Old Sep 18, 2011, 07:45 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Glue for bonding nylon and aluminium? (Skywalker PT)
I'm about to make a PT for which I'll use a HS65MG as a tilt servo and a GWS S125 1T 2BB as a pan servo. I'm going to make the PT along the same method as workshops excellent servo-killer-mount: http://www.rcgroups.com/forums/showthread.php?t=1373666
However since the pan servo arm is in nylon I need a good glue to make a good durable bond between it and the aluminium frame (see picture). The tilt servo has an aluminium arm and is glued and attached as per workshops guide using JB Weld and steel pins (or M2-screws). I will also use screws to attach the pan servo arm to the aluminium frame but I'd like to use a glue as well.
Any ideas?
boopidoo is online now Find More Posts by boopidoo
Old Sep 18, 2011, 07:59 AM
Questionable judgement
bracky72's Avatar
Charles Town, WV
Try goop or similar product.
bracky72 is offline Find More Posts by bracky72
Old Sep 18, 2011, 08:59 AM
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
http://tinyurl.com/4y2vabx
Gary Evans is offline Find More Posts by Gary Evans
Old Sep 18, 2011, 09:46 AM
Mesa, Arizona
Joined Nov 2006
Actually I would feel a lot safer just putting two screws through the arm and bracket.
Old Sep 18, 2011, 09:54 AM
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
Thats what I was thinking too. You dont want the glue getting loose and suddenly your cams facing straight down at the ground. If you really want to use a glue then try epoxy. Hard stuff to work with but very strong.
malcr001 is offline Find More Posts by malcr001
Old Sep 18, 2011, 11:41 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
As I wrote I will use both glue and screws, not just glue. I was thinking of using 4 M2 screws, the holes are shown in the model. The glue is an extra bond but maybe it's uneccessary?
Old Sep 18, 2011, 11:53 AM
Joined Mar 2009
In theory, epoxy glu is ok for aluminum, but ideally aluminium surface should be prepared :
Here's a how-to from an epoxy manufacturer :
http://www.boatdesign.net/forums/att...inium-deck.pdf
flipflap is offline Find More Posts by flipflap
Old Sep 18, 2011, 12:26 PM
malcr001's Avatar
Joined Nov 2007
If I was boopido I wouldent be using glue at all, two screws on the servo horn with loctite on should be fine.
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
For the most part, nothing sticks to solid nylon. Just screws will work fine.
ian
Daemon is offline Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Sep 18, 2011, 02:27 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Thanks for your input guys. I think this PT will be quite nice. It's intended to be mounted underneath (embedded in the fuselage) either a Skywalker or a custom built delta wing. It will pan +/-180° and tilt +/- 90°. The tilt servo is used to rotate the camera from inside to outside the fuselage.
Old Sep 18, 2011, 07:16 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
ditch the nylon control arms for aluminum & tig weeeeeld
Toysrme is offline Find More Posts by Toysrme
Old Sep 18, 2011, 10:57 PM
United States, TX
Joined Oct 2010
+1, if you are cool and have a tig
Or just screws and loctite as was mentioned. Adheasives with Nylon is a no, no. This resistance to chemicals is one of its main attributes.
If you were in the states I would tell you to send the parts to me and Ill tig them. Bet you can find someone local to do if for you if you look.
Slaphappysamy is offline Find More Posts by Slaphappysamy
Old Sep 19, 2011, 12:42 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Only the top mount is nylon but not possible to replace as I haven't found a compatible aluminum arm for the GWS servo. The tilt arm is aluminium and will be epoxied with JB Weld and M2-screws which I think will be sufficient. I do have a the possibility to TIG weld doesn't that risk to warp the construction due to heat? These parts are very small after all.
Old Sep 19, 2011, 02:00 AM
Hawaii
Joined Dec 2008
Just FYI, epoxy forms a mechanical bond. So if you form little pockets for the epoxy to grab, it'll "stick". It would be like forming dovetails or similar, into which the epoxy will mold itself.
The rougher the surface, the better. As long as it doesn't compromise the structure.
It's very important to avoid disturbing the bond until it's thoroughly cured.
The screws will definitely do the trick. The epoxy will help make it that much more secure.
Windbreaker is offline Find More Posts by Windbreaker
Old Sep 19, 2011, 03:06 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
My plan is to glue the epoxy and servo arm and when it's cured I'll drill some holes for the screws and apply a little more epoxy around the screws. That should make for a really durable mount. If only I could find a aluminium servo arm for the GWS S125 servo.
Yippee! New FORTAL aluminium tail gear replacement for TT T-Rex 500 and TT Clones !!! lothar2048 3D Electric Heli Flying 1 Sep 19, 2011 01:40 PM
Question glue for bonding teflon push rod tubes bootsause Hand Launch 8 Mar 25, 2010 07:49 AM
Discussion De-bonding Crazy Glue Fox7 Foamies (Scratchbuilt) 6 Mar 12, 2010 01:06 PM
Question best glue for nylon pushrods planepainter Sailplane Talk 7 Jul 11, 2009 02:30 PM
Question Preping Aluminium/basa for glue? evermax The Builders Workshop 5 Oct 09, 2005 09:32 AM
