Old Sep 18, 2011, 09:39 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Cool
Micro F-5/T-38 Parkflyer Build
This is a simple pusher jet I built in a single evening after work, with the aid of a few beers and a pre-cut toystore sheeted foam glider.
It is powered by the following (all from HobbyKing):
Caseless OrangeRx 6ch 2.4Ghz receiver
Zippy 2s 350mAh 20C LiPo pack
5g Hextronik 2000kv outrunner
Super Simple 8A ESC
GWS 4040 prop
4.3g servos
Essentially, what I had in my parts drawer. The battery is held in place with a rubber band for the time being until I can maiden it and find out if the CG is correct. At the moment its set for around 30% of the wing chord at the root.
Control is by simple tailerons with 0.020 music wire with Z-bends, heatshrink & CA for linkages. Contorl horns are the micro 'pin style' with the locator pin shaved off for flat-mounting straight to the tailerons using CA.
Enough talk, heres the finished airplane:
Its not totally scale (mainly wings) but thats to be expected of a model this size, especially as its derived from a toystore free-flight glider. To be honest thats the best part of it; the ability to buy the airframe for a dollar or two and simply fit your gear to it after assembly. Its already painted, and its already reasonaly airworthy.
Anywho, thats it! Maiden flight is whenever I get a chance, so stick around guys. As always any tips or suggestions much appreciated.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Sep 18, 2011, 09:58 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Way too windy to fly much of anything today, so I instead have charged up some batteries for when its calmer. I also weighed the plane, and with a Flightmax 2s 350mAh lipo pack it comes in at 73g/2.6oz - certiainly not a featherweight but it should perform reasonably well on the little 5g outrunner and GWS 4040 prop.
Hopefully next time I write it'll be of how well she flew on the maiden!
Cheers til then - boingk
Old Oct 17, 2011, 09:58 PM
ara25demayo is offline
Find More Posts by ara25demayo
México, MOR, Jiutepec
Joined Oct 2011
im making a 20% of parkjet plans and is 5 inch wigspan and an awg of 6.5-7 gr with plantraco stuff
ara25demayo is offline Find More Posts by ara25demayo
Discussion Is there a 90mm F-5, F-20, or T-38? demetrius Electric Ducted Fan Jet Talk 11 May 10, 2016 12:03 AM
Build Log MarkaZ 450 -micro full fuse 3 Ch Parkflyer-WITH VIDEO AND BUILD LOG !! Markus A. Foamies (Scratchbuilt) 31 Mar 27, 2016 10:24 PM
Discussion T-38 talon/F-5 5" EDF Wingnut31 Foamies (Scratchbuilt) 12 Feb 11, 2011 11:13 AM
Discussion Steve Shumate's T-38 / F-5 EDF Build therealhiphop Foamy EDFs 109 Oct 13, 2006 08:18 PM
For Sale gripen & t-38 parkflyer cut out ready to build blue foam jazsop Aircraft - Electric - Airplanes (FS/W) 7 Jun 09, 2005 11:22 PM
