Old Sep 15, 2011, 11:10 PM
big_poppa4904 is offline
Find More Posts by big_poppa4904
Build, Fly, Crash, repeat
big_poppa4904's Avatar
United States, NC, Shelby
Joined Nov 2010
how many volts can a 550 size BRUSHED motor take?
My ESC went out in my Tower Hobbies electric boat. It has a 550 size brushed motor in it. The ESC that was in there only used NiMh packs, but im wanting to get an ESC that will accept my 3s 2200mah Lipos. I have found a candidate for a ESC, but can my motor handle the 11.1v? From the factory I was using 8.4v Nimh packs with no problem, but my 3s Lipos will be delivering 11.1v.
Will this work?
And here is the ESC. The boat is a small boat, maybe only about 20" in length. Im assuming the 15amp will be ok.
big_poppa4904 is offline Find More Posts by big_poppa4904
Old Sep 16, 2011, 12:42 AM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
15 Amp ESC seems pretty small for a 550 motor, especially since you want to overcharge it.
You want power and do need to get a new esc anyway. So I would go brushless if I'm you. It does not have to be much more expensive. I'd say get the cheapest 60Amp esc and a 3650 brushless motor. A bigger motor will be overkill, not that it might not be fun...
You will appreciate the reliability and of course the extra power.
SARCFAN is offline Find More Posts by SARCFAN
Old Sep 16, 2011, 05:40 AM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
It all depends on what the voltage rating is on the motor. I've got 550 motors rated at only 6 volts & some rated at 18 volts.
8.4 & 9.6 volt rated motors will run on a 3s pack with no problems but you may need to prop down a bit as the revs will be quite a bit higher.
You will need to find out the voltage rating of the motor first.
Paul.
785boats is offline Find More Posts by 785boats
Old Sep 16, 2011, 06:57 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
A 3s2200mah pack is also really small for a boat this size, you'll want the extra weight of a bigger pack to help keep the boat on the water.
wparsons is offline Find More Posts by wparsons
Old Jun 11, 2012, 04:33 PM
andy stealth is offline
Find More Posts by andy stealth
Joined Aug 2008
50 amp
i sugest that you invest in a 50 amp ESC. i experienced the same downfall in my boat. So i got a 50 amp ESC and ive never looked back.
andy stealth is offline Find More Posts by andy stealth
Old Jun 11, 2012, 08:42 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
50a is way more than a brushed 550 motor will draw, I'd be shocked if it pulls 20a.
Old Jun 11, 2012, 09:04 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
This ESC is perfect for the job, will take 3s lipo as its rated to 10 cells nimh which fully charged is close to 14 volts. 40 amp as well.
http://www.offshoreelectrics.com/pro...rod=dh-prb2314
Your motor may well handle 3s, only one way to find out with the worst result being that you smoke a 10 dollar motor.
scorpion1 is offline Find More Posts by scorpion1
Old Jun 18, 2012, 09:50 PM
Car6on14 is online now
Find More Posts by Car6on14
United States, NC, Cary
Joined Jun 2012
I looked at that esc also for my viper, its running a le mans 360 brushed, it does not have low voltage cut for lipos, see anything with lvc? im looking to run a 2s lipo, ive only seen a traxxas xl5 that looks good?
Car6on14 is online now Find More Posts by Car6on14
Old Jun 19, 2012, 05:19 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I have three of these in my Wallypower 118' model. Each one drives a speed 600 motor & a 32mm water jet pump. On 3s Lipo (2 x 5000mah in parallel). They have Lipo cutout, and a 1A BEC Excellent little ESC's.
http://www.hobbyking.com/hobbycity/s...USHED_ESC.html
Old Jun 19, 2012, 10:47 AM
Joined Jun 2012
nice, looks like a good esc, do they offer 1 w/ reverse? im not seeing one
Old Jun 20, 2012, 08:13 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Sorry pal. No reverse. That's its only drawback.
Old Jun 20, 2012, 08:39 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
I've been running this esc for 4yrs now and never any problems .It's the Ripmax Xtra 35 amp brushed 5 to 12 cell nima or lipo 2 to 4 cell lipo . They have 7amp to 50 amp lipo friendly esc . Not the cheapest . you can find them at http://globalservices.globalhobby.com Look at some car brushed esc .there are a ton of them on Ebay , even found some water proof ones .
highflyerbill is offline Find More Posts by highflyerbill
Old Jun 20, 2012, 04:06 PM
Joined Jun 2012
Highflyer bill, that link does not have any ripmax products? and no search function, im googling found these: im in the states tho: http://www2.ripmax.net/Category_List...ry=060-050-100
im having a hard time finding a lipo friendly brushed esc w/ these features:
Reverse
BEC
Lipo 2s & 3s
lipo 3v voltage cut
30 - 60 Amps
I looked on ebay and contacted many sellers, and am still looking other sites online, im thinking im just going to settle for a traxxas xl5(9.6v max) or run a lipo low voltage indicator w/ buzzer?
Old Jun 21, 2012, 03:54 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I forgot to mention, that I've also got a couple of these in my tank landing barge driving 785 motors, spinning 45mm 3 blade pros on 2s lipo.
http://www.himodel.com/electric/150A...k_Crawler.html
Although is says 150A, I don't think is really is if you look at the wire size & the type of connectors.
They have two sets of output cables for twin motors but I only use one set on each controller.
I've also used them on 3s & 4s lipo in other models on 600 & 700 motors. No problems.
they have reverse. No Lipo cutout though. I just use an alarm module like this
http://www.himodel.com/electric/HiMo...t_3.7-30V.html
L
Sold Brand New Novak HV4.5 (550 size 4.5 turn) motor ta_man Cars - Accessories (FS/W) 0 Sep 09, 2011 10:17 PM
Help! how many volts can the rustler vxl take RUSTLER VXL Electric Power Cars 2 Jul 20, 2010 04:51 PM
Discussion how many volts can a fireball modified 17t motor handle? asweeba Electric Power Cars 3 Sep 20, 2009 03:58 PM
How many volts can a CN12-RLC really take? baza32000 GWS (Grand Wing Servo) 4 Jun 08, 2004 11:30 PM
How can I tell how many volts left in my Lipoly's MilkmanDan Batteries and Chargers 5 May 24, 2004 12:26 PM
