Old May 10, 2012, 06:02 AM
Hyvok is offline
Find More Posts by Hyvok
Joined May 2010
Originally Posted by Zen09 View Post
Beware, your MOSI connection to 9x seems wrong to me! It is not clear from the picture..
Perhaps you should use my picture http://imageshack.us/photo/my-images/836/detailq.jpg/
And this one for the USBasp interface http://th9x.googlecode.com/svn/wiki/....png?width=600
It is correctly, the yellow line points to the MOSI wire not the pad under it. I'll add a note to the text...
Hyvok is offline Find More Posts by Hyvok
Old May 11, 2012, 05:05 AM
z01z is offline
Find More Posts by z01z
Joined Mar 2012
Originally Posted by Hyvok View Post
Hey guys, I made a blog post where I try to clearly explain what you need to do to your 9X to get it to support the FrSky telemetry: http://www.dgkelectronics.com/how-to...elemetry-data/
Any suggestions what I could add or be more clear about?
I've a question regarding your mod, why is it needed to remove the MAX3232?
If the goal is to connect the 9x to the FrSky module internally, wouldn't it be sufficient to only connect the two lines to the 5 pin connector?
z01z is offline Find More Posts by z01z
Old May 18, 2012, 05:00 AM
maca55 is offline
Find More Posts by maca55
Australia, VIC, Chadstone
Joined Dec 2011
Results of 10 ohm resistor on MISO only
A 15ohm resistor will do. It is required only on MISO, you can leave MOSI with no resistor.
I was surprised by how low the resistance should be for the signal to pass. I can't tell the tolerance interval, except that it must be less than 200
Try whatever works and reply back so I can update the video.
I have just done your nice mod method direct to the DHT module. I used a 10ohm resistor (all I had) on MISO only. Thanks for this simple 'zero cost' method!!
I am receiving Telemetry fine however interestingly I still get the noise from the module when Writing an eeprom. Flashing firmware and reading of the eeprom makes no noise. This is using the HK USBasp programmer. I also have another programmer from ebay which makes no noise on the module!?
Also, not sure sure if this is normal, but when I alter the RSSI alarm levels in the open9x Telemetry page it does not appear to change the DHT alarm levels?
Any advice on what might be wrong, or is this all normal?
maca55 is offline Find More Posts by maca55
Old May 18, 2012, 08:29 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
This would mean the value of the resistor is too low.
This would mean the value of the resistor is too high.
Sorry, it's time someone who really knows the FrSky circuitry to jump in.
I personally have no idea why there's clicking noise and only provided a hack that worked at least for me and some others.
Zen09 is offline Find More Posts by Zen09
Old May 18, 2012, 08:51 AM
maca55 is offline
Joined Dec 2011
Thanks for your reply Zen. Actually the clicking noise doesnt bother me, as long as it is not doing any harm to the module. I will try without the resistor and post an update on whether the alarm setting works. Still think this is a good hack as it requires so little in the way of additional parts.
Old Jun 11, 2012, 02:44 PM
qmulus is offline
Find More Posts by qmulus
Gustatus Similis Pullus
USA, CO, Arvada
Joined Mar 2007
I just installed a DJT module in my 9X. I did mine a bit differently. For the remapped switches, I simply "tombstoned" the existing 220 ohm resistors and soldered the 30 AWG wires to them and to the uP pins. I then soldered the cable on the back board direct to the MOSI and MISO pads. So there was no need to add any components as they were already there. Due note that I do NOT have a programmer wired into my 9X, but rather just a header that I connect to universal device programmer I use (Conitec GALEP-4, FWIW) for when I need to flash it. I remove the back to reflash and disconnect the RF module, so there is no possibility of one circuit affecting the other. YMMV.
One thing that I did notice for this modification is that you must make sure to cut the re-purposed antenna ground pin on the module header away from the ground planes on both sides of the back board. I forgot to check the back side the first time.
Here is a picture of the re-routed serial lines on the DJT module. Note that I could have ran the jumpers from the vias near the uP instead of the RS232 IC.
qmulus is offline Find More Posts by qmulus
Old Jun 11, 2012, 03:04 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
One more way to... skin the Frsky module in order to send telemetry to the radio without holes.
renatoa is online now Find More Posts by renatoa
Old Jun 11, 2012, 03:33 PM
qmulus is offline
USA, CO, Arvada
Joined Mar 2007
Yes, is more direct the way you did it. Not sure why I grabbed them where I did, but I do like the way it works.
Old Jun 15, 2012, 06:18 AM
maca55 is offline
Joined Dec 2011
Has anyone tried adding a TTL Bluetooth module directly to the FrSky TTL signals for purposes of sending the Telemetry data to a phone or PC? It should work right?
eg) something like this:
http://www.goodluckbuy.com/serial-bl...ule-rs232.html
The Bluetooth addons mods I have seen so far appear to all use a TTL converter which I dont have as I have used the direct method detailed in this thread.
Old Jun 15, 2012, 09:27 AM
qmulus is offline
USA, CO, Arvada
Joined Mar 2007
The levels aren't the issue. These Bluetooth module (and any for that matter) need to be configured and matched via serial AT commands. This means that you would need another processor in between the Bluetooth and FrSky module to handle that. That isn't a big issue, but it does add complexity. It looks like the ERSKY9x board already has a provision for a Bluetooth link.
http://9xforums.com/forum/viewtopic.php?f=7&t=934
Old Jun 15, 2012, 09:41 AM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
nice mod, i'm waiting for my djt module and considering whether to go this route.
a question. both the max232 and 9x board will be driving the rxd line of the stm32, wouldn't there be interference? did you need to disconnect the output of the max232 since you would not be using it?
thanks
noobee is offline Find More Posts by noobee
Old Jun 15, 2012, 09:42 AM
Joined Sep 2007
There are transparent COM over BT modules, not requiring any configuration.
Joined Sep 2007
thanks
Yeah, this should be a kosher design.
Old Jun 15, 2012, 10:35 AM
noobee is offline
Joined Dec 2006
sorry, i didn't understand your response
is it okay to just tie the outputs together? or should i be disconnecting the max232 output from the stm32?
thanks
Old Jun 15, 2012, 10:53 AM
Joined Sep 2007
Disconnect max.
To one of the radios I moded so far the max232 is more powerfull than 9X, and don't let transmit alarms programming commands to the module if tied together.
Build Log Turnigy 9X and FrSky with Telemetry for Dummies Art Newland Radios 26 Dec 22, 2011 12:54 PM
Question Sell my DX6i for 9x w/frsky telemetry? razorseal Radios 12 Oct 18, 2011 11:08 AM
Discussion Sell my DX6i for 9x w/frsky telemetry? razorseal Radios 8 Sep 15, 2011 06:55 PM
Question Is there a firmware that supports Frsky telemetry for 9x? razorseal Radios 0 Sep 15, 2011 12:07 AM
