Airplanes (FS/W) 5 Jun 09, 2011 10:39 AM
