Old Sep 22, 2011, 03:56 PM
ibuild is offline
Find More Posts by ibuild
closed due to popular demand
Joined Jul 2011
ibuild is offline Find More Posts by ibuild
Old Sep 22, 2011, 08:30 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Looks pretty good. That TE will by very difficult to build accurately and strong. So very thin back there.
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old Sep 22, 2011, 09:50 PM
ibuild is offline
Joined Jul 2011
Old Sep 23, 2011, 01:25 PM
ibuild is offline
Joined Jul 2011
Old Sep 23, 2011, 11:26 PM
c.walker is offline
Find More Posts by c.walker
United States, CA, Berkeley
Joined Jul 2006
Perhaps a silly question, but, for a plank, would you rather have a Cm that's constant with Re, or a Cm that's as close to zero as possible over the Re range?
c.walker is offline Find More Posts by c.walker
Old Sep 23, 2011, 11:55 PM
Just fly it!
Cody, WY
Joined Nov 2007
Both.
Old Sep 24, 2011, 09:47 AM
ibuild is offline
Joined Jul 2011
Old Sep 24, 2011, 10:10 AM
Just fly it!
Cody, WY
Joined Nov 2007
Ideally you want an airfoil that has a neutral Cm at all speeds.
The challenge is that the airfoil has to fly at different AoA at different speeds and typically still requires trim changes.
Old Sep 24, 2011, 02:41 PM
ibuild is offline
Joined Jul 2011
Old Sep 24, 2011, 03:09 PM
Just fly it!
Cody, WY
Joined Nov 2007
If the wing is flying slow the wing has to fly at the required angle of attack to generate enough lift to maintain level flight along the slope. As the wing flies faster it develops more lift and then needs to fly at a lower AoA to fly level along the slope. This is why most wings require subtle trim changes as the speed changes.
Example:
Your glider weighs 45 ounces and has a wing area of 350 square inches. Lets also say that it uses your TK Plank 1a. The MAC of this wing is 6.333"
So at 40 mph the wing needs to generate a CL of .282
at 80 mph the wing needs to generate a CL of .071
Using the MAC in profili:
At 40 mph the RE at MAC is 195,000. The wing needs to fly at 2.1* to generate a CL of .282 to fly level.
At 80 mph the RE at MAC is 391,000. The wing needs to fly at .3* to generate a CL of .071 to fly level.
Won't this require a trim change?
Old Sep 24, 2011, 04:10 PM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
Depends on where the CG is.
Nauga,
who likes neutral stability
nauga is offline Find More Posts by nauga
Old Sep 24, 2011, 04:13 PM
ibuild is offline
Joined Jul 2011
Old Sep 24, 2011, 04:30 PM
Just fly it!
Cody, WY
Joined Nov 2007
Nauga,
Nauga, I'm glad you chimed in.
Can you help me understand this?
I too like neutral stability. So when a nuetral stable plane increases it's speed the wing generates more lift... right? So this change in lift and speed would change it's elevation but not necessarily it's attitude. If I want the plane to maintain it's elevation at this new speed (from my perspective on the ground) I would need to change it's attitude...right? Or not?
Adam
Old Sep 24, 2011, 04:51 PM
ibuild is offline
Joined Jul 2011
Old Sep 24, 2011, 06:40 PM
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
If by the above you mean that as you increase speed you need to decrease AOA to maintain level flight, you are correct. As for the trim to maintain that new AOA, a neutrally stable airplane does not require a different trim surface deflection to maintain that new AOA regardless of speed. Think of it as having the CG at the aerodynamic center of the whole airframe (i.e. at the neutral point).
...you disabled your PMs...
My PMs are open and have always been, and I regularly exchange PMs with other groupers. Not sure why you got indications otherwise.
Nauga,
and his rate command system
Discussion airfoils airfoild... dunno about airfoils. shockwave3895 Foamies (Scratchbuilt) 6 Jun 13, 2011 05:10 PM
Alert New windburner plank world record timbuck Dynamic Soaring 11 May 30, 2011 03:57 AM
Discussion Plank Design and Airfoils For Dummies skirmish Slope 37 Nov 17, 2010 04:56 PM
Discussion ATJ Plank Sloper Airfoils for Light Winds atjurhs Slope 11 Aug 28, 2010 11:48 AM
Discussion New Slermal plank and chevron airfoils Windknot Slope 5 Jul 15, 2010 09:43 AM
