Old Oct 02, 2011, 09:28 PM
swheels is offline
Find More Posts by swheels
swheels's Avatar
Joined Jan 2005
Originally Posted by Manuspain View Post
one or two seconds slower than a 1/5 superbike the same day on the same track. Not bad at all.
But the 1/8 scale need more tires options to be really funny in my opinion.
Not saying it was bad.I was just pointing out what i saw from the other 1/8th bikes. Now looking at that track the only real advantage i can see for a 1/5 bike.Would be on the long straight away,as far as going through the turns.It looks like it's point and shoot for any 1/5.Whereas the 1/8th bikes should be able to flow more.
Originally Posted by trf_414_m2 View Post
I should agree with Manu.
He was the only one that tested my bike at the Nats (others wanted but racing schedule was so tight...)
There are very few tyre choices for 1/8 scale. I raced Venom tyres and inserts due to easier availability for me while other drivers mixed OTO/ZH/Venom tyres and OTO/custom front inners plus OTO/Venom/custom rears.
But I think most important factor for the "front end pushing" seen at the video are the crash bars placement. If we look at bike´s mid point of wheelbase, OTO based prototypes place crash bars contact point closer to the front, and CG make them to unload that wheel.
My design places crash bar contact point over spur gear and CG is much more advanced and raised. This makes the front tyre to get a lot of pressure from bike´s weight at slow corners. This could lead to an unloaded rear wheel if not properly tuned, but I feel fast enough even in rainy conditions.
You should tell the other guys this so they can get their bikes working better.
I only had to watch the vid once to see what was happening.I'm not taking anything away from your bike,it works great. I was just pointing out what i saw,in the other 1/8th.
swheels is offline Find More Posts by swheels
Old Oct 02, 2011, 09:34 PM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
The 1/8 bikes are faster on he tight tracks... Look at the racing porter texas thread i just added some videos. I use the Zh Soft tire with the Zh hard insert for the front. Hard zh rear with the Zh rear yellow insert that comes with the Hard tire. These are the Slick versions that Zh has.
621clay is offline Find More Posts by 621clay
Old Oct 03, 2011, 08:45 AM
swheels is offline
swheels's Avatar
Joined Jan 2005
EEYup! That's pretty much what i'm saying. I'm pretty sure the superbikes are making time on his 1/8 on the straights.Where they can really open those 1/5 bikes up.
What did you do to correct the problem of the frontend pushing on your bike 621clay??
Old Oct 04, 2011, 01:14 PM
621clay is offline
621clay's Avatar
Joined Dec 2009
I run no fluid in the front forks. Wheel base it 193 mm. and i just tried my rider "whole" i always used a dremeled rider. I think the whole rider helps the front end more. Also my steering is not dampened anymore giving the front freedom to move when it wants to for a better contact patch. At this scale though.... thats just a thought... seeing it would be more believeable.
Old Oct 04, 2011, 02:30 PM
trf_414_m2 is offline
Find More Posts by trf_414_m2
Espaņa, CL, Ávila
Joined Sep 2008
I understood you at first time...
Thanks for the good comments
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Nov 30, 2011, 04:18 PM
forsakenrider is offline
Find More Posts by forsakenrider
Canada, BC, Grand Forks
Joined Aug 2008
any pictures of the actual bike? I really like this unique design!
forsakenrider is offline Find More Posts by forsakenrider
Old Dec 01, 2011, 10:03 AM
Espaņa, CL, Ávila
Joined Sep 2008
No actual pics yet.
Still saving to start ordering CNC machining of the motor mounts and complete chassis.
In the past 20 days, I´ve got some new ideas that lead to modify several parts design.
New too, a carbon fin (not displayed) that would fit between battery and esc. This will be the best place to add lead weights and change CG height.
Found different batteries and they allowed to place the front shock inside front swingarm.
Hope to start assemblying mine soon (handcrafted) but I´ll surely miss the chance to sell some this Christmas.
New 3D images:
Old Dec 01, 2011, 08:09 PM
Joined Aug 2008
Very nice! Looks light.
So why the offset rear? are the pinion, spur, and chain/belt all on the right side now?
Old Dec 01, 2011, 11:05 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
The rear only appears to be offset in the rear swingarm to make room for the drive train; otherwise, it appears to be inline with the front wheel.
Really cool design -- I can't wait to see it built!
Guidoracer is offline Find More Posts by Guidoracer
Old Dec 02, 2011, 07:17 AM
Joined Aug 2008
Yes thats what I mean. I've just usually seen the chain on the left side, I would think that must make a pretty busy right side, but nothing wrong with that that I can think of.
Old Dec 02, 2011, 10:57 AM
Espaņa, CL, Ávila
Joined Sep 2008
Busy right side?
This setup allows a fixed swingarm pivot shaft. It´s installed in the motor mounts with a press...
Why losing power fighting against swingarm suspension reaction when you can make a spur/pulley holder spining over bearings?
A low friction belt (low mass too) transfers the power to the rear wheel for the best efficiency ever seen at this scale.
A pic of the pulley setup at the "busy side":
Thanks Lito...
Ah, I forgot to say this bike feature two busy sides....
Right one for any transmision work, and left one for suspension setup.
Old Dec 02, 2011, 01:51 PM
Gartenzwerg is offline
Find More Posts by Gartenzwerg
Gartenzwerg's Avatar
Austria
Joined Jan 2007
This thing looks like straight from a Transformers Movie..
I love it !
Gartenzwerg is offline Find More Posts by Gartenzwerg
Wanted need 3 lobe 5.8 clover leaf windfou FPV Equipment (FS/W) 0 Sep 07, 2011 09:25 PM
For Sale 3.5/3.8 Xplorer V tail fuse ak79 Aircraft - Sailplanes (FS/W) 6 Jun 30, 2011 08:10 PM
Discussion El otro patron, mas bien, el primer patron Alfredo Rubio Mexico 4 Jun 20, 2011 09:01 PM
Discussion 3.8 -> 4.8 kg of thrust needed Narwhal Power Systems 2 May 31, 2011 10:01 PM
For Sale Bazooka el series 8" powered sub woofer bass tube nitrodude71 Non R/C Items (FS/W) 0 Nov 23, 2008 08:04 AM
