Old Sep 19, 2011, 12:37 PM
Firefox675 is offline
Find More Posts by Firefox675
Firefox
Firefox675's Avatar
USA, KS
Joined Oct 2005
Turnigy RotoMax 50cc Size Brushless Outrunner Motor
OK, just received an email from HK concerning their Turnigy RotoMax 50cc Size Brushless Outrunner Motor.
I'd be interested on hearing from those who use it or have thoughts on it.
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Spec.
Battery: 12 Cell / 44.4V
RPM: 172kv
Max current: 120A
Watts: 5300w
No load current: 44V/1.65A
Internal resistance: 0.021 ohm
Weight: 1080g
Diameter of shaft: 10mm
Suggested ESC: 180A 12S Compatible
Suggested Prop: 24x12 Majzlik / 26x12 APC
Firefox675 is offline Find More Posts by Firefox675
Old Sep 19, 2011, 03:30 PM
CHUNKSTER is offline
Find More Posts by CHUNKSTER
Joined Mar 2011
How many pounds of thrust?
Mike B
CHUNKSTER is offline Find More Posts by CHUNKSTER
Old Sep 20, 2011, 12:19 AM
ISR_Technology is offline
Find More Posts by ISR_Technology
Mad Scientist=Yes I built it:)
ISR_Technology's Avatar
United States, FL, Leesburg
Joined Sep 2011
I think its intresting to say the least I knew they were coming through a Korean contact I didnt relize they were going to be that big I was under the impression they were going to be like 15cc power, But I have A whole Slew Of Ideas for them
ISR_Technology is offline Find More Posts by ISR_Technology
Old Sep 20, 2011, 04:34 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
I am skeptical regarding the announced no load Io=1.65A @ 44V
If some one could test that value
Kv = 172 rpm/V is a better wording
Mejzlik with an "E" (chinese are not good in orthograph)
Louis
Fourdan is offline Find More Posts by Fourdan
Old Oct 22, 2011, 11:22 AM
Waggas is offline
Find More Posts by Waggas
Joined Jul 2005
Just ran mine up for the first time on a 22x10 xoar gas prop.
It's still in one piece!!!!!!!
Ran up nice and smooth on a hobby wing platinum 120 esc
Haven't taken any measurements or any of that stuff. Hopefully get everything mounted for a fly tomorrow. Seemed have quite a bit of pull even on used batteries. Need to sort then end points out on the throttle.
Need to change the connectors on my wattmeter before I can do any of that stuff.
I'm just using this prop as it was laying about, prob go for a 24x12 when I've checked it all out and measured everything
Cheers
Wayne
Waggas is offline Find More Posts by Waggas
Old Oct 25, 2011, 03:20 AM
rceccleston is offline
Find More Posts by rceccleston
Joined Feb 2009
Cheers
Wayne
How is this motor performing?
rceccleston is offline Find More Posts by rceccleston
Old Nov 14, 2011, 07:20 PM
jfruge is offline
Find More Posts by jfruge
RC Nut!
jfruge's Avatar
Madera, California, United States
Joined Oct 2001
Anyone else try one of these or have any input? I was thinking of getting one.
jfruge is offline Find More Posts by jfruge
Old Nov 16, 2011, 11:34 AM
Waggas is offline
Joined Jul 2005
Haven't had a chance to fly this since my last post. Hopefully the weather will play games as I have a weekend away from social engagements.
Will get some measurements with the wattmeter. Got a xoar 24x12 eprop to try as well.
Cheers
Wayne
Old Dec 01, 2011, 03:46 PM
STATUS is offline
Find More Posts by STATUS
STATUS TUNING
STATUS's Avatar
Australia, VIC, Melbourne
Joined Dec 2010
I finally got round to retro fitting my H9 extra 27% with the 50cc Rotomax, the extra has done some hard yards and is used as a test hack now.
i pulled the DLE55 out for another project and the whole conversion only took around 2hours. (pics below are just showing mock install for testing CG)
setup:
50cc Turnigy Rotomax 172kv and 1080grams (takes dle props and 10mm shaft is tapped for spinners) $182 RRP
CC 160HV Speedy
2 x 5000mah 6s
Mej 23 x 8 (only prop i had at the time) 26x10 on its way
Results on Eflite watt meter 4580watts @ 103 amps after 20sec
CG was perfect with the batteries swapped in place of the fuel tank, and the 2200mah nimh receiver battery under the cowl.
http://www.flyinggiants.com/forums/s...t=68763&page=2
STATUS is offline Find More Posts by STATUS
Old Feb 20, 2012, 07:18 PM
RCH64 is offline
Find More Posts by RCH64
Joined Jul 2007
Our club is building a 16' Giant Quaker as a winter project. We are considering going electric for the power system. In researching our options I found this thread to be quite interesting. Something I haven't seen addressed in the configuration summaries is the type of connectors that are being used with these higher amp loads. Is it best to go the Anderson PowerPole route, or are there other options that meet handle the higher amp loads?
Rick...
RCH64 is offline Find More Posts by RCH64
Old Feb 21, 2012, 08:23 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
To see the widest range of choices in connectors you can go to Hobby King and do a search for bullet connector and see up to 6mm bullets. But I can't seem to post a link to that search result with both terms in it so you'll have to do it yourself.
That won't show the Anderson PowerPoles and I consider them to be a good choice too.
Hobby King is not notorious for accuracy or honesty in advertising so you have to take their words with a grain of salt and look for honest and objective opinions elsewhere.
And the bottom line on 3000W and even 5000W power systems is that we don't need to actually have wire that will handle all of the current in the volts x amps = watts equation because of the way the current actually occurs as it comes out of the ESC and into the motor.
So in the end I would try anything for wiring and connectors that looked like it could handle current and test it to see how hot it actually got. And my personal standard for too hot is usually that I have to be able to keep a finger on it when actually taken to the highest load that I will actually use. That would basically mean 130F/54C or less. And there are some places where I will not even allow that much heat (a battery pack for instance).
I am not a monster electric user or flyer, just a interested lurker. Good luck with it!
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 21, 2012, 10:05 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
FWIW I have used 4mm bullet connectors up to 4.4kW and they have not gotten hot enough to concern me. If you did a 5.5mm or 6mm bullet you will be more than fine. I have also put 4kW-5kW through Deans without problems as well.
scatsob is offline Find More Posts by scatsob
Sold Turnigy 2836 Brushless 450-Size Heli Motor 3700kv snoshoe62 Aircraft - Electric - Power Systems (FS/W) 5 Sep 24, 2011 07:27 PM
Sold turnigy outrunner motor for 600 heli newheliguy81 Aircraft - Electric - Helis (FS/W) 1 Sep 20, 2011 06:18 PM
Sold NIB Eflite Power 15 Brushless Outrunner Motor, 950Kv godofthunder77 Aircraft - Electric - Power Systems (FS/W) 6 Sep 15, 2011 02:01 PM
For Sale Atlas 5030/22 Outrunner Brushless Motor and turnigy 100a Hv bullet proof esc $150.00 kois31 Aircraft - Electric - Power Systems (FS/W) 1 Aug 09, 2011 03:04 AM
Found 480-size 960Kv brushless outrunner motor Redhood Aircraft - Electric - Power Systems (FS/W) 5 Jun 23, 2011 10:58 PM
