Joined Dec 2008
Advance Version of R2 Hobbies Raptor 2000
News Flash: Raptor Advance is available for $97.72 from Nov 24th-30th 2011!
See the advert here: http://www.r2hobbies.com/images/news...sgiving%20SALE *Membership is required but it's free to join. (Sale's over for now, but R2 is always offering promotions. Still worth at full price IMO though.) News Flash: Raptor Advance and several other R2 planes are now available in the U.S.A. from Aloft Hobbies http://www.alofthobbies.com/ Shares some similarities with the Passer-X fuselage, wing mounting system and airfoil. Nice to finally have a D-Box, Flaps and removable V-Tail from R2....so tempting at $114 for R2Hobbies Members! If only they had a thermo version and other color schemes. (Edit: 2 new color schemes are available. See website for details) http://www.r2hobbies.com/eng/proddet...pl3901003_code Edit#2: Thermo fuselage finally available: http://www.r2hobbies.com/rc-aircraft...-fuselage.html There is also a Raptor-Tx 2000 version without D-Box wing available too for a little less $$$: http://www.r2hobbies.com/rc-aircraft...ilplane-2.html A Video is finally up from R2:
"Motor, ESC, Battery, Charger, Propeller & Spinner are all ready at our store! Hug it!" Gotta love that line ![]() Raptor (AKA Sloopy) Manual posted by Mitch: http://www.rcgroups.com/forums/showa...1&d=1322066976 Suggested Center of Gravity: 1/3 distance from leading edge. That's 73mm from the 220mm wing, but others have had good success with up to a more lively 80mm CoG. Here's Mitch's (AKA warwickcorvette1) great review of the 3/Channel Yellow Raptor with pix too: *note this has a non-removable V-Tail. http://www.rcgroups.com/forums/showp...&postcount=172 http://www.rcgroups.com/forums/showp...&postcount=179 Known differences between RA2000 and other versions: 1. RA2000 is the only version with flaps thus far; the rest are listed as "3 Channel" gliders. 2. Wing servos are supposed to be mounted vertically vs. standard flat/horizontal configuration found in all the previous versions. (Hence the servo wing mod below) 3. V-Tail servos are secured horizontally with zip-ties. (This is easier than prev. ver.) 4. Holes are pre-drilled in the rear of the fuse for bottom mounted control horns. Common issues for RA2000 1. Recently, some raptors have been arriving with loose or separated wing tips. Please check this part during your build. Raptor Advance Requirements: OK, I'm reserving this spot for Parts Lists since Jonathan (a.k.a. Twyl) had made the suggestion. As time allows, this section will be updated with parts suggested by participants in this thread ![]() (Only actual parts being used in this model will be listed here) Here is the format: Motor Here's Jack's informative post about possible extended motor shaft lengths required to install spinners (34mm Turbo from Esprit Model in this case) and clear the firewall: http://www.rcgroups.com/forums/showp...&postcount=356 *Note, the suggested D2836 motor fits perfectly without the need for an extended shaft. Here's Jack's step by step tutorial for making an extended motor shaft from an HSS drill blank: http://www.rcgroups.com/forums/showp...&postcount=374 1. Suggested by R2: Eurgle 1000pm/v D2836 EP Brushless Motor. Part# rcps4409002 *Please note that the: Product ID: rcps1016001_1180 11 x 8" Folding Propeller with 34mm dia. Aluminium Spinner Hub with 3mm Shaft; available from R2 does not fit the D2836's 4mm shaft. 2. NEODYM 400-920 motor with Graupner 11X6 folding prop (Tested with good results by Mitch) Relevant Post: http://www.rcgroups.com/forums/showp...&postcount=189 3. Turnigy 2836-1200 motor installation by Rotozuk: http://www.rcgroups.com/forums/showp...&postcount=413 4. Dualsky SM2830CA-12 (980 RPM/V) Some modification required, see bamoore01's tips for installation here: http://www.rcgroups.com/forums/showp...&postcount=783 Spinner/Prop 1. BB 34mm folding prop with 4mm shaft and Aeronaut 11x6 blades: http://www.espritmodel.com/bb-alumin...ropellers.aspx 2. Graupner 34mm folding prop (3 or 4mm collet relative to motor shaft) Relevant Post: http://www.rcgroups.com/forums/showp...&postcount=205 3. BB Al Turbo (34/3.2/8) with Aeronaut CAM Folding Prop (11x6) Used by bamoore01 Servos 1. EMAX Full Metal Gear Micro Servo ES08MA (1.8kg) x6 pieces The ES08xx line of servos "snap" perfectly into place in the plywood mounts for the V-Tail. Dimensions:23.0mm x 11.5mm x 24mm (.09" x 0.45" x 0.94") 2. Jack's excellent guide to Vertical Servo Installation (Suggested Kit Style) using HXT900 Servos. Lots of step by step photos too. http://www.rcgroups.com/forums/showp...&postcount=321 3. Jack's unique guide to extending servo leads without the use of the plastic housings. This one aids in sliding the leads through the wings: http://www.rcgroups.com/forums/showp...&postcount=375 4. Jack's Sevo Lead to Receiver tutorial: http://www.rcgroups.com/forums/showp...&postcount=378 5. Rotozuk's Fuselage/V-Tail servo installation: http://www.rcgroups.com/forums/showp...&postcount=413 http://www.rcgroups.com/forums/showp...&postcount=417 6.Ross's (aka Mulgaman) great Double-Decker Battery Tray mod and Fuse vents: http://www.rcgroups.com/forums/showp...&postcount=528 Battery & ESC 1. Jack's solution to mounting the Battery & ESC in the fuse with velcro-style tape: http://www.rcgroups.com/forums/showp...&postcount=379 2. Castle Thunderbird 36 (bamoore01) Mods & Installations 1. Servo covers in place of supplied servo frames. (For standard install, please see Jack's guide above) Covers: http://www.jethobby.com.sg/cgi-bin/e...88&idx=1&gid=6 http://www.hobbyking.com/hobbyking/s...idProduct=6998 Relavant posts: http://www.rcgroups.com/forums/showp...6&postcount=49 http://www.rcgroups.com/forums/showp...1&postcount=56 http://www.rcgroups.com/forums/showp...2&postcount=67 http://www.rcgroups.com/forums/showp...6&postcount=74 Jonathan's clean servo bay cutting with a just a hobby knife!: http://www.rcgroups.com/forums/showp...&postcount=462 Wayne's (aka Rotozuk) Eurgle Slim Metal Gear Servo glue-install on to Servo Covers: http://www.rcgroups.com/forums/showp...&postcount=369 TM1's Servo installation & comparison in a blue wing (Vertical to Horizontal) http://www.rcgroups.com/forums/showp...&postcount=824 http://www.rcgroups.com/forums/showp...&postcount=825 Painted Servo Covers for the Red/White version using Krylon Fusion for plastics: http://www.rcgroups.com/forums/showp...&postcount=300 2. Optional "Glue-In Style" Servo Horns This is for those of us who'd rather not see extra screws/platforms form supplied hardware. Horns: https://www.r2hobbies.com/eng/prodde...prod=rcps11936 Relevant Posts: http://www.rcgroups.com/forums/showp...2&postcount=67 http://www.rcgroups.com/forums/showp...&postcount=206 3. Flap & Aileron mod by Flyboy320: Cutting and re-hinging control surfaces for more travel. Materials: Clear Packing tape Relavant Posts: http://www.rcgroups.com/forums/showp...&postcount=102 http://www.rcgroups.com/forums/showp...&postcount=116 http://www.rcgroups.com/forums/showp...&postcount=122 4. Tail Assembly Mods & Installations 4.1. Peg- Mod An additional connection/carbon rod for added support since there's only a single screw for support. Materials: 1.5mm carbon rod Relavant Posts: http://www.rcgroups.com/forums/showp...&postcount=141 http://www.rcgroups.com/forums/showp...&postcount=143 http://www.rcgroups.com/forums/showp...&postcount=205 4.2. Jack's nice variant on a removable tail utilizing lobster claw rubber bands and no extra peg. Lots of good photos too ![]() Relevant Link: http://www.rcgroups.com/forums/showp...&postcount=305 4.3 Rotozuk's V-Tail assembly guide: http://www.rcgroups.com/forums/showp...&postcount=413 http://www.rcgroups.com/forums/showp...&postcount=417 4.4 Jonathan's slick "tape" solution enabling the two tail pieces to be completely separated for transport. This uses 2 carbon rods instead of just one: http://www.rcgroups.com/forums/showp...&postcount=468 5. Color Scheme jackerbes has posted an excellent list of Oracover Colors for those seeking to modify their Raptor's appearance/visibility: Relevant Post: http://www.rcgroups.com/forums/showp...&postcount=235 Dugout's Yellow Tip & Checkered covering solution: http://www.rcgroups.com/forums/showp...&postcount=319 6. Wiring Harnes Mods For those wishing to combine servo connections for each wing panel. Nathan's Multiplex Style plugs with nice photos: http://www.rcgroups.com/forums/showp...&postcount=290 |
Joined Dec 2008
Hi Edwin, sorry to hear about your Passer X. Guess this is a sign that you should be the 1st in Singapore to have shiny new Raptor ![]() Regarding my comment above; I meant a version without the nose cone cut off, like they have with the Passer-X & Passer Thermo. One has to wonder why they don't just make/supply a removable nose cone you can fill with weights for those of us who frequent the slopes. Quote:
You could always email them for a suggestion regarding your specific needs. (Though they don't always seem to understand exactly what you're asking for) If this motor is a bit too overpowering, you can always go for something else or adjust the throttle curve (if using a computerized TX) to make it a little more docile. At under $20, it's seems like a good deal. Cheers to both of you, -8th. What's really interesting is that they now offer 3 versions of the Raptor 2000; a Thermo, Pro and Advance model. But both the Thermo & Pro cost a fair bit more than the Advance, are 5cm longer, and are without the D-Box wing and Flaps! Another thing that appears to be worrisome on this Advance version are the chunky un-aerodynamic servo boxes on the wings that don't seem to be present on the other two models. I'm praying these are just templates or are removable, and that a D47/TS-1002 servo will fit in without much protrusion. I'm curious as to why they wouldn't just include nifty plates like those in the Passer-X and Speedo kits, which can accommodate standard micro servos with only a slight angled bump. |
Joined Nov 2010
8th, When I first came across r2hobbies a couple years ago, I thought, 'Oh no yet another fly-by-night, 'promise the world and deliver a postcard', website from China. Well I was WRONG. I feel very comfortable sending money to these people and getting exactly what they are advertising. I personally love their ESC (Eurgle) and use them in anything I want to keep in one piece. It makes me wonder: If the Passer-X was sold from Hobby-Lobby or equivalent, what would the price be? I have a hunch the price would be closer to $200 from a U.S. Dealer and even then still worth it! I wish they offered more in planes -> gliders -> Scale and high end competition F3J, F5B in particular. They are great for cars, radio and ECS gear. Anyway back to the Raptor... I wonder who makes their planes? I know they have a DLG called the Topsky (Leger) that is world renowned and a very decent price vs. quality. I think they actually make these in-house per order? And their packaging ... excellent! Items and planes arrive at my door step in perfect condition. Once this servo wing mounting issue is resolved or figured out, I will buy this plane. I hope they come out with a different color scheme with a light top and dark bottom. The current scheme makes it hard to differentiate between the two. I hope the owners of R2Hobbies are reading this thread? If you are thanks for offering quality products for a decent price! I am very please with your quality, service and price. Gambler |
| Thread Tools | |
| Discussion R2 Hobbies VGA 2M Advance ARF Electric Sailplane... | 8thelephant | Electric Sailplanes | 43 | Aug 23, 2012 04:38 AM |
| Discussion r2 Hobbies | wicker_Bill | Electric Sailplanes | 6 | Oct 03, 2011 01:19 AM |
| Discussion R2 Hobbies sailing boat hull | rcsoar4fun | Sailboats | 2 | May 19, 2011 10:58 PM |
| Alert 50% off sale at R2 Hobbies | Dofusme | Sailplane Talk | 15 | Apr 28, 2011 10:41 AM |
| Discussion New Sailplane from R2 hobbies 2000-Raptor | kuya- | Electric Sailplanes | 7 | Dec 30, 2010 07:03 PM |
