Old May 01, 2012, 03:16 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Heres one of my flights from ETOC with the Arrow V5:
2012 ETOC Freestyle Round 1 Seth Arnold (3 min 8 sec)
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old May 02, 2012, 02:21 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
AWESOME flying!
Why didn't you use VPP this year?
What happened to you Arrow V5 during the X-games?
Free
Free is offline Find More Posts by Free
Old May 20, 2012, 10:21 PM
UBILDIT is offline
Find More Posts by UBILDIT
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Finally Done
O.K. I finally got my Arrow done and flown. All I can say is Wow! I thought the SUltimate flew well right out of my hands... the Arrow is even better.
Thanks Don for the instruction manual and Dave for the Kits and for turning me on to Don's stuff in the first place.... I always love flying a plane that makes me easily look better than I really am.. LOL...
Some specs:
Not milled... going to do some outdoor flying with it at times.
so AUW is 207 grams
4 JR 290G's
CC PH 10 ESC
Spektrum 6115 RX
GensAce 2S 450 25C
Neu Motors Neutrino 14 gram motor. 1850kv
GWS 8x4
Don's reccommended setups as close as I could get on my DX7..
The Neu Motor does not have the punch out power and all out speed that the AXI probably has, but it is more than enough for whatever you want to do and almost completely silent ... which is really cool.
Here's a few pics..
Fly on.
Bo
UBILDIT is offline Find More Posts by UBILDIT
Old May 20, 2012, 10:29 PM
UBILDIT is offline
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Add..
Fantastic routine Seth.... thank the video guy as well...
Nice..
Bo
Old May 21, 2012, 11:16 AM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
two recommendations in one:
drop the weight and increase the power....how?
use smaller lighter batteries and ones that are much higher rate
my recommendation would be Nanotech 300s @35/70C
those go for dirt cheap and a 2S pack will weight UNDER 16gr
also a few more grams could come off with a 6A ESC vs the PH 10
ask any of the pros- lighter flys better, at least until you're below 120g(actually I say 100gr)
and yes, I mostly fly outdoors so I know how different it is
crossup is offline Find More Posts by crossup
Old May 21, 2012, 01:07 PM
UBILDIT is offline
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
O.k..
Thanks for the ideas crossup. I have TP 2S 320 packs at 35 or 40C that will certainly fly it and reduce the weight to under 200 grams but it puts the balance at the rearward point of the CG.. so I use those for indoors. I've also considered taking the bottom off of the two JR 290's in the wings because that will knock off 3 grams right there. ESC has got to stay, but RX covering can be removed. Then i'm pretty sure that I can get it around 180 grams or less.
I could also remove the rubber band powerd micro wheels and their wire from the CF landing struts, but then it would'nt roll on pavement or a gym floor.. LOL.. I'm also pretty sure that the only way to get an Arrow V5 anywhere near 100 to 120 grams is to have it milled and set up for indoor only.
Old May 21, 2012, 11:08 PM
crossup is offline
crossup's Avatar
Joined Feb 2001
Yup, was just saying not too worry about being too light unless you are down at 120 or less.
IRC, the Arrow is a big plane, like my 1 meter Bruckman Spark so they run a bit heavy compared to typical planes. Anyway, the trend, even for local F3P guys is to run very small and light packs, like 180mah now that they can deliver the current, so when you build, keep as much weight forward as possible so you can still balance with small packs. My AITO is a good example of and old design that you just cant build nose heavy enough. I'm forced to run a big pak to balance, like you even though EVERYTHING is at the firewall and so forth. Just something to keep in mind while building.
Old May 22, 2012, 03:02 AM
awood12345 is offline
Find More Posts by awood12345
Epic Win or Epic Fail!
awood12345's Avatar
Kent, England.
Joined Dec 2001
Are there ever going to be plans available for this model Donatas?
awood12345 is offline Find More Posts by awood12345
Old May 22, 2012, 10:35 AM
UBILDIT is offline
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Gotcha..
Crossup, I got your drift... last night I put the 30C TP 320's on it and it took it down to 197 grams. Can't remove the bottoms of the two aileron servo's as they are in front of the CG. Right now, I can put any size battery in basically the same place and it will balance within range, which is nice. Don's comments in the build guide that if you choose the two servo aileron setup it has it's advantages for weight and for actuall flaps was spot on. I set up a mix on my three position switch last night so that flaps go down up to 30% proportional to the up given to the elevator... man that thing loops so fast and tight it was funny to watch... then I turned it off and continued flying like normal.
I got my first plane of this type from DaveL at the JR indoor 3 years ago. It was his "old" Aito bi-plane with a Cyclon motor... and you're right.. kind of a large pack way up front.. LOL.. but that's a great flyer too.. thanks for the encouragement.
Awood12345, I don't even pretend to speak for Donatas but I doubt he'll post plans since he has a network of distributors for the kits. Do what I did with the Sultimate. Buy a kit and trace the parts on your own depron before putting it together. That way you can have spare parts if something drastic happens. The kits are well worth it.
Bo
Old Sep 23, 2012, 10:36 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Hey guys,
I finally built my V5 for this indoor season and it's ready to go except for one item - battery mounting.
I have cut the slot in the top vertical fuselage and put a stop block on one side but not sure how to finish it up so the battery doesn't come out.
I'm thinking of a velcro arrangement of some sort but after building all day, I am brain dead.
So the question of the day is...
How do you tackle the battery mounting issue?
Pictures highly desired!
JC
ps - My next weekly indoor session is in about 18 hours - hope to be ready for the maiden then.
JC Spohr is offline Find More Posts by JC Spohr
Old Sep 24, 2012, 10:40 AM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
Hello JC. I will try to make picture soon on my Arrow V6. But idea is the same. I build depron box for battery, and put just small piece of velcro to one end of battery, on other side of the box I put other side of velcro. Such way velcro is keeping battery in depron box and do not let it slide away from place. In past i simply used bigger piece of velcro, but eventually it was tering plane apart So big piece of velcro is not good in my opinion.
3Don is offline Find More Posts by 3Don
Old Sep 24, 2012, 05:10 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Thanks Donatas.
I figured it out today.
i used some 1/32" ply to make a small rectangular floor under the batterry with a little added length to put some "hooK' side velcro so I won't tear up the foam. That holds the battery pretty snug but I also added a small "loop" piece as added portection to keep the battery in place.
Will try it out tonight.
JC
Old Sep 20, 2013, 10:36 PM
nate 1001 is offline
Find More Posts by nate 1001
nate 1001's Avatar
PA
Joined Jul 2003
Is the manual still available for download anywhere? I found 2 different links on donatas website, but neither one works.
nate 1001 is offline Find More Posts by nate 1001
Old Sep 21, 2013, 04:14 AM
Finnspeed is online now
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
I think the manual could be posted here but it is too large, almost 20 MB (lots of pictures). Donatas reads these forums frequently so I expect him to come to rescue. If not, I can put the manual up to my Skydrive.
Finnspeed is online now Find More Posts by Finnspeed
Old Sep 25, 2013, 10:23 AM
nate 1001's Avatar
PA
Joined Jul 2003
If you could post it or share it, that would be great!
Thanks!
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don Indoor Pattern/F3P 34 Jun 13, 2014 07:22 AM
Discussion VIDEO:Arrow 4D by Donatas 3Don Indoor Pattern/F3P 38 Feb 19, 2013 08:16 PM
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don 3D Foamies 15 Jan 03, 2012 07:41 AM
Discussion SYMMETRIC, new Donatas Pauzuolis F3P design. 3Don Indoor Pattern/F3P 135 Nov 16, 2011 02:29 PM
Mini-Review Futurion (Donatas Pauzuolis design) jackack Indoor Pattern/F3P 1 Jan 14, 2008 08:47 AM
