Old Sep 17, 2011, 04:50 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo - MiniY6 - V1.0 - Online at www.MyRcBuild.com
EDIT:
Now available at www.MyRcBuild.com
HERE
Big tanks to the owner of myrcbuild.com and "Cutter" of the project. "LUIS" ..
Hi all,
As some people ask me about a small Y6 version of my quad, i have started to brain storm with them and now i move all that to the proper thread...
Here is what it look so far:
High Res: Here and Here
This is measure with HK 10g
http://www.hobbyking.com/hobbycity/s...idproduct=5358
I want to know witch motor people want to use and the hole patern.
For controller there is 2 mounting hole right now 30mm and 45mm
Feel free to ask anything..
18 October 2011
Here are some Picture i took of the thing today
Some new pictures with Paris V4.0 board (WM+ and Nunshuck)
High Resolution
Here and Here
High Resolution
Here and Here
High Resolution
Here and Here
Dialfonzo is offline Find More Posts by Dialfonzo
Old Sep 17, 2011, 04:57 PM
nasgul is offline
Find More Posts by nasgul
nasgul's Avatar
United Kingdom, Wales, Gwaun-Cae-Gurwen
Joined Mar 2011
lol, nice, feel a little bad contaminating the quad thread with all the y6 questions, so a proper thread is genius!
the 45mm controller holes is for kk board, and 30mm for cc, yes?
do you think the u/c will be stable enough?
nasgul is offline Find More Posts by nasgul
Old Sep 17, 2011, 05:09 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I only have MultiWii based board.
Most of them have a 45mm footprint.
Sorry for that but i don't know what you mean by "u/c".
(Englis is not my first language.. lol)
Old Sep 17, 2011, 05:12 PM
nasgul is offline
nasgul's Avatar
Joined Mar 2011
sorry eric, u/c short for undercarraige, or landing gear if you prefer. measured my kk board, 45mm holes on it, so all good
Old Sep 17, 2011, 07:05 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
looks great I may be grabbing a quad from you soon!
daign is offline Find More Posts by daign
Old Sep 18, 2011, 07:16 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes it have ton of u/c space...!
The "Prop" are draw at 45mm from motor mount. To see if they clear the ground.
And i will post another picture showing how much space is left from the prop to the ground.
Old Sep 18, 2011, 07:22 AM
nasgul is offline
nasgul's Avatar
Joined Mar 2011
nice one eric, look forwards to checking that out when i get back from work, lol
Old Sep 18, 2011, 07:50 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ok... Here it is..
I can even make the landing Sorter...
The second picture is the "Lock" that i have think for the landing.. is it clear enough ?
Old Sep 18, 2011, 08:51 AM
blackmoon is offline
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
Yup LG shorter is a plus, for me.
I'm going to use these babies in my next build (a friend has them in his micro quad and they are a blast).
https://www.hobbyking.com/hobbyking/...dProduct=14739
M2M lentgh ?
(Vraiment une super frame, elle sera super sur mon Y4, j'adore )
Thx
blackmoon is offline Find More Posts by blackmoon
Old Sep 18, 2011, 08:58 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
M2M lentgh ?
Thx
Merci...
Les moteurs que tu as postÚ sont vraiment bon ?
Je recherche qqch pour remplacÚ les 10g que j'ai...
C'est plus gros, vous avez fait des test de consomation ?
Ok.. if nobody complain about lower landing gear, i will make the change..
Old Sep 18, 2011, 12:15 PM
flying beam
blackmoon's Avatar
Joined Apr 2008
The motor I listed is very good with 8x4 props.
I saw in your post here http://www.rcgroups.com/forums/showp...&postcount=259, that M2M will be +/- 20 cm.
A little short for 8x4, I think if you scale it a little (maybe 23-25 cm M2M) we'll have more choice in different engine/props combos.
If not, I'll go with the 10gr on this frame, because I really want a mini Y4 .
Old Sep 18, 2011, 12:21 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
8" prop will not do it.. LOL
If you want a Y4 with 8" prop you could look at that one:
http://www.rcgroups.com/forums/showp...6&postcount=35
You should have lot more distance between prop i think.. even make it wider... will need much wider.
No ?
Old Sep 18, 2011, 01:42 PM
flying beam
blackmoon's Avatar
Joined Apr 2008
No ?
I didn't make any calculation just did think it would pass with 25cm M2M.
Thank you for the link, I'll maybe go with that one for the motors I listed.
And keep this one for the 10gr, I have for of them buggers waiting in my box
Old Sep 18, 2011, 04:41 PM
nasgul is offline
nasgul's Avatar
Joined Mar 2011
Ok... Here it is..
looks good to me eric, should hold good! only just got in from work, lol!
Old Sep 18, 2011, 05:56 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
I like the leg length you show above but as long as it works with the HK 10g with prop adapters making them shorter is fine with me.
Dolby is offline Find More Posts by Dolby
Discussion DiaLFonZo - QuadMini & TriMini Dialfonzo Multirotor Talk 745 Mar 24, 2015 11:22 AM
Discussion DiaLFonZo-Copter TrinitY Quad V2.0 Dialfonzo Multirotor Talk 316 Mar 12, 2012 05:46 AM
