Old Jan 10, 2013, 12:30 PM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Still Got Mine...
Originally Posted by yellowcolorado View Post
I just picked this plane up for 83 bucks. It seems like a pretty solid plane. Is there a reason this plane isnt being discussed anymore?
...in the hangar...
That is a super deal for this beautiful lil' airframe. The recommended Rimfire .10 motor works well unless you're used to flying faster birds already...
Been mostly practicing with & flying my aerobatic & 3D planes so there hasn't been any room for her in the rig lately... Although I did manage to bring her out of hibernation last week...
She always manages to give a quite a thrill to both pilots & onlookers. She can hold knife edge passes really well. I also enjoy like the way she can carve turns. Roll her 90 degrees then pull elevator & watch her rail through turns is really satisfying. She's a bit nose heavy with the recommended CG so it takes some push on the elevator to keep her flying neutral when inverted but that's to be expected with this type of racing design. For me, she seems to fly more like a scale warbird but is much more roll & pitch sensitive (for obvious reasons) since she is a race plane afterall...
I am beginning to move the battery back to get more of a neutral CG but at the same time I don't want her to become even more of a handful when it comes time to bring her back down to terra firma... I'm running a 9x7E prop for (slower) sport flying but I'm going to swap that out for the 8x8E for more speed. She does fly fine at 1/2 - 2/3 throttle so you don't have to be on it all the time which is nice...
As most here will tell you, the landings can be bit tricky with this ship since she'll bounce on all but the most perfect landings. Best advice is to plan & set up for landings much earlier to bleed off speed & then get her down sooner using the entire length of the runway to let her roll out...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Old Jan 10, 2013, 02:00 PM
Demon 6 is offline
Find More Posts by Demon 6
Dir. of Innovation at Alert 5
Demon 6's Avatar
United States, FL, Fort Lauderdale
Joined Jul 2011
Are you running the recommended power setup or is it amped up a bit. I tend to over power all of my models, but i'm thinking of making this one a quick and lite one.
I ran it stock... She's no slouch.... But I just picked up a .15 equivalent from HK, it has 1800kv so with a 9x9 she should be well equipped. It's a steal at those prices!
Demon 6 is offline Find More Posts by Demon 6
Old Jan 12, 2013, 11:13 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Just caught up
supercollider is offline Find More Posts by supercollider
Old Jan 21, 2013, 10:10 PM
Demon 6 is offline
Demon 6's Avatar
Joined Jul 2011
I'd buy one in a heartbeat! (I'f I didn't already have one)
Old Jan 31, 2013, 08:49 PM
CashD is online now
Find More Posts by CashD
One more flight...
CashD's Avatar
Joined Jan 2010
I am finally starting on mine. Is everyone using the stock pushrods setup, or are you replacing them. Wheel collars on a race plane seems like a potential problem.
CashD is online now Find More Posts by CashD
Old Feb 01, 2013, 09:47 AM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
All Stock...
...on this lil' speed racer with no issues to report, other than it's a little cumbersome to set up & adjust in the beginning...
Old Feb 02, 2013, 07:15 PM
CashD is online now
One more flight...
CashD's Avatar
Joined Jan 2010
Thanks for the response.
Old Feb 28, 2013, 07:59 PM
United States, NE
Joined Sep 2012
I was thinking the same thing on about the push rods, but then I installed them. They seem to work good.
Cheers
Old Mar 11, 2013, 08:21 AM
Demon 6 is offline
Demon 6's Avatar
Joined Jul 2011
I went with metal clevises, but have not heard of any issues with the stock hardware. I suggest following their "throw rate" suggestions, she is very snappy...
Old Mar 11, 2013, 09:15 AM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
Is using a strong servo like the HS-65MG on the rudder and elevator worth it? I'm only slightly overpowering the model (500W level - 1500kv). Or can something in the torque range of the s3114 be okay?
My build was going great - easy like every GP kit - except for the annoying locknut on the landing gears. Results do not match the photos
voxel is offline Find More Posts by voxel
Old Mar 13, 2013, 01:12 PM
Demon 6 is offline
Demon 6's Avatar
Joined Jul 2011
I was using the "Corona" brand micro servos all around with excellent results.
I read in the thread that once you get a "fast" Cosmic that the surfaces will "flutter" and a high grade servo must be used...
Old Mar 20, 2013, 07:54 AM
Demon 6 is offline
Demon 6's Avatar
Joined Jul 2011
Hey guys, I did this simple mod and it tamed the landings right out. It takes the excessive flex out of the main gear and keeps her from doing the "bounce"... I have the gear mounted with nylon 4-40 screws just in case I catch a divot in my grass field. A little unorthodox, but works great nevertheless. Name: ImageUploadedByTapatalk1363784002.698446.jpg
Description: Name: ImageUploadedByTapatalk1363784021.660389.jpg
Description:
Old Aug 22, 2013, 11:28 PM
corsair2014 is offline
Find More Posts by corsair2014
United States, TX, Cypress
Joined Jan 2012
Geek Moment: Onboard the Cosmic Wind (1 min 25 sec)
corsair2014 is offline Find More Posts by corsair2014
Old Aug 23, 2013, 02:29 PM
Demon 6 is offline
Demon 6's Avatar
Joined Jul 2011
Sweet... Liked to have seen more!
Old Aug 23, 2013, 03:42 PM
Joined Jan 2012
more coming soon!(:
i will be doing a compilation with my friends Extra 300 and we will be doing streamers, smoke bombs, etc
Sold GP Cosmic Wind Minnow ARF NIB 60 size, and others midwest_plans Aircraft - Fuel - Airplanes (FS/W) 0 Nov 04, 2010 07:14 AM
Found GP Cosmic Wind (Minnow or Lil Toni) or GP Revolver-RTF GoingVertical Aircraft - Fuel - Airplanes (FS/W) 0 Nov 04, 2007 01:18 AM
Discussion Recommend 4 stroke for GP Cosmic Wind Minnow RobNHood Engines 2 Aug 18, 2007 12:51 PM
