Old Sep 16, 2011, 07:26 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Video
Rich Uravitch 52" OV-10 Bronco
Here is my 52" Rich Uravitch OV-10 Bronco converted to electric power.
Specs:
wing span 52.5"
weight 8lbs
motors Hacker A30 1100kv's
props APC 11/7
ESC Castle Phoenix firebird 36amp's
Battery pair of 11.1v 2200mah 25C
I added extra weight to see how she will fly because I wanted to add retracts over the winter. First couple of attempts to maiden the Bronco she failed to rotate. There has been a lot of stories that the wing was built to small and you had to get her below 6.5lbs to fly and even you had to fly it at full power most of the time to keep it in the air. The only thing I needed to do was to get the nose to sit up a little higher and she took to the air just fine. With this power setup I can fly it at half throttle even in the turns. The maiden flight was last Sunday and the video below is the 11Th flight.
Broncoflight11 (5 min 23 sec)
BadLemon is offline Find More Posts by BadLemon
Old Dec 09, 2011, 04:53 AM
elecwhit is offline
Find More Posts by elecwhit
Joined Aug 2009
Ov-10 52" cg
Great looking aircraft. I have a quick question for you... I have a 52" OV-10 in Coast Guard markings, 2 ea O.S. 35's What is the CG for this aircraft?
Thank you very much for your time.
elecwhit is offline Find More Posts by elecwhit
Old Feb 09, 2012, 08:01 AM
dfsmith is offline
Find More Posts by dfsmith
United States, WI, Mukwonago
Joined Nov 2011
ov 10 retracts
I just purchased the Ov 10 and I will build it electric I'm looking to install retracts. did you install retracts on yours yet and if so what type did you use?
dfsmith is offline Find More Posts by dfsmith
Old Feb 09, 2012, 09:33 AM
elecwhit is offline
Joined Aug 2009
Ov-10
Hi,
Mine came with fixed landing gear, I'm going to fly without having retracts installed. Have not maidened my OV-10 yet, getting motors fine tuned before I even attempt to get off the ground. I have two OS25's installed and getting them synced has been a chore. Good luck on your build.
Old Apr 01, 2012, 11:44 PM
czirh is offline
Find More Posts by czirh
Use your imagination....
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Hi BadLemon;
I love twin prop aircrafts. Your Bronco nice and beatuful video.
Some photos, turboprop Bronco, Jet-Power 2011 Germany..
Regards
Cem
czirh is offline Find More Posts by czirh
Old Apr 02, 2012, 10:32 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Hi Cem and Thanks
Looks like we have the same taste in planes! I was the one that posted the pictures of the different tails sections on the Ta-183 Huckebein build you are doing.
As for the Bronco I installed electric retracts and I should have the Bronco back in the air this weekend. I'll post another video.
Good Luck with your Ta-183 maiden.
Originally Posted by czirh View Post
Hi BadLemon;
Regards
Cem
Old Apr 02, 2012, 10:35 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Cem
I also see pic's for that awesome turboprop Monster Bronco! Have you seen any video posted on it? I would like to see that!
Old May 15, 2012, 09:21 AM
Brian C is offline
Find More Posts by Brian C
Joined Nov 2004
Hey Bad Lemon,
Great job on converting your OV-10 to electric. I've been considering building mine electric as well. Can you tell me where you placed the ESC's and batteries for yours? Looks like she flys well even with the small wing, your landing was beautiful!
Brian C
Brian C is offline Find More Posts by Brian C
Old May 15, 2012, 10:49 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Hi Brian
Thanks for the comments! It was a fun and easy conversion the ESC's are in the nacelles on the back side of the firewall. I ran power leads through the wings to the Fuselage the batteries are located right under the wing. I was hoping the batteries where farther forward for easy excess but that is where she balanced out at. I'm almost finished with the retract modification, I'm installing E-Flite electric retracts. Here is a post I put on RCU with pic's showing where the ESC's and batteries are located. Also here is a thread here on Rcg about converting the OV-10 to electric that will help.
Good luck with your build
Doug
http://www.rcuniverse.com/forum/m_10758810/tm.htm
http://www.rcgroups.com/forums/showt...ighlight=ov+10
Originally Posted by Brian C View Post
Hey Bad Lemon,
Brian C
Old Jul 13, 2012, 12:28 PM
fordman is offline
Find More Posts by fordman
RR Tootie Toot Toot
United States, MI, Jackson
Joined Jan 2005
What type of electric retracts did you use?
fordman is offline Find More Posts by fordman
Old Jul 13, 2012, 12:41 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I used the E-Flite 25-45 90 degree mains and 105 degree nose retracts. So far this Summer I've got 30 flights and the gear work like new. I'm very happy with them.
Old Aug 11, 2012, 10:11 AM
Rich Uravitch is offline
Find More Posts by Rich Uravitch
Rich Uravitch's Avatar
Florida
Joined Sep 2001
Nice job, good video!
Rich
Rich Uravitch is offline Find More Posts by Rich Uravitch
Old Aug 14, 2012, 11:41 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Hi Rich
Thank you for the compliments that means a lot to me coming from the designer!
Rich
Old Nov 03, 2012, 08:17 AM
simplyfly is offline
Find More Posts by simplyfly
go ahead and try
Canada, ON, Maynooth
Joined Nov 2011
Where can I get this kit?
simplyfly is offline Find More Posts by simplyfly
Old Nov 03, 2012, 08:54 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Go to hobbyhangar.com or richuravitch.com
http://www.hobbyhangar.com/newhh2_002.htm
http://richuravitch.com/
Hobby hangar as 52" arf kits for 200.00 plus shipping
Great flying plane!
Help! Rich Uravitch's T-28 chetway The Builders Workshop 3 Dec 12, 2014 05:55 PM
Hobby Hangar's Rich Uravitch RV7?? Tram Scale Kit/Scratch Built 0 Oct 25, 2004 03:12 PM
Question Rich Uravitch plans Mopar92 Electric Plane Talk 5 Sep 19, 2004 10:25 AM
Rich Uravitch L-19 / O-1 Birddog plans tailfeathers Parkflyers 0 Jan 13, 2004 12:30 PM
Where in the world is Rich Uravitch? Greg Covey Sport Planes 5 Jul 17, 2001 10:04 AM
