| Thread Tools |
| This thread is privately moderated by jw357_23043, who may elect to delete unwanted replies. |
Here's the link to instructions:
http://www.extremeflightrc.com/manua...300_MANUAL.pdf Here's a link to an article for the setup of your plane, lots of serious competitors have used this article on setup: http://www.btinternet.com/~b.colclou...Trimming-1.pdf |
I've been into electrics since the beginning of my hobby but I'm just getting into bigger ones so I've been studying a lot about them and figuring out what I'm going to get for my new 60" EF Extra EXP that's coming out. I'm not going to promise everything I'm saying is correct as I've been more into large gas planes than large electrics but I'm quite sure it's all true and this is how I'm going to set up mine.
First thing, a lot of larger ESC's have a BEC cable. This is a cable that goes straight from the battery to the RX but regulated. It will eliminate the danger of the ESC failing and you losing all control. But you're still relying on a single battery and plug. So what you need to do is get a battery probably around 500-1000 mah and regulate it to the same voltage the BEC is putting out and plug it directly into the RX. Yes, I recommend a small lipo for this, just make sure you take it out of the plane when you charge it. Remember, It's just a backup so it won't need to be anything really special. Chances are you will be just fine without the backup battery. I've just had too many malfunctions to be even slightly careless. I recently asked a similar question on FG. You can read through the thread if you want. There's some helpful info on there. I've just found that an extra battery is the most redundant setup: http://www.flyinggiants.com/forums/s...ad.php?t=67700 |
I've been learning a lot since the post before my last one. What ever size prop you have, the motor will "try" to spin it at a certain RPM. Say 10000. The bigger the prop you have, the more amperage it will take to spin that prop. So you want to get the biggest prop you can without burning up the motor. I recommend getting a watt meter for this and run it on the ground at full throttle to see how many amps the motor is taking. Also, if you have a prop so big that you can't run the motor at full throttle without over amping it, that makes a less efficient setup because the prop is heavier for the same amount of power that you'd be making with the motor running at full and a smaller prop. Hope that makes sense.
| Thread Tools | |
| Sold Extreme Flight 70" Extra 300 EXP ARF NIB ( LPU in Middle GA ) | fatboyflying | Aircraft - Electric - Airplanes (FS/W) | 31 | Oct 16, 2011 09:05 PM |
| Sold Extreme Flight 78" Extra 300 | pfoot748 | Aircraft - Electric - Airplanes (FS/W) | 6 | Oct 06, 2011 08:53 PM |
| Wanted Extreme Flight 58" 300 Extra | SBOTI74 | Aircraft - Electric - Airplanes (FS/W) | 6 | Sep 19, 2011 11:06 AM |
| Sold Extreme Flight 70" Extra 300 EXP *** BRAND NEW *** | bluelevel | Aircraft - Electric - Airplanes (FS/W) | 3 | Sep 13, 2011 12:08 PM |
| Discussion Extreme Flight 70" Extra 300 | oldal | Competition Aerobatics | 0 | Sep 11, 2011 04:27 PM |
