Old Sep 17, 2011, 01:49 AM
Graham Lane is offline
Find More Posts by Graham Lane
That's my REAL name!
Graham Lane's Avatar
Italy, Umbria, Marsciano
Joined Jun 2011
How do you hang your plans?
I've got four huge sheets of plans for my ship, a Seabex One, and wondered if anyone has a magic idea for hanging them conveniently so one can be brought to the front quickly and easily.
Graham Lane is offline Find More Posts by Graham Lane
Old Sep 17, 2011, 04:07 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
i just used sticky tape and a wall when building celestia
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Sep 17, 2011, 04:20 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
In Drawing offices the plans were hung on pegs fastened to a backing plate, The Drawings had a self adhesive strip with a series of slots punched in the edge.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Sep 17, 2011, 08:30 AM
Raceguy is offline
Find More Posts by Raceguy
United States, FL, New Port Richey
Joined Aug 2010
Hi Graham
I had the same problem with my plans. I did not want to put holes in the wall (well, another person said I did not want to put holes in the wall) and tape could also have caused damage (so I was told). I now have 2 3X4 foot plans, one on top of the other, hanging on my wall using 3M Reusable Adhesive hooks.
I got the kind with the narrow metal hook, not the one shown. I needed the narrow metal hook to fit the binder clip to hang the plans.
Since this is in my garage I found the the plans would be blown around when the door was open and lifting one plan to see the other was not working either. Since I have 2 plan pages I got 4 1/4 diameter wood dowels 4 foot long and 16 feet of 3/16 ID clear PVC tubing. I then cut the tubing in 4 foot lengths then split the tubing along the entire length with a sharp blade.
I rolled a dowel in the top and bottom of each plan just enough to cover the dowel then slid the split tubing over the dowel. The tubing holds the plan on the dowel the entire length. The dowel and tubing protects the plan edge, gives the plan page weight and makes it somewhat rigid.
I then placed three binder clips on the tubing and slid the ring of the binder clip on the wall hook. The plans do not blow around in the wind and I can now lift the top page to see the one beneath or easily lift the top one off completely.
I hope this helps.
Ed
Raceguy is offline Find More Posts by Raceguy
Old Sep 17, 2011, 08:46 AM
mike_victoriaBC is offline
Find More Posts by mike_victoriaBC
victoria, bc
Joined Oct 2003
Tape/mount them to the light sign board material available at a plastics shop or a graphic sign maker - only problem can be long exposure to sunlight - eventually the linework will fade. I'm attempting to scan the sheets to jpg files - can then window areas and print off at 11x17 size and still retain the originals.
mike_victoriaBC is offline Find More Posts by mike_victoriaBC
Old Sep 17, 2011, 11:42 AM
Joined Jun 2011
I was thinking of putting two strips of batten either side of the top edge and screwing through but I like the dowel method.
Scanning is not really an option unless you have a graphics studio. However, you can PHOTOGRAPH your plans, in high resolution, and then download to your computer. Great if you have a PC next to your bench. I don't.
Old Sep 17, 2011, 12:32 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
I put two long, straight peg board holders at the correct width then hang the sheet over the tools etc. on the board with two wooden spring clothes pins with a hole drilled in one leg.
420TEE is offline Find More Posts by 420TEE
Old Sep 17, 2011, 03:24 PM
Raceguy is offline
Joined Aug 2010
My plans were for a smaller scale so I took them to FedEx (was Kinko's) here in the US. They scanned and printed them at the enlarged size I needed. I also had them save the scan to a thumb drive so I can print sections at home or have them do a full reprint should my enlarged plans fade.
Ed
Old Sep 17, 2011, 05:20 PM
victoria, bc
Joined Oct 2003
I did a bunch of work for a designer group that have a large copier/scanner - owe me quite a bit so hopefully can scan the plans there!
Old Sep 17, 2011, 05:26 PM
Sweeper Nut is offline
Find More Posts by Sweeper Nut
Sweeper Nut
Sweeper Nut's Avatar
Joined Apr 2007
I wish I had room to hang plans..
Sweeper Nut is offline Find More Posts by Sweeper Nut
Old Sep 17, 2011, 05:41 PM
desron48 is offline
Find More Posts by desron48
ADM. 48TH FLEET
oxnard ca.
Joined Jul 2007
i don't hang mine up eather......i lay them out on a seperate bench....
joe
desron48 is offline Find More Posts by desron48
Old Sep 17, 2011, 06:10 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
When I worked at Harken they had drawing holders mounted on the walls all around the office. I don't know where they got them. All they were was an aluminum channel about three feet long with a bunch of plastic rollers trapped inside. You just pushed the upper edge of the print up into the rollers and they grabbed onto the paper. To release, you just slide the print sideways and it would fall out. It would easily hold several sheets. Of course, these would have to be mounted to the wall, but when the prints are not in it it's only a strip about two inches high and three feet wide.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Sep 17, 2011, 07:11 PM
Cliff Hanger is offline
Find More Posts by Cliff Hanger
California Desert... 7 miles from nearest town
Joined Jan 2010
I mounted a 2"x1/4" flat bar of steel 10' long on the wall using counter sink screws attaching to wall studs.
I have several earth magnets with large spring paper clips that I use to hang the plans I am using. Three or four per sheet so they don't rip from their own weight.
Cliff Hanger is offline Find More Posts by Cliff Hanger
Old Sep 17, 2011, 07:28 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Ditto, a steel bar screwed to the wall with magnets holding up the plans.
green-boat is offline Find More Posts by green-boat
Old Sep 18, 2011, 12:53 AM
Joined Jun 2011
Magnets! Brilliant idea. I have a load of them, removed from my slot cars, so that's well worth considering. Thanks.
I'm thinking of forming a loop of string or cord down the back and up the front of each sheet with a strip of dowel along the lower edge. A little pulley at the top and I can roll up the front plan to reveal the one behind, and so on, like a roller blind. Sounds complicated but not actually.
Discussion What do you do when all your planes are broken? FeiJi Beginner Training Area (Aircraft-Electric) 29 May 21, 2012 03:14 PM
Discussion Enlarge your plans as big as you want! MUTCAKE Foamies (Scratchbuilt) 14 Sep 19, 2011 08:32 PM
Poll How do you operate your transmitter? slowone096 Electric Plane Talk 18 Apr 16, 2011 11:02 AM
Discussion How do you weather your WW1 aircraft? Gunnar15 Scale Kit/Scratch Built 6 Mar 21, 2011 10:54 PM
Question How do you Hang your plane in the House? jaskel Electric Plane Talk 32 Oct 09, 2009 06:52 AM
