Old Jan 21, 2013, 03:59 PM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I dont do anything but the Foam at this time.
I used some flat pieces of thin 1/32 ply in certain locations.
But I dont know if mine is built too heavy or not yet, ya know.
I don't believe myself to be of any authority on these until I've finished and flown it.
I simply took the drawings provided here and did the CAD and CNC work.
Best
Bob
birdofplay is online now Find More Posts by birdofplay
Old Jan 21, 2013, 08:50 PM
tom-tom 1 is offline
Find More Posts by tom-tom 1
Joined Jun 2010
I've haven't gotten mine to fly yet. My first was too heavy. My second one was built from Bob's plans posted on this thread reduced to 75%. I've got it all together and tried it but I had some problems. In forward flight mode the thrust was opposite the yaw in quad copter mode. I think I got that fixed. Also I'm wondering if enough air flow is moving from the rear two motors. The 8" prop is way wider than the tilt area provided in the rear wing in quad copter mode. It seems, that a lot of the thrust is diverted onto the wing instead of through the open area which will reduce the thrust lift. F&Ts model looks like it flys sooooo good. I've yet to see another like his to fly at all. I'm getting closer but, I'm not there yet.
tom-tom 1 is offline Find More Posts by tom-tom 1
Old Jan 23, 2013, 01:59 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by tom-tom 1 View Post
It seems, that a lot of the thrust is diverted onto the wing instead of through the open area which will reduce the thrust lift...
Cut the hole bigger. Mine isn't that much different from F&T's
Have you flown it in regular airplane mode yet? If not, what's the hold up
RCvertt is offline Find More Posts by RCvertt
Old Jan 23, 2013, 02:07 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
yup, i'd reccomend testing forward flight before investing time into adding all the tilt components in. I have 8 inch props on mine too and having less wing in the way definitely helped with hovering. The thing did fly OK in forward flight, it certainly wasn't anything spectacular along with in hover. It pretty much did what it wanted to do in hover mode regarding yaw control.
I'm currently crafting up another VTOL similar to LF's F-35, pretty much the same configuration. I'll try to provide plans for this one and a build guide if it works.
foam and tape is offline Find More Posts by foam and tape
Old Jan 23, 2013, 05:38 PM
Brandano is offline
Find More Posts by Brandano
if the two front or rear motors are on separate tilt servos it might be simpler and more effective to control yaw through differential tilt than with the typical cross/differential thrust arrangement of fixed rotor quads.
Brandano is offline Find More Posts by Brandano
Old Jan 23, 2013, 05:59 PM
Joined Jun 2010
Have you flown it in regular airplane mode yet? If not, what's the hold up[/QUOTE]
Well-the weather has been bad, it's 35 miles to the flying field, I've been working until dark, the check's in the mail, the dog ate my homework, but mostly it's cold and windy.
Old Jan 23, 2013, 07:55 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
That attitude ain't going to fly around these parts. Get some credit cards, take the dog to the pound and put some lights on that sucker and fly
Old Jan 23, 2013, 08:01 PM
beavercreek,ohio
Joined Jan 2007
hell yeah I'm just about to go test the Chimera (awesome name for a VTOL) in 14 F and snow... whats your excuse.
Old Jan 23, 2013, 10:02 PM
Joined Jun 2010
Sooo, That's the way it is. I guess the excuses will have to stop. Thanks for the encouragement. More videos and photos to come.
Old Jan 24, 2013, 09:03 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Yeah, my new F-35 is still collecting dust. All I need to finish it is the top fuse. I got stuck here cause I wanted to do a nice (possibly vacuum molded) looking canopy/fuse. It's pretty much the same as the first except the addition of retractable landing gear.
leadfeather is online now Find More Posts by leadfeather
Old Jan 25, 2013, 09:10 PM
Joined Jun 2010
I got two short flights down the street-straight and low in forward flight mode. I still haven't got the thing to hover. My yaw control seems to be opposite in hover mode than in forward flight mode. It doesn't help to reverse my servo in the radio. It just reverses both. I have changed yaw direction in the code and that doesn't seem to be the answer either. RCvertt, do you have any ideas. Is there someplace in the code where I can control the variable thrust in forward mode- like reverse direction, increase or lessen or turn off? I am going to switch out the boards with my quad copter and see if I can get it to hover. I could have something hooked up wrong. I know my quad copter works so I'm interested in what that board wilol do in my quad vtol.
Old Jan 25, 2013, 10:24 PM
beavercreek,ohio
Joined Jan 2007
I think it might have something to do with which way you have your yaw control set, I noticed your left rear motor is turning the prop CCW, I think I have mine setup CW so I may not have had to reverse my yaw command. Also in this configuration the (slight) twisting of the air frame during yawing to the left/right twisted the frame in the correct direction that it should turn, thus aiding in yawing the thing.
Old Jan 25, 2013, 10:28 PM
beavercreek,ohio
Joined Jan 2007
Sounds neat, I was contemplating Vacuforming an entire airliner fuselage out of some really thin ABS or some clear Vacu sheeting and making the wings and tail out of depron. The plane would have been an indoor flyer with a 40-50 inch ws. Definitely keep us informed as I haven't seen any vacuformed foamy planes.
Old Jan 25, 2013, 10:45 PM
Winging it >
Joined May 2006
I want to use PET (polyethylenepterthalate) very tough plastic used in packaging and soda bottles for the vacuum forming. I built a little jib and it works pretty good. I just have to make the fuse plugs to complete.
Part of the reason for the formed fuselage is to have space on top for the battery and especially the flight control board. Bottom mounting the fcb changes some of the orientation of the gyros.
Old Jan 25, 2013, 11:45 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Just a little tough love from the VTOL family That Chimera looks like a cool project F&T.
Build Log Quad Tilt Rotor - Build Log (Comments & Suggestions Welcome) maxvtol VTOLs 254 Aug 31, 2014 01:53 AM
Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) RCvertt VTOLs 100 Jun 28, 2012 01:15 AM
Discussion Help selecting receivers and transmitters for quad rotor oscioscia Multirotor Talk 5 Sep 06, 2011 02:43 PM
Discussion mcx 5in1 Unit for Roll Tilt Compensation on Quad nicnaimless Multirotor Talk 0 Aug 11, 2010 02:17 PM
Cool WOW!!!! Iphone controlled quad with vid link to iphone, tilt controlled!! helifrek Multirotor Talk 8 Jan 18, 2010 10:23 AM
