Old Sep 14, 2003, 10:48 PM
Starfox9 is offline
Find More Posts by Starfox9
Foam Addict
Boston 'ish MA
Joined Aug 2003
FMS Airplane Maker?
Where can i get the software/program to make airplanes in FMS. The link on their site was broken last time i tred. And is it easy?
Starfox9 is offline Find More Posts by Starfox9
Old Sep 15, 2003, 05:48 PM
ggunners is online now
Find More Posts by ggunners
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
Metasequoia Link
Check my web site under FMS models. The link was working last time I tried.
-- ggunners
Link to Metasequoia
Link to model building tutorial
Enjoy!
ggunners is online now Find More Posts by ggunners
Old Sep 17, 2003, 11:26 PM
Starfox9 is offline
Foam Addict
Boston 'ish MA
Joined Aug 2003
Thanks it worked. I forgot that I posted this so thats why i replied late.
Old Jul 31, 2008, 03:32 PM
killerkiz1 is offline
Find More Posts by killerkiz1
Joined Jul 2008
Help please
Hi,
I have a model and thats it ive saved it and everything but it wont let me fly it on fms it aint letting me on the .par folder cos there isnt one help please i want to fly it.
thanks
killerkiz1 is offline Find More Posts by killerkiz1
Old Aug 01, 2008, 09:49 AM
USA, VA, Chantilly
Joined Apr 2002
Just copy another model's .par file and rename it to your model's name .par.
Each FMS model has several files all with modelname. something.
mymodel.par = parameter file (versions for FMS 2.7 and 2.8)
mymodel.bmp = usually an image map file, i.e. paint for your model
mymodel.x = the DirectX 3D model used by FMS
mymodel.mqo = the Metasequoia 3D model you can edit
mymodel.wav = motor sound file
mymodel_prv.jpg = preview image for FMS when loading models
mymodel_readme.txt = readme comments file
So you can copy .wav, .par files from other models and rename them.
-- ggunners
Old Aug 01, 2008, 09:00 PM
flyx is offline
Find More Posts by flyx
Here's an english version of a .par file. I belive these are 2.7 .par
but it'll still work with 2.8. There are also different .par files
so you might want to load the latest model's .par file.
Sometimes the model won't display , if you need to try out different .par.
You can just copy and past this text into a .par file
Use Notepad to open .par file
0 1:Type(-) Type[0=Plane] ParDesigner Ver0.8
18 2:Tmax(N) Maximum Thrust
0 3rmax(rad) Maximun Rudder Angle
0.17 4emax(rad) Maxmim Elevator Angle
0.003 5amax(rad) Maximim Aileron Angle
1.0 6:CLmax(-) Maximum Lift Coefficient
-1.0 7:CLmin(-) Minimum Lift Coefficient
6.2 8:CLa(/rad) Lift Gradient
13 9:CLaSt(/rad) Lift Gradient in Stall
0.018 10:CDw(-) Drag Coefficient of Wing
0.02 11:CDb(-) Drag Coefficient of Fuselage
1 12:mug(-) Friction Coefficient of Wheels
0.76 13:dCDSt(-) Rise of Drag Coefficient in Stall
0.00 14:CM(-) Moment Coefficient
0.00 15:alpha0(rad) Wing Angle
1.6 16:b(m) Wing Span
0.32 17:c(m) Wing Chord
0.08 18:hce(m) Equivalent Center of Gravity
2.1 19:m(Kg) Mass
0.11 20:Izz(Kg*m^2) Yaw Inertia Moment
0.085 21:Iyy(Kg*m^2) Pitch Inertia Moment
0.06 22:Ixx(Kg*m^2) Roll Inertia Moment
0.09 23:She(m^2) Effective Area of Stab
0.05 24:Sfe(m^2) Effective Area of fin
1.0 25:Lt(m) Tail Moment Arm
0.000 26:VForm(-) Effect of Dihedral Angle
flyx is offline Find More Posts by flyx
FMS airplane model for GWS airplanes - Formosa RAY GWS GWS (Grand Wing Servo) 0 Dec 02, 2004 08:16 AM
FMS Airplane Design John2549 Modeling Science 2 Apr 08, 2003 04:08 AM
