Old Nov 30, 2011, 09:14 AM
schrederman is online now
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Be sure to do just that! If I'm in town, we'll fly!
schrederman is online now Find More Posts by schrederman
Old Nov 30, 2011, 09:33 AM
Lacquerhead is offline
Find More Posts by Lacquerhead
Wood Chucker
Lacquerhead's Avatar
USA, TX, Allen
Joined Nov 2009
I certainly will!
Lacquerhead is offline Find More Posts by Lacquerhead
Old Nov 30, 2011, 12:06 PM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
Mark:
Could you post a pic of the IM001TE airfoil? I would like to see just how thin the aft taper is.
Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Nov 30, 2011, 12:28 PM
Joined Jun 2003
Glue for Upper Sheeting
Originally Posted by schrederman View Post
I have the leading edges done and planed. Here's what the process looks like.
I realize this is old.
Jack,
What glue did you use for the upper sheeting and did you need water to get it to curve?
How did you hold the sheeting in place while applying the glue?
- Jim
Old Nov 30, 2011, 02:20 PM
Joined Nov 2002
Jim,
I use polyurethane glue for gluing on the top sheeting, usually... However, with this build, I used aliphatic resin (Titebond II) glue. I use phone books to keep the top sheeting pressed down. No water is necessary if you use good, medium, A-grain wood, as it bends pretty easily. I always position the books with the back just behind the spar and the opening pages to the leading edge. That allows the book to conform to the rib-top shape easier. I tape the sheeting at the spar and the leading edge with masking tape first, before outting the phone books on. I will usually stack the phone books 2 deep. Another note, I am not using books that are less than 2" thick. The lighter, thinner ones won't do you a lot of good...
With this arrangement on a flat building table, you come out with nice, straight wings. In a D-tube configuration, the bond between the ribs and the D-tube sheeting is very important for torsional rigidity. I have seen this done with contact glues and other stuff, but that is too flexible, in my opinion, for the best strength and flutter resistance.
No probelm with it being old... I am too...
Old Nov 30, 2011, 02:35 PM
Wood Chucker
USA, TX, Allen
Joined Nov 2009
Drats. I just pitched a whole bunch of old phone books.
Old Nov 30, 2011, 04:50 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
Regarding the airfoil....
Here is a two view of the Duet. It is an earlier version but only minor details have changed. You can see the airfoil there.
Also here is the analysis of the airfoil compared to the Bubble Dancer AG. Back then it was called RES1.
Here is a quote from the designer...
This is an XFOIL Type 2 analysis, RE ~ sqrt (CL), RE 80,000 at CL = 1.
In the range of operation CL = 0.4 -> CL = 1.0 (corresponding to thermal flying), the drag of the RES1 is less than that of the AG35, at some points as much as 10% less. The AG35 is superior at CL 0.35 and below, corresponding to a flying speed of about 1.5x the usual flight speed, or faster.
The Duet is really a test bed for the airfoil. My goal is to have a new RES plane for next year using this airfoil. I have some cool ideas. Now the real trick is putting them into reality.
Mark Miller is offline Find More Posts by Mark Miller
Old Nov 30, 2011, 06:54 PM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
I hope one of the cool ideas is a 3+ meter version!
LVsoaring is online now Find More Posts by LVsoaring
Old Nov 30, 2011, 07:41 PM
Joined Oct 2002
That is the plan. it is time to replace the Soprano.
Old Nov 30, 2011, 08:07 PM
jh2rc97 is offline
Find More Posts by jh2rc97
Dallas, TX
Joined Jan 2005
Mark,
What is the rough date of when the Duet will be up for sale?
jh2rc97 is offline Find More Posts by jh2rc97
Old Nov 30, 2011, 09:02 PM
Joined Oct 2002
I am happy with what I see with this build. Looks like we have things sorted. I have flown two of them so far and know that they fly great.
At this point the only remaining piece is a manual. Using Jack's build thread and some photos I already have there should be about to finish that. I'd like to have a few for sale by the New Year.
Old Dec 01, 2011, 08:38 AM
Joined Nov 2002
Amarillo weather is turning to crap... which is good for building... so, unless I have weather related emergencies for the railroad, I intend to finish this model this weekend. This week, my job has been intense, but things are slowing down. I should be able to post some progress tonight.
Old Dec 01, 2011, 06:27 PM
Cap_n_Dave is offline
Find More Posts by Cap_n_Dave
Joined Mar 2008
Errr...how about a vacuum instead of the books?
Cap_n_Dave is offline Find More Posts by Cap_n_Dave
Old Dec 01, 2011, 06:28 PM
Joined Mar 2008
Is the airfoil proprietary?
Old Dec 01, 2011, 06:39 PM
Joined Oct 2002
Yes it is Dave
Build Log Build Log - STARFIRE! Mc Clain Wing Cores 48" Beta Build pval3 Flying Wings 557 Feb 28, 2016 09:18 PM
New Product Scale Military UAV / Drone Beta-Kit Build/NOW WITH VIDEO! pattypilot Electric Warbirds 140 Mar 01, 2012 12:28 PM
Discussion Isthmus Models Duet Beta Build StevenatorLTFO Sailplane Talk 158 Sep 16, 2011 08:34 PM
Discussion Rollason Beta quick-build Sopwith Mike Scale Kit/Scratch Built 74 Jul 27, 2011 03:45 PM
Discussion Kit/Plane fun build contest-Hawker Typhoon beta build baldguy Scale Kit/Scratch Built 268 Oct 07, 2009 11:58 PM
