Thanks - motors arrived today! Got to say www.allrocketengines.ca rocks!
Pretty much exactly as you described and really high quality stuff - very light. I'll mount it all up and wait until the framework is complete before doing another test burn - I only have 6 re-loads and more are on back-order ![]() Temp this week is hovering around 0 That's when us Canucks start to get cabin fever and want to go fly something!
Note, that depending on when yours were packaged, you might have to re-use the o-ring for the three motors....also, be sure to find the right non flamable high temp lube, I use superlube....on the o-rings and the casing/threads....
Frank Quote:
Latest blog entry: Spaceship One
I have not used vaseline, but if aerotech says that is ok, I guess that's fine.
I thought they wanted something hi temp so it doesn't run, but since you aren't using an ejection charge, there is nothing to get contaminated if it does run a bit. Remember, that E-6 reload thrust is about a pound or so, so won't help much but will give you a nice long burn for effect. Frank |
| Thread Tools | |
| Alert SUPER SPORTSTER EP by GREAT PLANES with Modified Power setup! (Guapoman2000) Part II | daddysard | Sport Planes | 2751 | May 03, 2013 06:12 AM |
| Sold OS 91FS-II SURPASS II with Pump | ton2di | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Sep 11, 2011 08:17 PM |
| $24 brushless motor - $49 with speed control part II | arx_n_sparx | Foamies (Kits) | 310 | Dec 13, 2005 06:36 AM |
| STS Enterprise - Space Shuttle | Hepdog | Foamies (Kits) | 122 | Sep 29, 2005 09:06 PM |
| Sts Enterprise - Space Shuttle | Hepdog | Pusher Prop Jet Models | 1 | Aug 16, 2005 12:34 AM |
