Old Dec 15, 2011, 11:12 AM
philgriffin is offline
Find More Posts by philgriffin
Joined Aug 2008
Hello Greg.
Are screws included to attach the black plastic "backplate" (One that plugs into the mounting stick) to the motor? The ones included with the Suppo motor are too short. (Or I'm retarded, not sure which)
Phil
philgriffin is offline Find More Posts by philgriffin
Old Dec 15, 2011, 11:20 AM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Originally Posted by philgriffin View Post
Hello Greg.
Phil
Countersink the plastic disk for the flat head screws. Them use removable loctite on the screws to keep them from backing out in flight.
GM
from the droid mobile command center
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Dec 15, 2011, 11:26 AM
Joined Aug 2008
Thanks..
Btw, my brother Jim tried to call you guys earlier. He wants to order an XL Mc...
Old Dec 15, 2011, 11:37 AM
Jenison
Joined Nov 2009
Have him give me a call this evening I'm in the shop after 4 o'clock.
Note: the toll free number 855-359-9673 now forewards to my cell if no one is in the shop to take your call.
Old Dec 15, 2011, 05:42 PM
Joined Aug 2008
855-589-1694
This number is going to a fax machine...
Old Dec 15, 2011, 06:18 PM
Jenison
Joined Nov 2009
855-589-1694
Yes you are correct ... now you know our fax number too ... sorry I blasted my ears out with that fax tone as well. The correct number as stated above is 855-359-9673 ... small print and bad eyes got the fax number by mistake.
GM
WMParkFlyers.com
Old Dec 15, 2011, 06:29 PM
Joined Aug 2008
lol...Thanks Greg.
I'll forward this number to my brother..
Phil
Old Dec 15, 2011, 06:43 PM
Joined Aug 2008
Greg,
Do I drill out the holes in the little metal clevises on the servo arms that the CF rod goes through? It seems a little small...
Old Dec 15, 2011, 07:01 PM
Joined Aug 2008
It's ok, I just drilled them out a tiny bit. All is well...
Old Dec 16, 2011, 08:03 AM
Reaper802 is offline
Find More Posts by Reaper802
Reaper802's Avatar
United States, MD, Lexington Park
Joined Jun 2002
Greg,
I believe that is what the 4 extra pieces of piano wire with no z-bend are for. Get things mounted up, cut the carbon control rods a bit short, and then wrap/glue the unbend wire to the end. Then they slide right in with no problem.
This is my plan anyway if my HobbyKing shipment ever arrives. Last tracking had it leaving Switzerland on the 6th of December, today is the 16th. Not a good sign...
Reaper802 is offline Find More Posts by Reaper802
Old Dec 16, 2011, 08:28 AM
Joined Aug 2008
Thanks Reaper.
You know, I wondered what those unbent pieces were for. I ended up running a drill bit through the holes, just ever-so-slightly enlarging them, and the CF rods fit great. I feel kind of silly here, cause I've been assembling GS ARF's for the past 3 years, and when it comes to foamies I have all these questions... And BTW, this one's for Greg again. A 4 channel receiver is what I'll need for this, correct?
Old Dec 16, 2011, 08:30 AM
Joined Aug 2008
Here's what it looks like..
I cut the CF rods long, and have not trimmed to final length yet..
Old Dec 16, 2011, 08:31 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Correct.
BryanEW710 is offline Find More Posts by BryanEW710
Old Dec 16, 2011, 08:40 AM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Thanks Reaper.
Hi Phil,
A 4 channel will work fine with a Y harness for the ailerons. I've been using the little AR-6110e 6 channel receiver in my XL.
You should be fine with your pushrods as you have them. I think bdiesel3 has his this way and it's been working great.
r/cdawg is offline Find More Posts by r/cdawg
Old Dec 16, 2011, 09:01 AM
Joined Aug 2008
Thanks guys...
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product West Michigan Park Flyers EPP-MX2 WMParkFlyer 3D Foamies 767 Feb 07, 2015 08:50 AM
Discussion Yak 55 From West Michigan Park Flyers mt_100 3D Foamies 5 Sep 02, 2010 06:03 PM
