Old Sep 19, 2011, 04:49 AM
Voguna is offline
Find More Posts by Voguna
Norway, Oslo
Joined Jun 2010
How do you mount your fpv camera without a metal box?
I already have a small FPV camera, but its not a "shield" or a metal box around it, so I cannot mount it. So what have you done to make a box around it or protect it? I want to mount it to my heli, but its not easy to when it is like this.
It is like this one:
http://www.securitycamera2000.com/pr...-Security.html
Voguna is offline Find More Posts by Voguna
Old Sep 19, 2011, 06:46 AM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Use screws and nuts through the 4 corners to attach it to a credit card or gift card. Depending on how you're mounting to the plane you may: use velcro on the back of the credit card, or leave the credit card long and bend it at the proper angle to mount on the plane.
signflyer is offline Find More Posts by signflyer
Old Sep 19, 2011, 06:57 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
for pan only, piece of hard wood hot glued onto a servo case with a hole drilled for the lens to fit through. (Servo flipped so that large control horn screws into ply/hardwood)
from there cam board screwed directly into the hardwood, or squishy 1/2" open cell foam (like what you would wrap a receiver/rx batt with) with a hole for the lens separating the board & cam with a rubber band around it to keep it snug.
Toysrme is offline Find More Posts by Toysrme
Old Sep 19, 2011, 06:59 AM
barok is offline
Find More Posts by barok
barok's Avatar
Canada, ON, Toronto
Joined Apr 2006
this one..http://www.hobbyking.com/hobbyking/s...t_L_Size_.html
or you can sandwich the cam, cut a square plastic, hole in one of the plastic for the cam/lens, use a spacer between the cam and plastic..
barok is offline Find More Posts by barok
Old Sep 19, 2011, 08:02 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Make a custom camera enclosure using Kydex. It's easy and quick.
boopidoo is offline Find More Posts by boopidoo
Old Sep 19, 2011, 10:48 AM
Voguna is offline
Norway, Oslo
Joined Jun 2010
What Kydex do you recommend? Is it like a shrink tube?
Old Sep 19, 2011, 11:21 AM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
I'm also curious about Kydex, how do you give it shape exactly and does it turn solid?
malcr001 is offline Find More Posts by malcr001
Old Sep 19, 2011, 12:35 PM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Kydex is usually sold as plastic sheets in various thickness. It's hard plastic but is very easy to shape when it's hot. I usually just bend it in simple shapes but more complex designs is possible if you heat it in an oven. Search the forum for kydex and you will find my camera enclosures.
Old Sep 19, 2011, 12:47 PM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
I use this:
Source: http://www.blueskyrc.com/index.php?m...22026a55f83633
IceWind is online now Find More Posts by IceWind
Old Sep 19, 2011, 02:05 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I use a foam ball.
pictures tell the story. I use a larger foam ball for board camera.
I also use shrink wrap and glue it to the mount.
whakahere is offline Find More Posts by whakahere
Old Sep 19, 2011, 04:47 PM
2^p - 1
signflyer's Avatar
Joined Feb 2003
photos
Question How do you remove metal particles from a motor magnet? Tom Z Micro Helis 12 Sep 25, 2011 04:56 PM
Discussion How do you hang your plans? Graham Lane Dock Talk 16 Sep 18, 2011 09:37 AM
Discussion How are you mounting your Contour HD camera? BGauweiler FPV Talk 0 Sep 11, 2011 07:15 PM
Discussion Where do you like to mount your still camera? vvV FANG Vvv Aerial Photography 16 Jul 20, 2011 03:14 PM
Discussion Show us how you mount your GoPro for FPV! timnilson FPV Talk 42 Apr 10, 2011 02:41 AM
