Old Sep 19, 2011, 01:00 PM
Charlescd is offline
Find More Posts by Charlescd
RC Paraglider / Sailplanes
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Hobbyking ASK 21 2600mm Glider - good for first glider
I was thinking of purchasing my first glider.
http://www.hobbyking.com/hobbyking/s...lass_ARF_.html
Has anyone any reviews of this glider?
thanks
Charlescd is offline Find More Posts by Charlescd
Old Sep 19, 2011, 02:02 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
I'd say if this is your first RC airplane of any kind, there are probably better more resilient beginner choices instead a fiberglass model, such as the EPO foam version of this model also from HK. If you are already an experienced RC airplane pilot, I'd just get whatever interests you.
Doubletap is offline Find More Posts by Doubletap
Old Sep 19, 2011, 07:32 PM
Charlescd's Avatar
Joined May 2010
Hi,
I've been flying for a few years. I was looking for info on build and how people found it flew.
Old Sep 20, 2011, 08:23 AM
jacky65 is offline
Find More Posts by jacky65
jacky65's Avatar
Switzerland
Joined Jun 2007
You can find infos here -> http://www.rcgroups.com/forums/showthread.php?t=1379056
Note needed to add two holes in the fuselage near the motor for cooling.
My ASK-21 video:
ASK21 EP Glider 2600mm Fiberglass (ARF) HobbyKing (3 min 34 sec)
jacky65 is offline Find More Posts by jacky65
Old Sep 21, 2011, 03:50 PM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
I would like to here the experiences with this plane too......
BarnOwl is offline Find More Posts by BarnOwl
Old Sep 21, 2011, 05:15 PM
Charlescd's Avatar
Joined May 2010
Jacky65,
You can install an brushless outrunner in the glider? On the Hobbyking website, they suggest an inrunner. I suppose you can fit either?
thanks
Old Sep 22, 2011, 04:52 AM
jacky65 is offline
jacky65's Avatar
Switzerland
Joined Jun 2007
Originally Posted by Charlescd View Post
Jacky65,
thanks
Yes this 4S motor http://www.hobbyking.com/hobbycity/s...idproduct=4657 fits and he's lighter than the 3S recommended by HK.
The 3S http://www.hobbyking.com/hobbycity/s..._Inrunner.html is really hot after flight. With two holes drilled in the fuselage for motor cooling it's OK.
Old Sep 22, 2011, 12:20 PM
Charlescd's Avatar
Joined May 2010
thank-you for the link. Are you using the stock propellor size?
Also, which servos?
Sorry for all of the questions but not much info is floating around the net on this model.
Old Sep 22, 2011, 12:38 PM
jacky65 is offline
jacky65's Avatar
Switzerland
Joined Jun 2007
Hi,
Yes. stock propeller.
Servos, motor etc are displayed in the video @ 0:20
Old Sep 24, 2011, 09:12 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I think if you are already an experienced RC hobbyist, there is more happiness to be found in buying the kit versions of these planes and then choosing your own power systems components and even some of the bits and pieces of hardware that are not up to your standards.
It saves you the trouble of finding out what the problems are in the PNP's and RTF versions and going through a bunch or upgrades to fix those.
If the sellers would tell us who the kit makers are on all of the RTF stuff that is hitting the market it would let us better decide what might be a better kit to start with. The quality standards seem to vary widely from one model to another and from one seller to another...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 03, 2011, 11:29 PM
Charlescd's Avatar
Joined May 2010
Well it's almost finished.
Jacky65, how much does your ask21 weigh? I used the motor you suggested and with an 11x7 prop, I'm pulling 400 watts.
Mine weighs in at a little under 2500g. Very far off the flyfly 1600g.
Old Dec 05, 2011, 07:13 AM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Jack
Heartily agree!
Kev
Berkie is offline Find More Posts by Berkie
Old Dec 05, 2011, 12:09 PM
Charlescd's Avatar
Joined May 2010
For anyone looking for a review on this plane, please see:
http://www.bungymania.com/ask21aircadets/index.html
I have not flown mine yet but i agree with the build part of Bernard's article.
Old Mar 28, 2012, 09:01 PM
btdt is offline
Find More Posts by btdt
clearwater fl
Joined Nov 2001
I have bought this glider from hobby king; this is a beautiful glider, but it is not an airplane that some one without building experance needs for a first airplane.
This is only my thoughts; may be someone else can jump in here and give their opinion.
this is not an ARF, it will require some work to get it airworthy.
btdt is offline Find More Posts by btdt
Old Mar 29, 2012, 05:02 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Yep it's not an ARF. Needs nylon screws for tailplane & nylon bolts to replace the wing screws. Front wheel is better off removed and the nose & cockpit needs to be re-inforced with fibreglass before flying.
Kev
Question Electric Motor Choice for a Roedelmodell 4.2M ASK-21 Rudderman98 Scale Sailplanes 19 Jan 23, 2012 10:36 PM
Yippee! Ask for Ricky at Hobbyking Live Chat! RCSwitz18 Vendor Talk 0 Aug 31, 2011 12:36 AM
Discussion New Hobbyking 2.6m fiberglass glider - good for FPV ? i3dm FPV Talk 0 Jul 13, 2011 04:36 PM
Help! Blue Habciht 2600mm Glider ARF stihac Scale Sailplanes 2 Feb 14, 2011 01:43 PM
Discussion ASK-21 Glider Murocflyer Sailplane Talk 2 Nov 26, 2010 05:42 PM
