125% Slipso w/Built Up Wing
Several guys on the Slipso thread wanted me to document my build of a 125% Slipso with a built up wing. I seperated this build from a regular Slipso so as not to clog up that thread. I am a wood worker soooooo...would like to keep this thread clear of hollow molding or bagging for the guys who just haven't gotten that far yet.
The reason for the built up wing is that a solid carved wing of that size tends to warp when glassing and finishing. ![]() Soooooo...here we go. ![]() First things first...get the plans in 125% here: http://www.rcgroups.com/forums/attac...mentid=2492756 Then cut the plans for templates. I do my built up wings by building on the bottom sheeting. The sheeting is made after putting several sheets together then the bottom sheet is cut out. Then you must decide on a airfoil and the best place I've found is here: www.worldofkrauss.com/ This is great site the airfoil can be sized by the site and by the printer preview on your printer to get the size you want. Once I got the airfoil (MH43) I printed it out...glued it to lite ply, cut it out and it became the template for cutting out all those ribs (one at a time)
| Thread Tools | |
| Discussion Foam vs Built Up wing weight - No more foam for me! | MCarlton | The Builders Workshop | 15 | Sep 01, 2011 05:41 PM |
| Discussion -- Built Up Depron Wing With Airfoil-- | PinkYakRC | Foamies (Scratchbuilt) | 39 | Jun 13, 2011 02:09 PM |
| Question question about poly wing built up w/ less than specified dihedral. | The Other Dave | Electric Sailplanes | 12 | Dec 17, 2003 04:19 PM |
| Alert Foamy Edge w/built up wing | JoeCrasher | 3D Flying | 9 | Nov 16, 2003 08:59 AM |
| Plans for HLG w/built up wing | Allan Wright | Hand Launch | 49 | Jul 14, 2002 10:56 PM |
