Old Sep 17, 2011, 04:10 PM
TravisNeedham is offline
Find More Posts by TravisNeedham
Joined Sep 2011
Help!
E-flite PNP 450 shaft replacement
Hey all,
I'm a bit of noob, so I apologize in advance for my ignorance, but I was wondering if someone might be willing to help me figure out how to replace the shaft on my E-flite PNP 450 outrunner (EFLM7210). I believe I have found the correct shaft (EFLM72101), however it seems to be out of stock everywhere I look. I have placed an order with Horizon Hobby anyway, but I don't know how long it will take to actually get one. I have searched all over google and can't seem to find a guide for the actual replacement. It was easy to get the motor apart, but the shaft won't budge. I am afraid to use a TON of force, because I don't want to break anything. I think there must be something I am missing, one last thing I need to do before the shaft will come loose. Can anyone help? I'm hoping someone can lead me to a better place to get a new shaft, as well as a guide to the shaft replacement. Thanks!!
Travis
TravisNeedham is offline Find More Posts by TravisNeedham
Old Sep 17, 2011, 04:28 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
The basic's:
http://www.rcgroups.com/forums/showthread.php?t=1126102
As bad as your shaft is bent I'd either push it out from the back of the bell OR cut the bent part of the shaft off flush with the bell and then push out the rest from the front.
If you don't want to wait this shaft will fit
http://www.valuehobby.com/product_de...39&item_id=250
shultz is offline Find More Posts by shultz
Old Sep 18, 2011, 10:00 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
What shultz said! Cut that off, stand the magnet housing over a deep socket wrench, or piece of small tubing, and press the shaft down into the tubing. It is pretty much normal for a shaft to slide out of the inner bearing races without too much trouble but to be a press fit in the magnet housing. This thread has the details on making your own shafts, cutting them to lenght, and getting snap ring grooves and flats in the right places:
http://www.rcgroups.com/forums/showthread.php?t=1240725
There is some info in that thread on where to get shaft material too, here is a place that has a good assortment of shafts at decent prices and that ships cheap too:
http://www.headsuprc.com/servlet/the...fts/Categories
Jack
jackerbes is offline Find More Posts by jackerbes
Old Sep 24, 2011, 03:25 PM
Joined Sep 2011
Thanks for the help guys. I purchased 3 shafts from Shultz's link, but unfortunately they don't fit either. They are 4mm shafts, and I need 3.17mm. I have a 450 PNP or BL450, so it takes a slightly smaller shaft than the normal 450 outrunner. They still seem sold out everywhere, but I think I finally found one here. They'll probably send me an e-mail after I order saying that they are actually out of stock We'll see!
Old Sep 24, 2011, 04:06 PM
shultz is offline
Joined Sep 2009
you must have received the wrong shafts... the shafts I linked SHOULD HAVE BEEN 3.17mm... man sorry about that.
Even the motor specs call it 3.17mm
http://www.valuehobby.com/product_de...29&item_id=135
Edit:
Contact value hobby... they should make it right.
Old Sep 24, 2011, 04:16 PM
Joined Sep 2011
Yeah, strange. Does it have anything to do with the extra number on the end of the title? In the parenthesis? (28-36) vs. (35-30)
Old Sep 24, 2011, 04:20 PM
shultz is offline
Joined Sep 2009
In both of the links I see (28-36)... where are you seeing 35-30
Old Sep 24, 2011, 04:22 PM
shultz is offline
Joined Sep 2009
is this the shaft you ordered?
http://www.valuehobby.com/product_de...39&item_id=251
It is 4mm...
Joined Sep 2011
http://www.valuehobby.com/products.php?category_id=39
Here there are two shafts listed for the 450, and they look exactly the same except those numbers in the parens.
Old Sep 24, 2011, 04:25 PM
Joined Sep 2011
No, that's not the one I ordered. I DID order the other one you first linked. I think they simply sent me the wrong one. I am e-mailing them now. How could you tell that that one was 4mm vs the other one 3.17?
Old Sep 24, 2011, 04:26 PM
shultz is offline
Joined Sep 2009
The numbers are the difference... the 2836 is 3.17mm the 3530 is 4mm.
Old Sep 24, 2011, 04:27 PM
Joined Sep 2011
But how did you know that from the given (or lack there of) descriptions?
Old Sep 24, 2011, 04:28 PM
shultz is offline
Joined Sep 2009
I'm sure they will make it right... I have a couple of the 3530's... I know they are 4mm
Old Sep 24, 2011, 04:31 PM
Joined Sep 2011
I see. Cool. Thanks for your help. Have you been pleased with the build quality in general from valuehobby? Their prices are fantastic! It makes me want to go on a shopping spree But I'm worried about things like servos, motors, and ESC's going out during flights due to poor build quality. Should I be worried, or not?
Old Sep 24, 2011, 04:42 PM
shultz is offline
Joined Sep 2009
The motors are OK quality wise... I've never had any problems myself... may need to replace the bearings sooner than a big name brand but that's cheap and simple. As for ESC's again NEVER had any problems... I tend to run about 15-20% under spec's so I'm never pushing them to the max. Servo's... in the smaller stuff like 9gram size I've had BETTER luck with the cheap stuff than Parkzone or Hitec... that's not saying much as I've only had one parkzone and one Hitec servo fail in the 5 or so years I've been flying electric.
all in all I'm happy with the cheap stuff on foamies and small park flyer's... If were talking a plane I put a bunch of time into building then it's getting the best stuff I can afford
Sold repost hacker002 Aircraft - Sailplanes (FS/W) 0 Aug 20, 2011 06:05 PM
Question e flite power 10 shaft replacement serairdog Electric Motor Design and Construction 3 Jul 08, 2011 08:20 PM
Help! Prop shaft removal on E-Flite 450 Thermalin Electric Plane Talk 11 Jun 04, 2011 07:38 PM
Sold E-flite Taylorcraft 450 PNP (with park480) $140 local Northern Virginia kevinb120 Aircraft - Electric - Airplanes (FS/W) 4 Mar 09, 2011 10:37 AM
Sold E-flite 22-Amp BL ESC Combo with the E-flite park 450 pnp 890kv outrunner. hobby-plane-rc Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2008 10:13 PM
