Old Sep 19, 2011, 11:18 PM
coldboot is offline
Find More Posts by coldboot
Joined Aug 2011
Spektrum TM1000 Y-harness not working with Voltage sensor
Hey there,
I have a Spektrum DX8 with the TM1000 Telemetry module. It has a port for both voltage and temperature, that you can plug either one of those into, or you can use the included Y-harness to attach both at the same time.
The Temperature sensor works when directly plugged in to the TM1000, and in both plugs of the Y-harness.
The Voltage sensor only works when it's plugged directly into the TM1000, and doesn't work when plugged alone in to one of the Y-harness plugs, or along with the temperature sensor.
Does anyone know why the voltage sensor won't work in the Y-harness?
coldboot is offline Find More Posts by coldboot
Old Sep 20, 2011, 02:50 AM
Thalios is offline
Find More Posts by Thalios
Canada, QC, Quebec
Joined Sep 2011
Seems like your Y harness is wired wrong..
Thalios is offline Find More Posts by Thalios
Old Sep 20, 2011, 05:32 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
If you pay attention the the temps and voltage sensor connector you will notice that they both share one wire connection but heat sensor uses one end wire while the voltage sensor uses the other end wire.
If both sensors work directly in the TM unit then you know both unit and sensors work. If you connect the heat sensor in both ends of the Y harness then all you are doing is confirming that that side of the Y works.
If the voltage sensor stops working when you connect in the Y harness then the Y harness as issues OR you are not connecting it properly.
freechip is offline Find More Posts by freechip
Old Sep 20, 2011, 04:52 PM
coldboot is offline
Joined Aug 2011
Good point. It seems like the voltage-specific wire in my Y-harness might not be working. The connectors are such that you can't plug them in the wrong way, so this seems to be the only possibility.
Old Sep 20, 2011, 06:21 PM
coldboot is offline
Joined Aug 2011
Looks like my Y-harness is defective. The red wire doesn't have continuity to either side of the Y.
Old Sep 20, 2011, 07:05 PM
freechip is offline
freechip's Avatar
Joined Aug 2008
Cut away heatshrink and fix it. Should be fairly simple.
Discussion Frsky receiver not working with brushed motor rotagen Radios 3 Sep 19, 2011 05:05 PM
Discussion Connecting two batteries with a Y harness will.. Swert Pertoto Batteries and Chargers 2 Sep 10, 2011 10:38 PM
Question Spektrum radio compatability with reversing Y harness? wmcneal Radios 1 May 30, 2010 06:23 PM
Discussion E Logger V3 RPM with CSM Revlock 10 sensor not working sg sailing Eagle Tree Systems 5 Jan 08, 2010 04:13 PM
Discussion The DX7 not compatible with a reverse Y-harness? luisflycubs Radios 1 Jun 02, 2009 04:31 PM
