Old Sep 22, 2011, 06:50 PM
Steve2381 is offline
Find More Posts by Steve2381
Joined Apr 2008
Selling my Revell Gato project
I am never going to finish it!…. So its got to go.
Revell 1:72 scale US Navy Gato-class submarine kit. Partially assembled.
Conning tower is together and the deck guns have been built with fibre optic cable inside the barrels so that they could flash using leds.
All the parts are there and still on the sprigs. Decals are still bagged.
The hull has been cut to allow a WTC to fit inside.
The rudder and rear planes have been fitted and are ready to connect to your servo system.
The front planes are also fitted with tilt and retract mechanisms. Just connect to servos and you are away.
Most of the work done so far on the hull was re-shaping and converting the front 6 torpedo tubes to their correct shape and then making them open/close on a servo.
99% of the work on those as been done (I did post about this conversion last year)
I made my own clear WTC which is included, but you probably will want to either redesign or bin it.
There are 4 sections (Pump room, radio room, ballast tank and engine room). However on further consideration, I think making these sections separately has made for more work when it comes to wiring etc.
I am sure you could convert them however to whatever system you want to use.
There is a fairly intricate brass frame inside the radio and pump room.
The pump room houses a blood pressure air pump that works well. It runs on 6v.
Also included is the spare, but handy 6v air valve that came in the blood pressure unit too.
I am also selling my brilliant Robbe Futaba F-14 Navy dual throttle RC controller in perfect condition (40hmz) and its 8 channel receiver.(currently fitted inside the WTC)
Fitted into that is a Robbe Multiprop 8039 4+4 control package, giving you 4x extra sets of 3 position switches, and 4x rotary servo controls.
There is also the Robbe Multiprop 8042 decoder to match (currently fitted inside the WTC)
I also have a couple of odd Robbe relay boards that I will throw in. They don’t work directly off the receiver, so I am not sure how they work.
There are 4x mini servos fitted inside the WTC. These could be removed and re-used.
There is a 4700mAh 7.2v NiMh battery pack fitted inside the WTC (never used or charged)
I also have a brand new, never used or charged 4.2v receiver rechargeable battery pack
Also supplied are 2x never used MFA 457RE385 motors. 6-15V
A brand new Graupner V15R electronic Speed controller
A pair of expensive brass propellers (Right and left handed) I believe they are 35mm diameter.
4x High quality universal joints - new
1x 6mm brass bell detail - new
A few packs of battery connectors etc - new
4x MFA 914mm control cables in sleeves - new
2x Packs of MFA motor suppressor capacitors - new
Standard battery box and switch loom
5x Concertina style servo rod waterproofing boots
Please make an offer. The radio gear is worth a good few hundred on its own
I dread to think what I actually spent in plastic tubes, brass etc!
I might split the radio gear if the whole lot doesn't sell
Email Steve.croot@googlemail.com for any more information.
Postage to be sorted out, but its quite big so I would imagine at least 12-15 + insurance.
Thanks guys
Steve2381 is offline Find More Posts by Steve2381
Discussion Revell Gato Rc conversion complete gulgecm Submarines 3 May 28, 2011 05:14 AM
Discussion My 1/72 Revell build - Gato Class USS Cobia Steve2381 Submarines 78 Mar 25, 2010 12:41 PM
Discussion Engel Gato vs Revell Gato junglelord Submarines 3 Apr 30, 2009 02:43 PM
