Old Sep 20, 2011, 12:29 AM
Skyraider Bill is offline
Find More Posts by Skyraider Bill
If you build it, they will FLY
Skyraider Bill's Avatar
Joined Sep 2010
Mini-Review
FMS Douglas A1 Skyraider 750mm
Hello Gents,
This is not an in depth review just my quick take
on the FMS mini Skyraider with the 750mm wingspan.
Even though I'm in a build of my own of a molded fiberglass A1 with a 47inch WS,
I bought this little foamy because mine isn't ready yet and I was really pleased that FMS did their homework on what a Skyraider should look like...unlike Starmax(enough said there)
It's a bit small, but it looks great and is pretty darn accurate.
I picked this up online from I think a Singapore distributor. BananaHobby didn't have them yet. I paid probably twice what they charge.
Model was packed nicely with no transpo damage.
The build is straight forward to the instructions. The only thing I changed was the supplied Deans to a JST for battery.
The only thing to glue is the horizontal stab parts. The molding is very good and the parts line up without difficulty. I glued them on with the main wing bolted in place for visual alignment.
A Turnigy 1000mah 2cell fit perfectly in the battery area of the fuse.
It's tight in there, but everything fits.
Spektrum radio was used and all controls were set to 30% expo.
Flying:
The CG in the instructions is correct.
I didn't want to break the supplied 3bladed prop on a maiden so I switched it with a GWS 8x6 Slow fly. It's a bit flexible but worked fine.
The maiden as you will see in the video is uneventfull.
Take off is about 5-10 feet...or less
Ithink I gave it two clicks of up trim..that's it.
The plane flies great an has more than enough power.
I flew it mostly at half throttle.
It tracks nicely through loops with no corrections.
Tip stalls were non existent to me.
On landing I kept a liitle extra speed, but it bleeds off quickly on touchdown.
The battery was maybe warm but definitely not hot.
Conclusion:
The model seems small but if you keep it close you'll do fine. The wing loading doesn't seem high at all. (I have not done the math on it )
Again just build to the instructions and use EXPOs on the throws.
It is a fun little bird for the cost. I might get another and paint it in a different scheme
Skyraider Bill is offline Find More Posts by Skyraider Bill
Old Sep 20, 2011, 12:34 AM
Joined Sep 2010
And here is the video...when it's done uploading...
FMS mini A1 Skyraider maiden flight (3 min 33 sec)
Old Sep 20, 2011, 12:53 AM
foamjet is offline
Find More Posts by foamjet
Joined Mar 2011
nice review.
Do you think flaps would be nice on this A-1E in landing?
foamjet is offline Find More Posts by foamjet
Reply With Quote  (Disabled)
Old Sep 20, 2011, 09:48 AM
Joined Sep 2010
Honestly I don't know if it's worth the weight increase. This airplane is really small.
SB
Old Sep 28, 2012, 03:37 PM
Weed89 is online now
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
i use 3s1p 850 lipo...but wants to ground loop like crazy
Weed89 is online now Find More Posts by Weed89
Old Oct 19, 2012, 09:48 PM
DRAMJET is offline
Find More Posts by DRAMJET
2 metre rule applies!
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Weed,
Just got given one from a mates friend who didn't have any luck with it but I'm sure he was in need of a trainer not a slick mini. I have finally arrived at the conclusion that my FMS F4u is beyond repair and along comes this. The corsair was a great belly lander and under arm launches worked well. With gear on it flipped over on grass landings always and got airborne with only 60% power otherwise "exit stage left"!
Reglued the firewall and some cracks around the upper cowl, XT60 and 7060 SF prop from the Corsair and its ready to go.
Can you advise me of the CoG. I will use a 1000mah 3s, same as the F4u and it seems to be about 1/3 back from LE, any thing more precise?
Thanks. Same same as the 1100mm Durafly just smaller and I'm sure quicker.
Foamjets question about flap, just use channel 5 (aux) as other aileron and dial in flaperons, no weight increase for some flap, only trouble is if belly landing it puts more stuff down into the dirt so keep wheels on.
DRAMJET is offline Find More Posts by DRAMJET
Old Oct 19, 2012, 11:02 PM
Mikey 68 is offline
Find More Posts by Mikey 68
Joined Sep 2004
They sell pretty small servos that you could use for flaps
Mikey 68 is offline Find More Posts by Mikey 68
Old Oct 19, 2012, 11:18 PM
DRAMJET is offline
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Twizt, yeah those 2-3 grammers should do it, but this size ac just do it nice clean.
Old Oct 20, 2012, 11:04 AM
Weed89's Avatar
Joined Aug 2012
CG is aprox 1 1/2" from leading edge @ fuselage....remember to check it inverted I use 3S1P both 850MAh and 1000Mah lipos with no issues...just shove them as for into the nose as they can go...Enjoy...I set my timer to about 5 mins.
Old Oct 25, 2012, 11:56 PM
DRAMJET is offline
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Got mine proper maidened today.
Had a launch attempt last Sunday but it rolled RIGHT (!) from an underhanded launch (unlike my retired F4u) and took an early break to prop, gear mount and required motor bell manipulation. 1000 3s in battery slot gave correct cog, thanks weed.
Repaired and more alert today, it went for left roll on launch but got that under control and had a ball like I used to with the corsair. Quick rolls, powerful elevator and FAST, same as the corsair, but easier landing on grass with gear without the nose over that the corsair would always do. Looks like the gear stays with this beast!
Old Apr 07, 2014, 10:07 PM
DonRhone is offline
Find More Posts by DonRhone
Canada, BC, Terrace
Joined Mar 2014
FMS A1 Skyraider 800mm
FMS 800mm A1 Skyraider Ver2
Why does the manual indicate the Cof G is 40mm on the bottom of page 13
yet on Page 18 the diagram shows the CofG is 65mm
DonRhone is offline Find More Posts by DonRhone
Old Apr 12, 2014, 06:26 PM
Weed89's Avatar
Joined Aug 2012
who knows they might be a bit different now...I have never flown with a 2 cell lipo ... and with the stock 3 bladed prop & a 3 cell ... Mine flies MUCH faster than the 1 in the video above
Old Aug 17, 2014, 11:15 AM
whypaymore is offline
Find More Posts by whypaymore
Joined Aug 2014
Very valid question, I didn't see anyone answering it , can anyone advise what's the correct CG position for this plane?
whypaymore is offline Find More Posts by whypaymore
Old Oct 10, 2014, 12:30 PM
Turbobearcat is offline
Find More Posts by Turbobearcat
Turbobearcat's Avatar
Joined Aug 2011
I am interested in this plane.... just looking for information..
Turbobearcat is offline Find More Posts by Turbobearcat
Old Oct 25, 2014, 03:38 PM
Joined Aug 2011
Well tried to fly mine this morning- it taxi well and the tail lifted off the ground, I increased power slightly and it went up in the air and drove to the left side and broke the props off!!!!
I was pissed...now I have to order all new props.. the problem was I was too slow on the take off and a slight wind gust made it veer off to the left into the grass.
ordered two new props for now...
New Product Banana Hobby's New A1 Skyraider!! hbsurfer Electric Warbirds 141 Sep 21, 2016 04:08 AM
Yippee! Epo a1 skyraider HLC SHOP Electric Warbirds 17 Feb 19, 2012 03:26 PM
New Product New A1 Skyraider!!! Banana Hobby CSR Banana Hobby 24 Feb 01, 2012 03:21 PM
Discussion Douglas A-1H Skyraider parkcityskier Foamies (Kits) 2 Sep 10, 2011 11:35 AM
Video Starmax A1 Skyraider jmpdgs Electric Plane Talk 0 Sep 05, 2011 10:41 PM
