Old Dec 14, 2012, 03:12 AM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
Right.
I didn't think of that.
I love how it makes it's own clear spot to land.
Dirk.
swami is offline Find More Posts by swami
Old Dec 18, 2012, 09:29 AM
marlinlinger is offline
Find More Posts by marlinlinger
Joined Dec 2012
Dear Peter,
I saw a video on flitetest.com about your X-19 Hummingbird VTOL aircraft. I teach a course involving quadcopters at Lorain County Community College in Elyria, Ohio. I am also the faculty adviser for the college's Orbit aerospace club. Are you ever up in northeast Ohio? I'm wondering if you would like to bring your X-19 aircraft to an Orbit meeting to discuss your aircraft. We also have an outdoor flying field and an indoor field house in which we can fly RC aircraft, if you would like to demonstrate it. Or if you're ever flying it in the Dayton area, perhaps I could see it there. I'm down there fairly regularly. Neat project. Good luck with it!
Marlin
marlinlinger is offline Find More Posts by marlinlinger
Old Dec 22, 2012, 06:13 PM
tom-tom 1 is offline
Find More Posts by tom-tom 1
Joined Jun 2010
RCvertt - F&T,
I've been building a 75% QTR since my first attenpt was too heavy. I want to use elevons on the aft wings. When I set my DX8 to elevons, my motors don't power upcorrectly for hover. The motors work correctly when I set the wing selection to normal wing. How did you get your elevons to work correctly and not mess up your quad copter function? Thanks, I 'm not giving up yet.
tom-tom 1 is offline Find More Posts by tom-tom 1
Old Dec 22, 2012, 06:48 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Originally Posted by tom-tom 1 View Post
RCvertt - F&T,
I did mine by slaving Channels 6 and 7 for the quad parts, 6 slaved to 1, 7 to 2 and rudder was just y harnessed for both. That way elevon mixing happens for 1 and 2 and 6 and 7 only correspond to the individual sticks. That or use a vtail mixer.
foam and tape is offline Find More Posts by foam and tape
Old Dec 22, 2012, 10:10 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Mine was mixed in Arduino code. I think F&T's method will work best for you. It will work better if you don't have elevons on the back. Canards like the Long Easy like to have elevator control up front.
So you should be able to get away with no mixing and just plug your back ailerons directly to the RX and your front elevator directly to the RX and have full airplane control. If you go this route make sure you mount your servos in the correct direction since you won't be able to use your TX servo reversing since that would affect your quad controls. Or slave a channel to the aileron and elevator like F&T suggested so you can reverse those channels latter if you want. If you slave a channel then that would also allow you to control its travel range which might come in handy.
RCvertt is offline Find More Posts by RCvertt
Old Dec 22, 2012, 10:59 PM
Joined Jun 2010
Thanks so much F&T and RCvertt for your quick and informative answers to my problem. Now I have to decide which way to try. I was going to try to leave off the rudders because the board gives me variable thrust for yaw. I saw this done in the RCvertt video. I was also going to try to leave off the active elevator on the canard. F&T said his elevator came loose and it didn't make any difference in the way his QTR flew. In the interest of weight, I was just thinking of leaving them both off. What do you think?
Old Dec 23, 2012, 09:28 PM
Joined Jun 2010
I decided to go for an active elevator on the canard and elevons on the aft wing. I got everything mixed correctly as far as direction goes. Travel and trim are another matter. Where generally is the CG as far as forward flight is concerned? In F&Ts videos I could hardly tell the surfaces were moving so I'm guessing that I won't need a lot of throw. Here are photos of the new (around 2 LBs) lighter version. I went back with the little blue wonder motors. I hope to test it out this week.
Old Dec 23, 2012, 10:09 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Looks good. You may not need a rudder that moves but you will need at least a vertical stabilizer.
...Where generally is the CG as far as forward flight is concerned? In F&Ts videos I could hardly tell the surfaces were moving so I'm guessing that I won't need a lot of throw...
I used an online canard CG calculator I found on google and ended up with my CG about an inch in front of what the CG calculator told me. I recommend you do your first forward flight tests with a conventional rolling takeoff and landing or it'll crash and you won't know why.
I wouldn't worry about tilting the motors yet. If they are already on tilting rods then hot glue the rods in place and fly it like a normal airplane. You'll probably end up changing its shape as you try to get it flying good. If it doesn't fly good then the canard is probably too long. It should be about half the length of the rear wing or smaller.
My elevons had to move a lot and had to be big.
Old Dec 23, 2012, 10:17 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Looks like your elevator on the canard is half the length of the canard. I would make it the full length of the canard.
Old Dec 25, 2012, 07:49 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
F&Ts design has the OUTER front Wing tilting with the motor and the
inner Front wing fixed except for the moveable elevator.
It seems to have worked well for him.
birdofplay is online now Find More Posts by birdofplay
Old Dec 25, 2012, 09:42 PM
beavercreek,ohio
Joined Jan 2007
I think my CG was about in between the four motors. Possibly about an inch or two forward of that. Its gone now though
Old Jan 20, 2013, 01:43 PM
garrisondr is offline
Find More Posts by garrisondr
Joined Apr 2012
Birdofplay: Did you ever get your version flying?
garrisondr is offline Find More Posts by garrisondr
Old Jan 20, 2013, 02:08 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
It's possible that mine was nose heavy. I recently had the same problem with my Osprey but moving the battery back on it brought the elevator to life.
Old Jan 20, 2013, 02:23 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
NO dang it all ... It's in storage still.
I wont have a large enough place to do Building until Early Summer "hopefully".
I used what space I have to start up CNC cutting ops again and that was that.
sigh ...
Bob
Hoosier Cutout Service
Old Jan 21, 2013, 01:45 PM
Joined Apr 2012
Bob,
I'm thinking seriously about ordering the foam parts kit from you for Sripol's X-19 Hummingbird QTR. Do you, or can you, provide any other structural parts than just the foam pieces? What would you recommend as the best adhesive to assemble the foam structure? Also, any advice based on your experience would be welcome.
--Darrell--
Build Log Quad Tilt Rotor - Build Log (Comments & Suggestions Welcome) maxvtol VTOLs 254 Aug 31, 2014 12:53 AM
Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) RCvertt VTOLs 100 Jun 28, 2012 12:15 AM
Discussion Help selecting receivers and transmitters for quad rotor oscioscia Multirotor Talk 5 Sep 06, 2011 01:43 PM
Discussion mcx 5in1 Unit for Roll Tilt Compensation on Quad nicnaimless Multirotor Talk 0 Aug 11, 2010 01:17 PM
Cool WOW!!!! Iphone controlled quad with vid link to iphone, tilt controlled!! helifrek Multirotor Talk 8 Jan 18, 2010 09:23 AM
