Old Dec 05, 2011, 07:08 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Originally Posted by Reaper802 View Post
Probably because I took the photos while standing on a chair.
Oh yeah...that'd do it
BryanEW710 is offline Find More Posts by BryanEW710
Old Dec 05, 2011, 07:18 PM
Reaper802 is offline
Find More Posts by Reaper802
Reaper802's Avatar
United States, MD, Lexington Park
Joined Jun 2002
Originally Posted by WMParkFlyer View Post
Dont forget to not glue dlwn where the servo trays are supposed to go.
I just glued the servo trays down and then glued the top over them. I hope that works out...
Reaper802 is offline Find More Posts by Reaper802
Old Dec 05, 2011, 07:41 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Yes that is correct... I was concerned when I did'nt see them in pla e on the test fit.
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Dec 05, 2011, 07:43 PM
Jenison
Joined Nov 2009
Wow ... rhe droid thumbs arent working too well going down the road.
Old Dec 06, 2011, 09:14 PM
Reaper802's Avatar
Joined Jun 2002
Ok I've run into my first little issue with the build. Nothing serious but I'd figured I would ask. Built my carbon linkages and started to do the dry fit. The photo on page one of the thread shows the rudder linkage on the right side of the plane when looking from front to back. This puts the elevator on the left side.
My kit is not pre-cut like this:
Notice it is cut to run the elevator on the right side except the elevator horn slot is on the left side of the plane. Perhaps the elevator came pre-hinged up side down?
I think what may have happened was that the wing section was hinged up side down putting the elevator holes on the ride side instead of the left.
Ether way it shouldn't be a big deal. I should be able to cut a new elevator horn slot on the right side that mirrors the existing one on the left. Problem solved, I think...
Thoughts?
Old Dec 06, 2011, 09:17 PM
BryanEW710's Avatar
Joined Sep 2010
I'd just cut a new slot.
Old Dec 06, 2011, 09:34 PM
Jenison
Joined Nov 2009
You are correct in the fact that your wing was hinged on the wrong side. We just started cutting in all the slots and trussing on these kits ... yours was the first. You will need to move the rudder servo linkage to the hinge side and move the elevator to the other. The rudder needs to be controlled from the left side of the plane (the hinged rudder side) as you are sitting in the pilot seat to get the correct throws. Do what you can to correct this and get it in the air. Let us know what you need as far as replacement parts.
We will be sending you a new kit soon.
Greg M
WMParkFlyers.com
Old Dec 07, 2011, 06:18 PM
Reaper802's Avatar
Joined Jun 2002
The pre-cut slots are great and made trussing a snap. I would suggest just adding the elevator guide holes to both sides in your drawing so it's impossible to get backwards from now on.
Quick question on the control horns: Which hole should I be using for aileron, rudder, and elevator for correct throw?
Now if that pesky HobbyKing box would just show up already I could finish this badboy... This is by far the longest I've ever had to wait for a HobbyKing order to arrive, must be the holiday season.
Old Dec 08, 2011, 07:23 AM
bdiesel3 is offline
Find More Posts by bdiesel3
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Greg M
WMParkFlyers.com
This is another place where wmparkflyers shines, excellent customer service. I had a small problem a few weeks back and Greg handled it no questions asked.
My XL is still flying great, though the wind has been persistant lately, looking forward to a calm day....
bdiesel3 is offline Find More Posts by bdiesel3
Old Dec 11, 2011, 10:32 PM
Jenison
Joined Nov 2009
West Michigan Park Flyers
Holiday hours of operation
West Michigan Park Flyers will be shutting down on Friday night December 23rd and will re open on Jan 2nd
We will be painting and shipping out orders during this time but we will not be taking in any orders over the phone or over paypal via website.
We would like to wish everyone a Merry Christmas and a Happy new year.
Please be safe during the celebrations
Old Dec 12, 2011, 12:19 PM
Reaper802's Avatar
Joined Jun 2002
The long wait for HobbyKing drags on... Maybe this week.
Asked this a few post back and never got an answer: Quick question on the control horns: Which hole should I be using for aileron, rudder, and elevator for correct throw?
Old Dec 12, 2011, 01:14 PM
r/cdawg is online now
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I typically like to set it up for maximum throws to begin with and adjust from there. I used HS-65 servos on my XL and on the ailerons I used the outer hole, and the middle hole for rudder and elevator. I did have to reduce the throws some to suit my flying style.
r/cdawg is online now Find More Posts by r/cdawg
Old Dec 13, 2011, 07:12 AM
bdiesel3 is offline
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
I usually start with the top hole and see how the throws are, if I need more then I move them down. Be sure for the elevator and rudder to do this before you glue the guides in the fuse, otherwise it could be difficult to change the hole location.
Old Dec 13, 2011, 07:40 AM
Reaper802's Avatar
Joined Jun 2002
I should be looking for about 45* of throw correct?
Old Dec 13, 2011, 09:27 AM
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
45 degrees would be fine for most 3d and aerobatic flying.
For max 3d I am running about 60 degrees on the elevator, the rudder touches the elevator at max throw, and probably 60 degrees on ailerons.
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product West Michigan Park Flyers EPP-MX2 WMParkFlyer 3D Foamies 767 Feb 07, 2015 08:50 AM
Discussion Yak 55 From West Michigan Park Flyers mt_100 3D Foamies 5 Sep 02, 2010 06:03 PM
