Old Sep 27, 2011, 03:11 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
Now you all can see why I went with the 1" TE stock. There is not much to the back of this airfoil. With 3/4" it would break easily. Looking back while this airfoil has specs as good or better than any RES airfoil out there currently including the Drelas it may be better suited to and was designed for the Ava/Soprano type construction.
My hope is to get some custom cut TE stock that will fit better and so less planing and sanding.
Mark Miller is offline Find More Posts by Mark Miller
Old Oct 10, 2011, 09:56 AM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
I've been out of pocket for a week attending a dog and pony show... (staff meeting)... and then had VIP company all weekend... (grandson)... I'll be hittin' it again tonight!
schrederman is offline Find More Posts by schrederman
Old Oct 10, 2011, 10:29 PM
Lacquerhead is offline
Find More Posts by Lacquerhead
Wood Chucker
Lacquerhead's Avatar
USA, TX, Allen
Joined Nov 2009
Would custom cut TE compare favorably against something like CF prelam? It seems to me that I've seen a lot of rubber FF models using prelam as TE material recently but that's not a community I'm involved in.
Lacquerhead is offline Find More Posts by Lacquerhead
Old Oct 11, 2011, 02:01 PM
Joined Oct 2002
A CF TE would be great but remember that this is a beginner to intermediate design. This necessitates keeping cost down and assembly basic.
Old Oct 17, 2011, 08:54 AM
Joined Nov 2002
OK... I have actually done some work on the Duet. I'll be posting some pics and narratives tonight... I'm at the salt pit right now...
Old Oct 17, 2011, 12:25 PM
Wood Chucker
USA, TX, Allen
Joined Nov 2009
Would it be possible for an ambitious fabricator to replace the TE with laminated CF? I don't know that I'm actually that ambitious but I might experiment on another model to see if its worth the effort.
Old Oct 17, 2011, 08:47 PM
Joined Nov 2002
OK... so here we go again. I have joined the center panels and added the upper sheeting and leading edges. So far so good. I'm going to upload pictures without much narrative. There'll be some labeling, etc... but I'm curious as to what and how many questions I'll get.
Old Oct 17, 2011, 09:01 PM
Joined Nov 2002
Last installment for tonight... and probably until next weekend. You know... that nasty 4-letter word... WORK!
I hope you 2-meter lovers will take the last caption as the funny it was intended...
Old Oct 17, 2011, 09:16 PM
Wood Chucker
USA, TX, Allen
Joined Nov 2009
Nicely done work Jack. So far, beautiful. I noticed the backing plate on the center joiner is beveled at the edges. Is there a mechanical reason for that or just personal preference?
Old Oct 17, 2011, 11:04 PM
Joined Nov 2002
The edges are scarfed out to feather edge to prevent a stress point. It's proven to help some, but probably more for my peace of mind than anything...
Old Oct 19, 2011, 08:19 AM
Joined Nov 2002
I started on the fuselage last night. I just started by gluing the sides together and trial fitting parts. Two of the bulkheads get glued together to form one, and that's done. I glued the sides together, one on top of the other, with waxed paper in between, so they would be perfectly aligned with each other. I'll take a few pics tonight and post 'em... I'll be laminating the 1/64" ply nose doublers in place with polyurethane glue or thinned wood glue this evening... depending on the temperature in my garage. I haven't broken out the heater, yet, but it may be time to do that...
Old Oct 19, 2011, 08:46 AM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Hi Jack, looking good so far. If you can, would you demonstrate how you get the bottom leading edge sheeting to glue to the curved ribs? That was always something that vexed me when I was a beginner builder.
Wayne
Windependence is offline Find More Posts by Windependence
Old Oct 19, 2011, 10:25 AM
stephen.s1 is offline
Find More Posts by stephen.s1
stephen.s1's Avatar
North Branford, CT
Joined Jun 2001
Why do you dilute Titebond?
stephen.s1 is offline Find More Posts by stephen.s1
Old Oct 19, 2011, 10:40 AM
Joined Nov 2002
It soaks in better and I actually use 1/3 less glue in each joint. It also slows my drying time somewhat. That's not important in areas where the humidity is high. But on the desert high plains, where the humidity is generally less that 20%, without dilution, Titebond scabs over in less than a minute.
Build Log Build Log - STARFIRE! Mc Clain Wing Cores 48" Beta Build pval3 Flying Wings 557 Feb 28, 2016 09:18 PM
New Product Scale Military UAV / Drone Beta-Kit Build/NOW WITH VIDEO! pattypilot Electric Warbirds 140 Mar 01, 2012 12:28 PM
Discussion Isthmus Models Duet Beta Build StevenatorLTFO Sailplane Talk 158 Sep 16, 2011 08:34 PM
Discussion Rollason Beta quick-build Sopwith Mike Scale Kit/Scratch Built 74 Jul 27, 2011 03:45 PM
Discussion Kit/Plane fun build contest-Hawker Typhoon beta build baldguy Scale Kit/Scratch Built 268 Oct 07, 2009 11:58 PM
