Old Sep 15, 2003, 02:05 PM
thorine is offline
Find More Posts by thorine
Callsign: Flyby
thorine's Avatar
Pacific, WA
Joined Aug 2003
Ball in swash mod
Where do I get a kit to do this? I have a Hummingbird. Is the kit just plug and play? Take out the old install the new type of thing?
thorine is offline Find More Posts by thorine
Old Sep 15, 2003, 03:53 PM
WyndShadow is offline
Find More Posts by WyndShadow
Razy Crandom Guy
Millville, New Jersey (excl EWR), United States
Joined Sep 2001
Try Sean at www.helihobby.com and then there is also www.precisionmodelproducts.com
I have done business at both. Sean's customer service is absolutely top notch. I use the other site as a backup when Sean is out of stock and I need a heli "fix" quickly.
WyndShadow is offline Find More Posts by WyndShadow
Old Sep 15, 2003, 04:45 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Here is another place to get a ball-in-swash mod. His price is less than Helihobby, and he only charges $2 shipping. I haven't ordered from him, but have seen good reports in other posts.
http://www.geocities.com/pierreholl...heliprohome.htm
Wherever you get the mod, it is not just a drop in. You have to remove the swash, and drill out the opening, so the ball and race will fit. You need to do this very carefully. It is well worth the effort, and makes a very significant improvement in the precision of the controls.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Sep 15, 2003, 04:48 PM
thorine is offline
Callsign: Flyby
thorine's Avatar
Pacific, WA
Joined Aug 2003
I would love to do it, but it sounds like something I would mess up.
Old Sep 15, 2003, 09:40 PM
Glenn Cain is offline
Find More Posts by Glenn Cain
Joined Oct 2002
patience and do not use too much strenght =p
Glenn Cain is offline Find More Posts by Glenn Cain
Old Sep 15, 2003, 09:45 PM
Razy Crandom Guy
Joined Sep 2001
Thosine, I thought the same, but actually, if you are careful and keep all this centered, it's not hard. The real trick is not to get any CA in the ball. I dipped a pin in some thin CA and then very very VERY carefully held the swash to the pin with the pin at an upward angle, to keep the drop near my finger. Got it all lined up and then dipped it onto the joint. Just make sure you are not on the ball, but on the race to swash line.
Old Sep 15, 2003, 09:46 PM
Razy Crandom Guy
Joined Sep 2001
OH YEAH, don't forget to make the opening big enough so that the ball rotates freely, without any tension and binding. I used a drill bit by hand that was almost big enough, and then sanded to get a smooth opening.
Old Sep 15, 2003, 11:52 PM
thorine is offline
Callsign: Flyby
thorine's Avatar
Pacific, WA
Joined Aug 2003
You make it sound do-able, but you drilled at steel ball by hand? That sounds ridiculous. And I have no idea what a race is. Did the tourtise win, or the hare?
Old Sep 16, 2003, 01:56 AM
Supersix is offline
Find More Posts by Supersix
Supersix's Avatar
Sydney, Down under
Joined Aug 2003
i dont think he drilled the ball but where the ball assebly fits into the chopper
Supersix is offline Find More Posts by Supersix
Old Sep 16, 2003, 10:56 AM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Thorine,
What you drill is plastic out of the middle of the swash, that is why you do it by hand. There is already a hole down thru the middle of the swash, you just enlarge it. Here is a picture of the ball and race. The ball is the shiny thing in the center, and the race is the black plastic around the ball. http://www.helihobby.com/commonImages/swashBall.jpg
Jeff
Old Sep 16, 2003, 11:24 AM
Randall is offline
Find More Posts by Randall
Randall's Avatar
Oliver BC Canada
Joined Nov 2002
If you do get it make sure you put it someplace safe, they are very small and easy to lose.
I misplaced mine and nearly ordered another one before I finally found it again.
Looking at that picture link that jeff555 posted, it seems to be a bit different then the one I had. Mine had a bit of a tapered towards the bottom which made it a lttle harder to drill out the hole for.
Here is a pic of mine before I installed it http://www.southokanagan.biz/moreHBp...SWASH.JPG.html
and one of it installed http://www.southokanagan.biz/moreHBp..._body.JPG.html
Randall is offline Find More Posts by Randall
Old Sep 16, 2003, 11:42 AM
thorine is offline
Callsign: Flyby
thorine's Avatar
Pacific, WA
Joined Aug 2003
I understand now! You guys rock!
Old Sep 17, 2003, 08:27 PM
Razy Crandom Guy
Joined Sep 2001
Mine had a little shelf-type-thingy at the top of the race, so I just drilled till it sat in there, but not too tight. It's important to make sure your hole is enlarged to a point where there is no binding or tightness, otherwise the servos work harder. I held the drill bit in my hand, then used sand paper to make the hole bigger by very tiny increments.
Old Jan 31, 2004, 09:31 AM
BeerBatter is offline
Find More Posts by BeerBatter
Want to Fly, Have to Work
BeerBatter's Avatar
Orlando, FL
Joined Feb 2003
Randall
Thanks for posting the picture of your heli with the swash ball mod. I just bought one from Helihobby and couldn't figure out how to install it (no instructions provided), but your picture and some of these threads made it clear.
I also upgraded to a Lipo battery pack and couldn't figure out how to place the battery far enough forward to make the CG right since the Lipo is so much lighter than the stock batteries.
I see in your picture how you rubber banded the Lipo to the two front carbon fiber bars. I will do mine the same.
-Beerbatter...
BeerBatter is offline Find More Posts by BeerBatter
Old Jan 31, 2004, 09:51 AM
JWags is offline
Find More Posts by JWags
JWags's Avatar
United States, MN, Rogers
Joined Mar 2003
For posterity (in the event anyone ever searches), that link should be http://www.geocities.com/pierreholli...eliprohome.htm.
I'll also throw in a link to http://www.slyshobbyden.net/ though I've never ordered from them and know nothing about them.
JWags is offline Find More Posts by JWags
Ball in Swash mod on Dragonfly Question cheeto Micro Helis 5 Feb 20, 2005 07:08 PM
WtB-ball In Swash Swashplate billyp Aircraft - Electric - Helis (FS/W) 0 Apr 25, 2004 03:43 PM
ball in swash mod ? buster7467 Micro Helis 6 Apr 07, 2004 10:14 PM
Ball in Swash Top or Bottom stuka Micro Helis 2 Nov 08, 2003 05:31 PM
Ball in swash mod thorine Micro Helis 5 Oct 21, 2003 08:05 AM
