Old Sep 17, 2011, 08:45 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Frsky receiver not working with brushed motor
Don't know if anyone else has seen this. It doesn't make sense to me, maybe someone knows why. I dug out an old trainer plane of mine for a friend that is learning to fly. It has a brushed motor/brushed esc designed to handle lipos and I'm running with a small 2S lipo.
The old receiver was FM but I wanted to try my Frsky rx in it.
Well all channels worked except the esc/motor (ch3). I got proper servo movement but no response from the motor. Took me a long time as I figured it was the esc, then possibly the old brushed motor but swapping them out did nothing, no motor response.
Then went back to the old FM receiver and everything functioned.
Anyone know why? It seems crazy to me, the Rx should be giving the same signal to the esc, but maybe not ?
rotagen is offline Find More Posts by rotagen
Old Sep 17, 2011, 08:49 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Make sure the FrSky reciever is not in "High Speed" mode.
The LED should flash slowly if you turn on the receiver without turning on the transmitter. If it flashes quickly then press the bind button for 3 seconds to change modes.
(This assumes you are using a D8 telemetry receiver)
Pat MacKEnzie
pmackenzie is offline Find More Posts by pmackenzie
Old Sep 19, 2011, 12:22 AM
c2po is offline
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Probably because old FM receivers usually output 5V PWM signal, and FrSky receiver has 3.3V PWM output (as also many other modern receivers).
I bet your brushed ESC doesn't like it. Look here for more info.
c2po is offline Find More Posts by c2po
Old Sep 19, 2011, 05:05 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Old brushed ESC was probably made to match old FM receiver.
Just stay with old FM radio.
To fly with 2.4, change motor and ESC to modern brushless.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Help! Blade SR120 - main motor not working ulogix Electric Heli Talk 4 Apr 24, 2011 03:07 PM
Help! Syma S006 front motor not working helimark112052 Coaxial Helicopters 2 Mar 07, 2011 03:18 PM
Help! ESC not working with Futaba Receiver. ovajay Power Systems 10 Oct 07, 2006 07:25 AM
electrifly receiver with 30a esc not working need help maeu2003 Radios 4 Jul 16, 2004 03:47 PM
