Old Sep 17, 2011, 06:06 PM
Jimmy Rc
Joined Nov 2004
esc that can handle 4 servos
I have a dr foamie f15 that I tryed to run 4 hitec 55 servos on. The esc I had was a grayson hobbie 50 amp it said to run a seperate ubec and disconnect red wire from this esc which I did. But after installing ubec servos went crazy and cannot get any range. Uninstalled ubec and went back to 2 servos and is fine. I am running futaba 8u comp radio on 72 mhz has any one else had these problem and what did you do to solve it? I read somewhere that 2.4 is better becuase of this issue. Running 3s 2200 mah lipo.
Thanks for any info
Jimmy
newelectro is offline Find More Posts by newelectro
Old Sep 17, 2011, 06:15 PM
United States, NV, North Las Vegas
Joined Sep 2009
How far is the BEC from the Rx? back when I ran 72mhz I had to keep the BEC as far from the receiver as possible or I lost range or had glitching(or both) another thing to try is a simple RF choke.
Any ESC with a 3amp switch mode built in BEC will be fine for your needs.
shultz is offline Find More Posts by shultz
Old Sep 17, 2011, 06:52 PM
Jimmy Rc
Joined Nov 2004
Had ubec and esc about 3 to 4 inches from rec I think. Thanks for info
Old Sep 17, 2011, 07:04 PM
Joined Sep 2009
Depending on the BEC 3 or 4 inches would have never been enough for my Futaba 9C's with any receiver I owned from futaba or hitec... try and move it away at least the length of the lead off the BEC(6-8 inches average) If you still have problems add the RF choke(not a bad idea anyway) and maybe even use a servo extension if you could get it farther away from the Rx than the BEC lead will allow.
Old Sep 17, 2011, 11:38 PM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
You can use a Turnigy (or whatever they are calling them this week) with a 3A SWITCHING BEC. This is the same as a Hobbywing.
http://www.hobbyking.com/hobbyking/s...ontroller.html
or
http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html
The Grayson appears to be linear BEC.
If you are in a hurry here's one branded as EMAX:
http://www.headsuprc.com/servlet/the...Amp-ESC/Detail
flydiver is offline Find More Posts by flydiver
Old Sep 18, 2011, 02:35 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
I had similar problems when I was on 35MHz (UK frequency). As shultz has said, 3 to 4 inches separation might not be enough to avoid interference, and I believe switching BECs are more likely to interfere than linear ones. My solution was to use opto ESCs and separate NiMh receiver packs, plus moving the ESC, motor, battery, and their leads as far away as possible from the receiver, servos, and their leads.
Since going over to 2.4GHz I've been able to replace all my NiMh receiver packs with stand-alone switching BECs, with no problems whatsoever.
abenn is offline Find More Posts by abenn
Old Sep 18, 2011, 07:03 AM
Jimmy Rc
Joined Nov 2004
Thanks for info will be going 2.4
JImmy
Old Sep 18, 2011, 08:37 AM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
JImmy
Do your homework. With 4 servos you still need a BEC or switching BEC/ESC.
Spektrum has this condition called 'brown out'.
Question Suggestions for esc that can handle 10s lipo. Charlescd Electric Plane Talk 16 Mar 14, 2011 01:50 PM
Can the ICS-400 ESC handle 4 servos? pc_pilot GWS (Grand Wing Servo) 5 Dec 15, 2003 09:53 AM
Can this ESC handle 4 servos? pc_pilot Parkflyers 10 Dec 14, 2003 02:46 AM
Are there ESC`s out there that can handle 4 servo`s? kushal_22 Parkflyers 7 May 01, 2002 02:15 PM
Lightest ESC that can handle 3 servos V-Raptor Parkflyers 4 Oct 23, 2001 12:15 PM
