Old Sep 15, 2011, 02:38 PM
cwolfe is offline
Find More Posts by cwolfe
cwolfe's Avatar
United States, TX, Spring
Joined Aug 2011
Question
What's the strongest motor you can put on an AR6400L?
I'm wondering whats the strongest motor I can run off of a AR6400L with builtin brushless ESC I pulled out of my crashed UM Corsair?
cwolfe is offline Find More Posts by cwolfe
Old Sep 15, 2011, 03:31 PM
Ranandar is offline
Find More Posts by Ranandar
Ranandar's Avatar
Kentucky
Joined Dec 2008
That is an integrated brushed ESC, not brushless.
I would not put anything bigger than the one that came with the Corsair.
http://www.horizonhobby.com/Products...odID=SPMAR6400
http://www.horizonhobby.com/Products...ProdID=PKZ3616
Added...
There are alternatives though.
Search for threads about upgrading the PZ-UM to brushless motors.
Ranandar is offline Find More Posts by Ranandar
Old Sep 15, 2011, 04:02 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
You need a new receiver, brushless ESC, new motor, prop and maybe a higher power battery if you really want a lot more power.
If you just want a little more power a slightly larger prop and higher C battery would be more practical.
RC Man is offline Find More Posts by RC Man
Old Sep 15, 2011, 04:15 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
thanks Guys. I did mean to say brushed motor.
Old Sep 15, 2011, 05:05 PM
ausf is offline
Find More Posts by ausf
ausf's Avatar
United States, NY, CENTRAL VLY
Joined May 2011
A lot of guys swear by the BravoSX motor for more power. I'm happy with my Solo Pro over the stock motor, but will try the Bravo when I need to swap it out. You need to pull the pinion gear off the stock motor and install in on the replacement though. It's not hard and if you heat the pinion for a few seconds, it slides right on the new motor shaft. I did three in a matter of minutes earlier this week.
The GWS 5043 prop works great too, especially compared to the 3 blade stock.
ausf is offline Find More Posts by ausf
Discussion If you had an Eflite Power 10 what would you put it in? tptompkins Power Systems 7 Sep 17, 2011 07:20 PM
Sold GAUI 2-4 Cell 12A BL ESC #923122 NIP can put leads on 4 you if needed blueindian Aircraft - Electric - Helis (FS/W) 1 Sep 10, 2011 09:46 AM
Discussion Can you put more than one brushless motor on one esc? asd9000 Scratchbuilt Indoor and Micro Models 13 Aug 04, 2011 07:20 PM
Discussion What's the most lights you have put on your HZ Champ and what did you use newflyer100 Micro Ready-to-Fly 0 Jul 12, 2011 10:27 PM
Discussion What's the smallest prop you can put on an AXI 4130/16 Tracon Power Systems 4 Jul 04, 2007 08:55 AM
