Old Nov 24, 2012, 11:46 AM
tom-tom 1 is offline
Find More Posts by tom-tom 1
Joined Jun 2010
RCvertt
I built another board,up loaded the FT1.7 code to it and installed it into my QTR. The motors work (-1, bad ESC) but the ailerons and tilt don't. I got the code from this thread. The last one posted for F&T. PinA0 =left aileron,A1=right aileron, and A2=tilt.
I have the tilt in receiver channel 8-aux3. Aux 3 is mixed to activate flaps with 3 positions for the 3 tilt positions.
How do I get them to work. I do have power on the red and black wires to the servos.I have not tried to change anything in the code.
tom-tom 1 is offline Find More Posts by tom-tom 1
Old Nov 24, 2012, 05:35 PM
Fairway is offline
Find More Posts by Fairway
Fairway's Avatar
Joined Sep 2004
Beginner looking for a setup from scratch.
Hi guys,
I am a beginner here with vtol. It looks like a lot of fun. I have been flying RC Planes for 12 years and do a lot of scratch builds.
If you had it to do over what would be your choice for the best setup? I have read the thread for start to end and seen lots of options.
http://www.hobbyking.com/hobbyking/s...DSM2_Port.html
http://www.hobbyking.com/hobbyking/s...PS_Module.html
what would GPS get me? Anyone doing planned flights?
http://www.hobbyking.com/hobbyking/s...er_w_FTDI.html
I plan to build this X-19 Humming Bird
Flite Test - X-19 Humming Bird - REVIEW (2 min 14 sec)
I would really appreciate any and all feedback. Also, any feedback on where to get the software would be great. !!!!
Phil
Fairway is offline Find More Posts by Fairway
Old Nov 24, 2012, 07:06 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Hi Guys,
I believe that I have my CNC machine back together enough
to start making kits again.
I have some foam stocks and a have another 2 cases
of depron arriving on Wednesday.
I've made web page changes, so if you discover
something amiss please let me know right away.
Also NO MORE Black depron offerings.
I still have to get shipping boxes locally.
A trip to deepest darkest downtown Indianapolis is my
next step on Monday, then I'll be ready to go.
Thanks for your patience while I moved 2400 miles,
bought a new house and moved back in. Wheew !
As always I'm here to serve.
e-mail - bob@balsabuddies.com
Web pags - www.balsabuddies.com
Best,
Bob
birdofplay is offline Find More Posts by birdofplay
Old Nov 25, 2012, 10:57 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
F&T I though this was gonna be your next RC project, Am I right?
The Do.X
Pete whatever you build next I know its Gonna Rock!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Nov 25, 2012, 11:49 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Oh yeah, try that plus 21 motors and two spruce goose fuselages arranged in an f-82 style plane. SEFF 2013 project
foam and tape is offline Find More Posts by foam and tape
Old Nov 26, 2012, 01:06 AM
Fairway is offline
Fairway's Avatar
Joined Sep 2004
I am really interested in what board to buy. Can anyone give me some feedback?
Thanks in advance.
Phil
Old Nov 26, 2012, 01:03 PM
Brandano is offline
Find More Posts by Brandano
F&T, if you are going to put that many motors on a plane you should just put a full sized cockpit on it as well.
Brandano is offline Find More Posts by Brandano
Old Nov 26, 2012, 05:12 PM
jyothibasu1k is offline
Find More Posts by jyothibasu1k
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
thanks for ur reply...
jyothibasu1k is offline Find More Posts by jyothibasu1k
Old Nov 26, 2012, 05:43 PM
Joined Jun 2010
Fairway
Go to www.multiwii.com this gives you the basics of the multiwii board. The multiwii board is different than the KK board, and is the board used by Foam and Tape for the QTR vtol you say you want to build. F&T and RCvertt have successfully built the QTR vtol. I have built one, photos and video are posted earlier in this thread. RCvertt has helped me with my project but I haven't gotten everything working yet but I'm close. I think if you read this thread while you build the board using the multiwii web page, you will learn a lot. The plans are posted for the airframe.
I am needing help with the code to get my tilt servo and my ailerons working. I am also waiting for a replacement for a bad ESC.
Old Nov 26, 2012, 11:17 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by tom-tom 1 View Post
...The motors work (-1, bad ESC) but the ailerons and tilt don't...
I only did the motor code for F&T. F&T did all the motor tilting and aileron stuff himself so I will refer to my boss F&T on how he did that.
...I have the tilt in receiver channel 8-aux3. Aux 3 is mixed to activate flaps with 3 positions for the 3 tilt positions.
The motor code is only set up for a two position switch. The receiver AUX channel that you use has to be plugged into the ProMini pin 7.
In the configurator make sure the AUX 1 channel goes from 1200 to 1900 as you move your switch. 1200 = Hover mode motor commands. 1900 = Forward Flight motor commands. To see the affect in the configurator, Don't connect the flight battery, connect USB power to the ProMini, start the configurator and arm the motors. With the AUX switch at 1200 you should see the motor graph act like a normal quadcopter. With the AUX switch at 1900 your motors should only respond to throttle stick commands.
RCvertt is offline Find More Posts by RCvertt
Old Nov 26, 2012, 11:45 PM
Fairway is offline
Fairway's Avatar
Joined Sep 2004
Thanks for your patience while I catch up to you guys
Fairway
Thanks for your feedback. That is a great site.
http://www.multiwii.com/
I also found a very good set of YouTube videos that helped a lot.
Arduino Multiwii Quadcopter Part 2- Wii Motion Plus, Nunchuck Sensors -
Thanks to MachineMarkoeZ
Arduino Multiwii Quadcopter Part 2- Wii Motion Plus, Nunchuck Sensors - Markoez Arduino Vids (3 min 57 sec)
I see in the videos he uses the
Wii Motion Plus (WMP)
and
Nunchuk (NK)
I don't see this on your post. Do we need both of them with the
https://www.sparkfun.com/categories/103
There are so many pick from here. Will this one work
Arduino Pro Mini 328 - 5V/16MHz
https://www.sparkfun.com/products/11113?
Previous is RETIRED
This product has been retired from our catalog and is no longer for sale.
I think I am getting a better handle on this project. It looks fun.
Thanks for your patience while I catch up to you guys.
Phil
Old Nov 27, 2012, 10:15 AM
NoT iNtElLiGeNt
Joined Jan 2011
guy's can any one help me in telling the mechanism he used in 1st video to tilt the rotors in detail..
Old Nov 27, 2012, 06:04 PM
Joined Jun 2010
Phil
Arduino Pro Mini 328 - 5V/16MHz by SparkFun
Yes that is the correct board and is available from Amazon.com for $19.95
Old Nov 27, 2012, 10:45 PM
beavercreek,ohio
Joined Jan 2007
Just a standard HS-311 servo, nothing fancy.
Old Nov 27, 2012, 10:46 PM
beavercreek,ohio
Joined Jan 2007
WOW I just watched Tom tom's video! It looks great man, too bad i'm not much of a use for help. I just got dumb luck with the code and it just worked.
Build Log Quad Tilt Rotor - Build Log (Comments & Suggestions Welcome) maxvtol VTOLs 254 Aug 31, 2014 12:53 AM
Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) RCvertt VTOLs 100 Jun 28, 2012 12:15 AM
Discussion Help selecting receivers and transmitters for quad rotor oscioscia Multirotor Talk 5 Sep 06, 2011 01:43 PM
Discussion mcx 5in1 Unit for Roll Tilt Compensation on Quad nicnaimless Multirotor Talk 0 Aug 11, 2010 01:17 PM
Cool WOW!!!! Iphone controlled quad with vid link to iphone, tilt controlled!! helifrek Multirotor Talk 8 Jan 18, 2010 09:23 AM
