Old Sep 27, 2011, 09:25 PM
racin06 is online now
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Which Hacker motor for XL?
I think I will go with a Hacker this time on the XL. Which Hacker should I use? The Hacker A20-50S is a little smaller with similar KV and power numbers (100 watts) as the recommended Suppo motor, yet is recommended for only 4 - 8 oz. models . The Hacker A20-26M is similar in size and KV as the Suppo, yet much more power (150 watts) and is recommended for 7 - 12 oz. models . Lastly, all of the Hacker motors recommended for 12 - 18 oz. models are 200 watt motors with the closest to the Suppo being the Hacker A20-20L; however, this motor is a little larger and heavier versus the Suppo. Any advice on the proper Hacker motor. I'm a little unsure . Thanks.
racin06 is online now Find More Posts by racin06
Old Sep 27, 2011, 10:46 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
I would go with the A20-26M I think the A20-20L would be too much for this plane. This is the data I found for the Suppo A2208-17 1100KV if you look at the data for the 3 cell on 9 x 5 DD it should give you 21oz of thrust. That is better than a 1.5 to 1 power to weight ratio.
http://www.motocalc.com/index.html has a good motor calc data calculator.
This is what it came up with for the hacker A20-26M 22.5 oz of thrust with a APC 10 x 3.8 prop the spec sheet recommends a 9 x 4.7 but I think it could handle the 10 at a lower pitch.
GM
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Sep 28, 2011, 09:40 AM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I agree with Greg in going with the A20-26M. The A20-20L will be way too much. On my XL I like the recommended Suppo with an APC 10x3.8 slo fly prop which provides gobs of thrust and a nice consistant speed envelope.
r/cdawg is offline Find More Posts by r/cdawg
Old Sep 29, 2011, 07:04 AM
bdiesel3 is offline
Find More Posts by bdiesel3
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Put some flights on the XL last night with r/cdawg, we also took some video and hope to get it up soon....stay tuned.
bdiesel3 is offline Find More Posts by bdiesel3
Old Sep 29, 2011, 08:01 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Really looking forward to this one! The McFoamy seems pretty cool, but I like that this one will be big enough that I don't need to buy new (smaller) batteries!
BryanEW710 is offline Find More Posts by BryanEW710
Old Sep 29, 2011, 09:44 AM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Video
bdiesel3 let me bind to his XL (I fly mode one) and put a flight on it while he videoed. The flying is nothing special, as an old guy like me will never be competing in the Extreme Flight Championships or King 50, but hopefully you will get the idea of how nice of a flying plane the McFoamy XL is.
bdiesel3's set up is as follows:
Eflite Park 370
GWS 9x5DD prop
Suppo 20a esc
Gens Ace 3s/800 25c pack
Hitec HS-65 servos
Spectrum AR6100 receiver.
The plane flies great with plenty of power as seen in the video. The larger McFoamy is nice for outdoor flying as it handles wind much better than the little EPP planes.
McFoamy XL (4 min 40 sec)
Old Sep 29, 2011, 09:53 AM
Jenison
Joined Nov 2009
Eflite Park 370
GWS 9x5DD prop
Suppo 20a esc
Hitec HS-65 servos
http://www.youtube.com/watch?v=djieizhZpj8
Mike, you don't give yourself enough credit on your flying skills. I don't know many people that can do a knife edge figure eight with the wing tips on the gym floor or even attempt it in the first place.
Thanks for shooting some video ... now we need to get one of these in Jase Dussias neighborhood.
Pick out your colors Jase we have one cutting in the laser this morning !!!
GM
WMParkFlyers.com
Old Sep 29, 2011, 10:08 AM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Yes, some video by Jase will really demonstrate what the XL can do in capable hands.
Old Sep 29, 2011, 10:10 AM
BryanEW710's Avatar
Joined Sep 2010
I'm also curious how it can do in normal hands--'cuz I sure ain't "capable"...yet
Old Sep 29, 2011, 10:19 AM
Jenison
Joined Nov 2009
Video is on the web site.
You want video in normal unskilled hands ... that means I might have to finish my build and shoot some crash tests !!! You guys keep me in the shop most of the time, so my stick time is even more limited than it used to be.
GM
Old Sep 29, 2011, 02:54 PM
BryanEW710's Avatar
Joined Sep 2010
lol...I'd like that.
It's really nice to see what a perfectly assembled plane can do when flown by a good pilot, but it'd be nice to see what a plane put together by and flown by a mere mortal would fly like, too.
Old Sep 30, 2011, 10:23 AM
Joined Dec 2006
GM
I appreciate the information. I'm still not certain on flying the XL in my indoor venue. I posted the dimensions of my indoor flying area, along with a video of my flying me McFoamy on Post #24. As the manufacturer, do you believe the XL is suitable to fly in my indoor venue?
Old Sep 30, 2011, 10:31 AM
Jenison
Joined Nov 2009
I appreciate the information. I'm still not certain on flying the XL in my indoor venue. I posted the dimensions of my indoor flying area, along with a video of my flying me McFoamy on Post #24. As the manufacturer of the XL, what is your opinion?
Racine06, I don't think it would be an issue flying in that space. The XL can slow down quite nicely. Based on your flying skills I think you will be fine.
GM
Old Sep 30, 2011, 11:43 AM
Joined Dec 2006
Thanks...what diameter and approximate total length of carbon trussing is recommended for the XL?
Old Sep 30, 2011, 11:57 AM
Jenison
Joined Nov 2009
Kit contents Include the following:
  • Plane painted, all hinges glued.
  • Motor Mount.
  • 6mm tube full length wing spar.
  • 3mm tube H-Stab spar.
  • Control linkage including E-Z connectors.
  • Wooden stand off set for control rod guides.
  • Wooden servo tray for dual aileron.
  • Wooden servo tray for rudder and elevator servo.
  • Carbon Fiber for wing and fuse trussing.
We include the trussing in the kit. We are going to include it an all the kits eventually.
We use 1.5mm for the trussing on this bird.
GM
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product West Michigan Park Flyers EPP-MX2 WMParkFlyer 3D Foamies 767 Feb 07, 2015 08:50 AM
Discussion Yak 55 From West Michigan Park Flyers mt_100 3D Foamies 5 Sep 02, 2010 06:03 PM
