Old Oct 10, 2011, 03:51 PM
bullittjeff is offline
Find More Posts by bullittjeff
Team Hillbilly 🐘💨
bullittjeff's Avatar
United States, OH, Canal Winchester
Joined Feb 2010
10x3.8 it is then. Thanks
bullittjeff is offline Find More Posts by bullittjeff
Old Oct 10, 2011, 08:15 PM
bdiesel3 is offline
Find More Posts by bdiesel3
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Originally Posted by bullittjeff View Post
Just ordered one up. I'm going with the suppo motor and esc. Hk 9 gram servos and gens ace 3s 800 batteries. I ordered 10x 4.7 props but prob will try 10x 3.8 also. I love the looks of this plane and also the size. Should do really well in the back yard.
I also fly with the gens ace 3s 800mah, works great for this plane. I have also used the rino 3s 750 mah. I think this plane will work great on 3s 750mah -1000mah range. If you noticed my earlier post, I am trying a 3s 1550mah gens ace just for fun. Just placed more velco on for moving the battery back as it was too nose heavy to really know how the plane handles the battery, though suprizingly it did not seem too bad.
On another note, I placed washers behind the left side of the motor for some right thrust. Maybe to picky for a foamy, but it is fun to try.
bdiesel3 is offline Find More Posts by bdiesel3
Old Oct 11, 2011, 08:17 AM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Originally Posted by BryanEW710 View Post
Which prop do you feel that it did 3D best with?
For 3d definitely the APC 10x3.8. I also liked the GWS 9x5DD but felt the 10x3.8 was a little better.
r/cdawg is offline Find More Posts by r/cdawg
Old Oct 11, 2011, 08:21 AM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
This is what I like about flying foamies. They are forgiving enough to allow you to experiment with different set ups and the XL is about as forgiving of a foamy as I've flown. Just a really nice plane.
By the way how'd the right thrust work out?
Old Oct 11, 2011, 08:37 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
I'm surprised...I would have thought the 10x4.7 would have more thrust (which is what I'd think you would want for 3D).
BryanEW710 is offline Find More Posts by BryanEW710
Old Oct 11, 2011, 10:10 AM
bdiesel3 is offline
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
So far, it seems to work well. I going to try some more flights before I know if I want to leave it or not though.
Old Oct 11, 2011, 03:59 PM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
The 10x4.7 is to much for the motor. It did have better thrust but it got real hot real fast. It still gets warm with the 10x3.8 but not nearly as hot.
Old Oct 11, 2011, 04:12 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
At the same current level, the lower pitch will create more thrust, the higher pitch more speed.
In actuality you see more thrust because the higher pitch prop is drawing more current. If the system can handle it then it's great, if not then ......
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 11, 2011, 09:30 PM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Currently working on building my XL. So, I'm assuming the servos are secured to the wooden trays by two screws, but how are the trays secured to the foam...with glue? Also, any measurements available on where I need to cut the servo holes in the foam?
racin06 is offline Find More Posts by racin06
Old Oct 11, 2011, 10:42 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Glue the wood down with welder adhesive and you can then screw or glue down the servos.
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Oct 11, 2011, 11:28 PM
ThatGuy123 is offline
Find More Posts by ThatGuy123
TAS Foamies was here!!!!!!!!
United States, CA, Thousand Oaks
Joined Jul 2011
Well I am hoping to get my xl soon but I don't have the cash unless someone wants to donate one to me jk
ThatGuy123 is offline Find More Posts by ThatGuy123
Old Oct 12, 2011, 07:27 AM
racin06 is offline
Joined Dec 2006
Thanks. Does each pair of servo trays go cut in half or is the upper fuse actually resting on the middle of each servo tray pair? I can't tell from your photos. Also, do you have any measurements/distances of where the servo trays go installed?
Old Oct 12, 2011, 05:35 PM
Jenison
Joined Nov 2009
The servo tray is designed to rest under the top fuse. There are 2 cuts in the tray to help align it to the fuse.
I scaled up the picture and took some measurements. They can be viewed when you open the picture. We will get these in the build instructions when we get them completed.
Greg M
WMParkFlyers.com
Old Oct 12, 2011, 06:36 PM
bdiesel3 is offline
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Greg M
WMParkFlyers.com
I tried to upload my build pictures last night and ran into some problems, I will try again tonight. I also have measurments, but not as accurate as gregs. Here they are with just a ruler.
Old Oct 12, 2011, 07:06 PM
Jenison
Joined Nov 2009
Wow ... my measurements were on the money, nice to know I got the scale correct in the picture ... Note My measurements are to the front edge of the servo cutout.
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product West Michigan Park Flyers EPP-MX2 WMParkFlyer 3D Foamies 767 Feb 07, 2015 08:50 AM
Discussion Yak 55 From West Michigan Park Flyers mt_100 3D Foamies 5 Sep 02, 2010 06:03 PM
