Old Oct 19, 2011, 12:41 PM
stephen.s1 is offline
Find More Posts by stephen.s1
stephen.s1's Avatar
North Branford, CT
Joined Jun 2001
Interesting.... thought it might be cuz of your low humidity.... No strength differences noted?
stephen.s1 is offline Find More Posts by stephen.s1
Old Oct 19, 2011, 02:35 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
No strength difference...
schrederman is offline Find More Posts by schrederman
Old Oct 19, 2011, 03:13 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
There is a product called Super Phatic by Deluxe Materials and sold by Hobby Lobby that is diluted aliphatic glue. It can be used much like CA in that it will wick into assembled joints. No need to get it as you can dilute as Jack mentioned earlier
Mark
Mark Miller is offline Find More Posts by Mark Miller
Old Oct 19, 2011, 03:31 PM
stardustertoo is offline
Find More Posts by stardustertoo
Canada, AB, Red Deer
Joined Apr 2010
A little tip I was given a number of years ago regarding diluting glue. If you are one of those guys who prefers aliphatics due to the strength, weight, ease of working with it etc, but you want to speed up the drying time, mix in some methyl hydrate. Methyl hydrate mixes in fine, thins out the glue so it flows and soaks in nicely, but it evaporates faily quickly and you end up with almost an "aliphatic CA" hybrid. I have used it a few times and it works pretty slick.
Now down in the desert where Jack is at you you don't need to do that, right Jack
stardustertoo is offline Find More Posts by stardustertoo
Old Oct 20, 2011, 08:12 AM
Joined Nov 2002
Sorry, but work problems kept me out last night... so no pics or progress... No need to speed up drying time for me... In fact, I need to slow down... drying time... and my life!
Old Oct 24, 2011, 10:42 AM
Joined Nov 2002
Sitting in the Denver airport on a layover. I have made some progress, but haven't had time to post pics. I'll take quite a few when I have time later this week... I have the fuselage sides done, with the exception of the 1/4" triangle stock. I didn't get any and the LHS had only one empty slot in the balsa bin... yep... 1/4" triangle... He should have it in by the time I get back from sunny Commifornia...
Mark... If the Rangers lose the Series... it all goes in the trash can! (Just kidding )
Jack ... aka Darth Overworked and Overfaired...
Old Oct 24, 2011, 10:43 AM
Joined Nov 2002
OBTW Mark... A couple of fuselage cross sections would help beginning builders immensely, as would a dihedral diagram...
Old Oct 24, 2011, 11:06 AM
Joined Oct 2002
Jack,
I can send you some triangle stock. I have plenty.
My prediction was that it will go 7 with a bad outcome for the Cards. I don't follow baseball and am just going by gut.
Mark
Old Oct 25, 2011, 10:43 AM
Joined Nov 2002
It's cheaper for me to buy than for you to ship... and it's no problem... He'll have it by the time I get back to Amarillo...
Old Oct 25, 2011, 02:00 PM
LVsoaring is offline
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
My sincerest condolences sir.
LVsoaring is offline Find More Posts by LVsoaring
Old Oct 26, 2011, 11:08 AM
Joined Nov 2002
Got home around 1:00 AM this morning. I will be going home... via the LHS... around 4:00 and should be able to post some stuff tonight...
Old Oct 27, 2011, 12:17 AM
HIR/Cer is offline
Find More Posts by HIR/Cer
HIR/Cer's Avatar
Joined Apr 2005
Looking forward to seeing the progress on the fuselage. BTW, excellent joints on the wing build!
HIR/Cer is offline Find More Posts by HIR/Cer
Old Oct 29, 2011, 02:55 PM
Joined Nov 2002
Wing Bottom Sheeting
We had a question about how to hold up the bottom sheeting when the wing has what we used to call "Phillips Entry"... It's pretty simple if you have laser-cut parts. Lay a ruler on the sheet blanks after the ribs are removed. Compensate for the sheeting thickness at the trailing edge.
A couple of pictures will tell the tale...
Well... I can't get the pictures to upload right now. I'll try later this evening. I have poor internet service... wireless only... since I moved from Clovis. I guess that's the price of living out in the counrty.
Old Oct 29, 2011, 03:25 PM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
[...] I made a template for marking the trailing edge so I could have accurate rib notches. However, we'll do this a different way for the main panels... more on that later.
Here's what the template and trailing edge look like...
Jack:
I'm late joining this thread. What did you make you yellow colored templates of way back in the post in the quote?
- Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Oct 29, 2011, 03:28 PM
Joined Nov 2002
Continued
OK... let's try again... says we're up on 3G... we'll see...
For whatever reason, I cannot upload pictures right now. I'm going back out to do some more building. I'll try later...
Build Log Build Log - STARFIRE! Mc Clain Wing Cores 48" Beta Build pval3 Flying Wings 557 Feb 28, 2016 09:18 PM
New Product Scale Military UAV / Drone Beta-Kit Build/NOW WITH VIDEO! pattypilot Electric Warbirds 140 Mar 01, 2012 12:28 PM
Discussion Isthmus Models Duet Beta Build StevenatorLTFO Sailplane Talk 158 Sep 16, 2011 08:34 PM
Discussion Rollason Beta quick-build Sopwith Mike Scale Kit/Scratch Built 74 Jul 27, 2011 03:45 PM
Discussion Kit/Plane fun build contest-Hawker Typhoon beta build baldguy Scale Kit/Scratch Built 268 Oct 07, 2009 11:58 PM
