Old Oct 12, 2011, 07:16 PM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Thanks...much appreciated, guys!
racin06 is offline Find More Posts by racin06
Old Oct 12, 2011, 07:30 PM
bdiesel3 is offline
Find More Posts by bdiesel3
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Build pictures are up.
http://www.rcgroups.com/forums/showt...3#post19363382
bdiesel3 is offline Find More Posts by bdiesel3
Old Oct 12, 2011, 07:31 PM
bdiesel3 is offline
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Greg is always very helpful, a great guy to deal with.
Old Oct 12, 2011, 07:57 PM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
bdiesel3 was gracious to allow me to put 3 flights on his XL this evening. All I have to say is that this thing flies great. It was quite breezy this evening but it only made it more fun. I was doing low level tight outside loops and trying to touch the rudder at the bottom. Fun stuff. What made it better was how rock solid the XL is even in the wind.
r/cdawg is offline Find More Posts by r/cdawg
Old Oct 12, 2011, 08:09 PM
racin06 is offline
Joined Dec 2006
Originally Posted by bdiesel3 View Post
Awesome pics! You mind posting the lengths of the various carbon rod truss pieces? Also, how are the trusses secured...with medium CA or hot glue? Thanks.
Old Oct 12, 2011, 09:19 PM
bdiesel3 is offline
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Thank you for your kind words. The trussing carbon rod lengths from front to back are as follows: 7.5", 5.5", 5.5", 5", 5", 7.25". The first truss goes from the front of the fuse to the center point of the wing spar, then from there to the aileron hinge point. After that it is pretty forgiving on how it is done. On my next XL I would change the two 5" trusses to 5.5" making the last truss 6.25". I would do this just to be more even down the sides of the fuse and distrubiting the "twist" load from rolls more evenly (imo). The wing trusses are 9" long, though this works great, I may go 10"-12" on the next XL. I sharpened the carbon rods with sand paper on each end and poked them into the EPP at least a 1/8", then removed them and put Welders glue in the holes in the fuse where I poked the carbon rods in and on the ends of the carbon rod. This holds really well and it takes quite a beating before they come loose. If one does come loose, I add some glue and put it back in place.
Old Oct 12, 2011, 10:42 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
EPP NEVER gets CA it will make a brittle joint. Hot glue is to heavy.
Welder adhesive or Beacon's foam tack should be used on all construction.
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Oct 12, 2011, 11:39 PM
ThatGuy123 is offline
Find More Posts by ThatGuy123
TAS Foamies was here!!!!!!!!
United States, CA, Thousand Oaks
Joined Jul 2011
Anyone need a paint job ?
ThatGuy123 is offline Find More Posts by ThatGuy123
Old Oct 13, 2011, 06:39 AM
HaeMKa is offline
Find More Posts by HaeMKa
Dr.
HaeMKa's Avatar
Nederland, NB, Grave
Joined Jul 2011
And 5 - 10 or 15 minute epoxy.
Glues good, or is this to heavy too
Or gorilla glue, is not that heavy and glues very well, filles the little holes to..
Or are the named ones just the best for these foam planes..
HaeMKa is offline Find More Posts by HaeMKa
Old Oct 13, 2011, 05:37 PM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
Looks amazing Greg! Is the XL to big to fly at the grandville gym? I love the servo stray idea you came up with! Looks a lot easier and faster! Another homerun for WMPF! Keep up the good work!
TMAC4123 is offline Find More Posts by TMAC4123
Old Oct 13, 2011, 06:49 PM
bullittjeff is offline
Find More Posts by bullittjeff
Team Hillbilly 🐘💨
bullittjeff's Avatar
United States, OH, Canal Winchester
Joined Feb 2010
Just got some welders from lowes. I am all set for my build. The servo platform is awesome. If you burn one out just un screw and replace. I hate having to cut servos out of airframes
bullittjeff is offline Find More Posts by bullittjeff
Old Oct 13, 2011, 07:23 PM
bdiesel3 is offline
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
The servo platforms are great, I agree. I like you avatar, cool picture.
Old Oct 13, 2011, 07:35 PM
Team Hillbilly 🐘💨
Joined Feb 2010
thanks here's a few more.
Old Oct 13, 2011, 07:47 PM
racin06 is offline
Joined Dec 2006
Thanks for the great information. Based upon your measurements, it appears that the aileron servo tray should rest against the upper fuse tab to the front and the rudder/elevator servo tray should rest against the upper fuse tab to the rear. Is this correct?
Old Oct 13, 2011, 07:56 PM
racin06 is offline
Joined Dec 2006
Very nice 3DHS airplanes! I own the 3DHS 72" Extra 330SC running an 8S electric setup. I don't have any action photos of my 72SC, only video...not to hijack the thread...
3D Hobby Shop 72" Extra 330SC - June 26, 2011 (5 min 46 sec)
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product West Michigan Park Flyers EPP-MX2 WMParkFlyer 3D Foamies 767 Feb 07, 2015 08:50 AM
Discussion Yak 55 From West Michigan Park Flyers mt_100 3D Foamies 5 Sep 02, 2010 06:03 PM
