GP Cosmic Wind
This looks interesting. I wonder if Great Planes is going to come out with a series of foamies at the 129 price?
http://www3.towerhobbies.com/cgi-bin...0p?&I=GPMA1811 Wolfe |
http://www.electrifly.com/largeelectrics/gpma1810.html "ElectriFly captures the Cosmic Wind’s sleek racing profile with a painted fiberglass fuselage, fiberglass wheel pants, and built-up wood wing and tail covered in MonoKote film. Use the included checkerboard decal sheets to create a custom look." |
United States, IL, Chicago
Joined Dec 1996
I'd start looking at things like wing loadings and section - I'd be building this with wash-out and all up, no down differential on the ailerons, that sort of scale stuff.
After my ElectriFly Fokker DR1 triplane experiences, you couldn't give me any more of their stuff for Christmas... Regarts Dereck |
A few pics after the unboxing over the weekend. My progress is rather slow during the weekdays. Should be finish by Friday and looking forward to its maiden flight this coming weekend.
I was able to finish motor install, landing gears, wings and tail yesterday. Will post those pics later. |
Joined Dec 1996
There's some serious wing taper there.
Wouldn't fly this one tail-heavy or with too much control throw on ele or ailerons. Got the impression the overall finish was red - you have a spray paint job upcoming too. Good luck! D |
This one does seems to like to be flown fast with very small throws. The manual confirms this:
"CAUTION: The throws appear to be small. However, the model has been extensively flown and tested to arrive at the throws at which it flies best. Flying your model at these throws will provide you with the greatest chance for successful first flights. Increasing the throws can cause the plane to be very difficult to fly." Elevator: 3mm - 6mm Ailerons: 3mm - 5mm I typically take first several flights on any plane easy on both e&a just to ensure no surprises...especially on this one since they're small to begin with. More than likely I will have to bump up my expo higher than normal to account for this. |
Here's a the latest update. It's nearly ready. See pics below. Since I can only get to this in the evening, pics may look a little darker due to lighting I used in the house.
Remaining components:
ARF installation has been relatively run-of-the-mill with exception of:
Impression so far:
I hope to finish remaining components tonight as time permit so I can maiden her early Friday evening/early Saturday morning.
Joined Dec 1996
How's the CG doing? With the battery that far up front, you'll have to balance it with one size/type of pack and just use that for flights. Changing the pack for one of different weight will affect the CG.
An idle thought, though hopefully you're ahead of me. If the battery is loaded from the underside, use Velcro for its full length and use a double sided Velcro strap to secure it around the pack and battery tray - gravity works real well downwards, where the pack is pointing. It looks a lot better than my Electrifly DR1 as a flying prospect... If you look at a real P51, they had a fair amount of dihedral too. D |
| Thread Tools | |
| Sold GP Cosmic Wind Minnow ARF NIB 60 size, and others | midwest_plans | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 04, 2010 07:14 AM |
| Found GP Cosmic Wind (Minnow or Lil Toni) or GP Revolver-RTF | GoingVertical | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 04, 2007 01:18 AM |
| Discussion Recommend 4 stroke for GP Cosmic Wind Minnow | RobNHood | Engines | 2 | Aug 18, 2007 12:51 PM |
